scott3t Samba Member
Joined: July 06, 2014 Posts: 39 Location: Washington, DC
Posted: Thu Jun 04, 2020 11:33 pm Post subject: Scott3t 412 Restoration. Part 1 - Brakes |
This has been a long time coming. This initial introduction may be a bit long, but we'll get there, I promise. I'm starting the restoration of my 1974 412, 4 speed manual. It's been in the family since '76. I was driving it since about '87. Given to me from Mom in about '88. Garaged since '96. Last ran in 2001.
So why am I finally doing this? It's been a dream for many years. I remember talking my mom into buying it at the used car lot when I was a little kid. Numerous delays along the way, including the military and family, have pushed the timeline to now. And I've been reading this forum for four hours each of the past five nights. It is unbelievable the amount of expertise and resources here. Thank you all for that. It gives me the confidence that I can get the help necessary and confirms my feelings that I have a special car.
Since it has sat for so long, the car will need work in every area and on every system. I think the bones are overall good. It was maintained decently when it ran and [I think] is low rust. But there are a couple of rough spots/dents on the body from a minor tree scrape once and a minor telephone poll scrape another. We don't need to go there just yet...
Since the brakes were keeping me from driving it before I parked it (air leaks), I think I need to start there. And it if has to move along the way of restoration, perhaps it can be done a little more easily.
Challenge: I am splitting time between my primary house and our get away cottage two hours away. The car is in the garage at the cottage. But the telework option is in full force for my wife so we'll be spending a ton of time there this summer.
I've read some of the posts, but I'm sure not all the right ones. A couple that seem especially relevant are the "brake hydraulic parts reconditioning techniques" and the "... front caliper rebuild part 1 and part 2". And a recent note from Ray has pointed me in the right direction on some things.
So questions and comments:
1. I'll send initial photos this Sunday.
2. Where to start exactly? Front calipers was where I was going. But I don't know exactly what I'm going to find this weekend. For rear drum brakes, how easy is it to get new wheel cylinders and are there preferred options/vendors/sources? For the other rear brake parts, do I wait to see what I find or what do I already "know" to go buy?
3. Please send guidance on tools/parts/cleaners/solvents/oils you know I'll need. The car is 35 minutes from the parts store. And the parts store options are limited. So I'll be doing some of the parts/supplies buying in batches.
4. For eventual pressurizing and testing with air, how exactly is that done, and I think I need to get threaded couplers and caps for that.
5. Does it matter if I address front and or rear brakes before I look at the master cylinder?
6. Brake lines - i'll be having to replace some of these I think. Will assess with pictures this weekend.
7. What is the best way to support/block entire car while working on this? Right now I have the rear car on jack stands and the front tires on. Should I just put the whole thing on four jack stands and are there best practices with supporting without damaging?
8. Besides forums and numerous articles and weblinks on the D Jetronic Fuel injection, I have the Clymer manual, the John Muir book (How to keep your Volkswagen alive), and the Fuel injection technical manual (Henry Elfrink). Don't have the Haynes or Chiltons. The Haynes website actually shows the Chiltons when you select the 412 (air cooled '70-'81 repair manual, $25.50). Not sure why it doesn't have the ones I see on eBay (68-73 Haynes ~$20-25) or the old, vintage looking manual by J.H. Haynes (~$20-25). Do these refs exist easily online or I guess I'll want a copy of these as well...
Some of you have done numerous restorations, whereas this is my first. I'm a good learner. But please assume you can give me all the detail you want, as I won't take offense and need guidance. I'm smart enough to know there is a ton of stuff I don't know but I'm hoping the years of driving this car with some experience working on it and other cars in the past will get me through this. But it's a whole other world working on a car that has sat for decades and that doesn't have parts at the local auto supply store.
-Scott |
ClassicCamper Samba Member
Posted: Fri Jun 05, 2020 11:01 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Scott,
Welcome! I’m glad there’s someone else working on a resto of one of these cars. Cool background history about it as well. I have a lot of fuel injection parts for a 1974, so can help you out in that department.
