Posted: Wed Jun 03, 2020 5:38 pm Post subject: 2.2 Subaru Crankshaft Pulley |
The crank pulley on my 1991 2.2 powered Subivan has been wobbling a bit and the rubber is hard as rock. I was just wondering what is the newest year, model, and engine this pulley was used on.
Thanks in advance |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Wed Jun 03, 2020 7:05 pm Post subject: Re: 2.2 Subaru Crankshaft Pulley |
it's all the same 12305 AA243 for the serp belt and 12305 AA001 for the V belt.
if it's a V belt, that changed sometime in the early 90's and shouldn't be rubber isolated.
DO NOT buy a dorman one...they are fukin junk. OEM is like 130 bux _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Zeitgeist 13 Samba Member
Posted: Wed Jun 03, 2020 7:10 pm Post subject: Re: 2.2 Subaru Crankshaft Pulley |
That's a feature. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Franklinstower Samba Member
Posted: Wed Jun 03, 2020 7:39 pm Post subject: Re: 2.2 Subaru Crankshaft Pulley |
The early crank pulleys had an issue with coming loose causing key way damage. Which means a new crank. A tsb came out, increased the torque value of I remember correctly.
If your pulley is wobbling, get on it right away and don't drive until it's corrected....
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Wed Jun 03, 2020 7:55 pm Post subject: Re: 2.2 Subaru Crankshaft Pulley |
Franklinstower wrote: |
Paul |
The pulley was nice and tight to the crank, but the rubber appears to be in failure mode, it being hard as a rock. I had lost the bearings in the alternator and was looking for why it happened when I noticed the pulley wobbling a bit. I installed another one that I had of the same age but the rubber is more supple and it runs true, but want to find a low mileage one that is at least ten years newer. Lots of Subarus in our local wrecking yard but the dealer is a goodly number of miles away.
I had looked up the spec on the internet and seen the controversy on how tight the bolt should be. Went with the 135 ft*lb spec over the lesser ones. |
Posted: Wed Jun 03, 2020 8:36 pm Post subject: Re: 2.2 Subaru Crankshaft Pulley |
Wildthings wrote: |
Thumbs up, good news.... I should probably replace, or at least stock a newer pulley too. Mine is coming on 20 years old too. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Thu Jun 04, 2020 5:11 am Post subject: Re: 2.2 Subaru Crankshaft Pulley |
Zeitgeist 13 wrote: |
That's a feature. |
You're thinking of shakey TDIs. |