For your brakes, I’d suggest getting your front calipers up to par. Sitting for 19 years and reading that it was parked due to a brake problem probably warrants starting there. I had a guy on the Type 3 forums (Jim Adney) recondition my calipers for a resonable price, and they never worked better. (Just a suggestion). Next, in the front, I would put the front rotors on a mic and make sure they still have meat on them and get a fresh turn on them if necessary. Once done, repack the bearings and remount the rotors. I believe Jim sends the calipers back with brand new brake pads on them. I have his contact info if you want to at least chat with him, he’s actually doing a fuel pump restore for me right now.
If you choose that route, you can sort through inspecting the brake lines for leaks, and replace as necessary. I blew out all my steel lines with air and it was pretty easy to find any bad areas.
Next, I’d absolutely replace all of the flexible rubber lines in the front and the rear and buy new rear wheel cylinders, most likely, the bleeder valves will be rusted closed, anyway. Also, check the drums out and see if they need to be turned and buy fresh shoes/hardware.
I’m taking a rough guess here, but all of that work, the parts, and machining will cost around $400-500. But, your brakes are important and need to be done right.
At least, that is how I did my car and it seemed to work fine. The brakes were toast and everything needed to be replaced (even the lines that go from the master cylinder to the brake reservoir).
After I did all that, and replaced a small section of steel line under the steering wheel and bled the system, the brakes pumped right up. My master cylinder seemed to be ok, it held pressure and I had no brake fade.
Im sure there are many ‘good’ ways to approach this, but that is how I did mine and my brakes still work great. Don’t need much pedal effort to stop the car at all.
Again, welcome and hope this gave you a general start. I didn’t answer all your questions point by point, but hope this will give you a general way to tackle this. Looking forward to seeing pictures of your ride!
Ron _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Sun Jun 07, 2020 7:47 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Ron,
Great info thanks. Yes, I would like to talk with Jim. I'll PM you to get his contact info. I agree about starting with the calipers so that is the route I'm planning. I'll also start working the rear brakes as feasible while working the caliper issue.
I got a better look today at everything. It looks like there is more rust than I thought and the body is a little rougher than I thought. But it is what it is. Hopefully not too big of an issue.
I'm trying to determine best/correct way to support car with all four wheels removed. And looking for comments from pictures below.
Pictures are below...
This is the car. Ground zero.
Master brake cylinder
Left rear brakes
Left rear
Left rear
Left rear
Right rear
Right rear
View from the right rear brakes
Right rear brakes
Right rear brakes
Brake lines - view from right rear
Brake line junction - view from right rear
Front left wheel
Front left - inside view
Front right wheel
Front right
Front right
Front jack stands.
What is best way to support entire from portion of car with all four wheels removed? I have the jack where the track control arm attaches to the front axle carrier. But what part is the most strong and stable for the jack stands? Or do I make a support bridge with 2x4s somewhere else?
Rear portion of front axle carrier
Under driver's seat. Rust.
Under left rear passenger seat. Rust.
Under car from rear view.
Plenty more pictures available but will save for another day. |
raygreenwood Samba Member
Posted: Mon Jun 08, 2020 10:31 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
I dont have much time today but a few things:
1. All of the rear brake parts are type 3. So shoes, hardware, adjusters, hold downs....you can get.
2. Carefully check your rear wheel cylinders. If they have rust pits inside....just not worth the hassle. If they are clean.....you can rebuild them. You can get wheel cylinder kits....right now....in closeout from Rockauto for between $1.60 for Wagner, ahout $2.50 for EIS and about the same for NAPA. But...just a warning. I have not had a prohlem with extremely old wheel cylinder kits....rubber wise....but I just do not know. Wheel cylinder kits crom NAPA/United and EIS....mean those are very old kits.....like 20 years old.
There are more than a few vendors out there. You can get Centric or Raybestos cylinders new.... from Rockauto....in the $11 range.
3. Do not discard the rear drums. Lets look at them. Because....all that is available are Brazilian junk.
4. Do not turn your front rotors. Its just not worth it. You have enough rust that the amount you will have to take off will be enough to lose considerable mass. They will overheat and warp....if they are not already warped.
New....excellent quality rotors....are relatively cheap. You can get German made Sebro for about $67-69 each at PMB performance and Autohuaz AZ. You can get Raybestos or Centric from Rockauto....both quite good.....for about $15 less each
Ray |
Deanaha Samba Member
Posted: Tue Jun 09, 2020 3:53 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
You all are an inspiration to me! I had just decided to get the brakes on my 71 411 fixed. They work but the pedals go tot he floor at times- fluid level is up. So that is my starting point- to examine and ask questions. I am looking forward to reading the progress and see the pics
Thanks for sharing this adventure. |
Posted: Tue Jun 09, 2020 11:26 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Thanks for guidance Ray. I got the calipers off. So I won't turn the rotors. I'll measure them. I'm wondering if there is a possibility to clean them up or should I just go ahead and replace them. I should probably just replace them?
The Haynes manual shows a tool for removing the brake pads. Or making a little tool to do it. Is that "official" tool very helpful or what is the best way to do that moving forward? Or do you just make a hook with a piece of metal and pull from the hole where the pin was?
The brake lines actually look pretty decent and there wasn't evidence of leakage in the lines at the wheels. Looking at that now.
Deanaha, great you are inspired! The folks on here are great! Good luck and let us know what you do.
Here are calipers:
Left side
Left side
Right side
Next is looking at rear brake cylinders. |
Posted: Tue Jun 09, 2020 11:33 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
And one picture showing the brake rotor....
Posted: Tue Jun 09, 2020 11:34 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
It's awesome to see that you are making progress! You will be riding in her in no time! Keep plugging along.
Looking good. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Tue Jun 09, 2020 6:38 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
ClassicCamper wrote: |
Looking good. |
Yes!^^^^^^
As for your rotors...yes...they are toast. Understand...they already have some normal wear.c And...that rust has a lot of dimpling. By the time you turn those enough to get that all off and smooth......they re going to be thiiiiiinnnn.
If you can find someone to even turn them....they will run about $20-$25 each....a little less than half the cost of a new one.
Many shops these days...more so than in the past...will not turn old rotors that will end up close to minimum tolerance.....its not worth the warranty issue for how cheap new rotors are.
Just get new ones...but keep the old ones and their bearings around for a while. Until you get it ready to be actually driveable ...keep the ld rotors and bearings on it so the new ones do not rust.
So the calipers are probably going to be just fine. No you do not need a "tool". You can pull the outer boots and dribble in some penetrating oil. Put it on the bolts and inside and out on the bleeder screws now too.
You can "usually" use compressed air to blow the pistons out.
So first...soak in penetrating oil. Then remove the pads...push the pistons inward to get them cracked loose. More penetrating oil. Then with a block of wood between the pistons.... about the same thickness as the two pads stacked together...or just use the old pads....put about 75 psi of air into the inlet.
For Gods sake keep your fingers out of the way.
If they only move a little....more penetrating oil...and squeeze them inward again with a "C" clamp. Air pressure again.
Usually you get both moving a little and you can just put one pad between them...and then one gets stuck and the other pops out.
When that happens...clean off the piston that popped out....and clean out its bore....put some oil in it....squeeze it back in....and then clamp it with a 6" C-clamp. Hit it with air again and usually the other piston will now pop loose.
If they get REALLY stubborn.....you can connect a flexible grease gun hose into the fluid inlet....and literally pump them out.
If you have not read this....it should help.
https://www.thesamba.com/vw/forum/viewtopic.php?t=658176
Rockauto has Centric Repair kits for $25.95 per caliper.
https://www.rockauto.com/en/catalog/volkswagen,197...r+kit,1720
These are excellent kits....for that price because they are generally repackaged FAG brand German made parts. They also come with new caliper bolts and locking plates. The only thing they do not have is the caliper half/bridge seals.
So...I am kind of torn. Those kits are excellent because they have hardware other kits do not.
But....PMB Performance has caliper kits with all the hardware (except springs and pins)...AND...they have teh caliper half seals as well.
Right now....I can only find the listing for the 70-72 (411) caliper kits on their site.
https://www.pmbperformance.com/catalog/item/1925563/4747234.htm
But...if you call them and ask they should have the Aug 72 and on kits as well. If not you can see if they can sell you the small seals separately and buy the kits from Rockauto.
Ray |
Danno5 Samba Member
Joined: March 19, 2016 Posts: 63 Location: Leavenworth, KS
Posted: Fri Jun 12, 2020 10:02 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Hey, welcome Scott. I won't have much to chime in here, my 412's brakes are in good shape so I just wanted to say hi. Awesome that you have a 4-speed! A rare bird. |
Posted: Sat Jun 13, 2020 11:17 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Hello all, I'm still plugging and chugging even though no updates posted this week. I appreciate the comments Danno5, Ray, ClassicCamper, etc. I'll update status of everything soon but a couple questions to keep things moving forward...
I wasn’t able to get the master cylinder out before having to leave the car a few days for work and family. Ray, you were looking to do some plating of some master cylinder bores and clutch slave and master cylinders last summer. Did you get all that done or are you looking for any to add to a group to do that [again]? By the way, I got a NOS clutch slave cylinder in February 2007 off of eBay but am only now finally doing all the work.
Is the best way to rebuild the type 4 master cylinder still to get a type 3 rebuild kit, take the seals, and reuse the type 4 hardware (assuming those parts are ok)?
Any need to replace the blue line from the master cylinder reservoir to the MC (unless it’s really loose when reconnecting to the MC)?
The metal brake lines look good right now – at least until I clean/pressurize and check. I’m getting the new rubber brake lines for the four short sections near each wheel. I assume they are all the same. Looks like these work – not sure if certain ones are preferred.
https://www.rockauto.com/en/catalog/volkswagen,197...+hose,1792
Prices between $5.10 to $11.06 each.
I am tracking at least some relevant posts on the master cylinder work…
Hydraulic parts reconditioning
Alternative Master Cylinders
The risks of NOS master cylinders
https://www.thesamba.com/vw/forum/viewtopic.php?t=679160
1973 master cylinder
https://www.thesamba.com/vw/forum/viewtopic.php?t=629103 |
Danno5 Samba Member
Posted: Sun Jun 14, 2020 3:10 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Scott,
I looked through some of your earlier posts in more detail and found something that Ray hasn't answered yet. Ray is the is the source of the answer though!
Your question:
My answer - Look about halfway through Ray's build on his 4-speed and you can see some pictures of the setup. He recommends going the support bridge route.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20 |
Danno5 Samba Member
Posted: Sun Jun 14, 2020 4:46 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Oh, and your first post had something on manuals. You have a lot of good ones. I would add these if you haven't already seen them:
The VW parts book for the type 4 -
https://www.volkswagen-classic-parts.de/catalogues/Typ4/html5.html#/1
Has a lot of good part explosion diagrams. Ray found this one first.
The Factory repair manual -
http://www.michaelknappmann.de/bulli/michaelk/vw_bus_d/reparat0.htm#67-74
The repair manual is all in german, but google translate does really good. It also isn't organized by car. You go by system and then you select the relevant car. The classic parts people at VW told me about this one.
The eberspacher BA-4 manual - https://www.type4.org/manuals/ba4/index.html.
This is for the gas heater behind your back seat. I think the manual is also on the samba, but this guy has it in a nice electronic layout. I used this in conjuction with a post from Ray where he gave a list of refresh steps for the heater to get it going again.
Dan |
Posted: Sun Jun 14, 2020 7:58 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Dan,
Good stuff -thanks! Yes, I remember seeing that part of Ray’s post with the wood support. Guess I’ll make that going forward because I assume it supports the body just rear of the axle carrier so I can also remove suspension parts. If I’m wrong here please somebody let me know.
Great on the ref manuals. I like those parts book diagrams. I really have nothing on part numbers. I also decided to go ahead and get the Haynes and Chiltons. They are on the way. I’ve had the John Muir book forever. Used it a ton on my old ‘63 VW bug (RIP, it got massively vandalized sitting on the edge of an old field of some farm property).
-Scott |
Posted: Mon Jun 15, 2020 8:14 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
scott3t wrote: |
Dan,
-Scott |
Yes.....its not just the wood support.
The wood support beam is a distance spacer. What is actually supporting the FRONT of the car.....are a pair of Harbor freight "dirt bike" motorcycle maintenance stands.
https://www.harborfreight.com/automotive/lifts-cra...67151.html
I agonized over these. On one hand I am a great proponent of Jack stands. But.....where to put them on a 411/412 that may be on them for a year or two.....especially when the entire suspension is coming off....the main reason the car will be on jack stands......which takes away most if not all of the places you could safely locate a jack stand.
And....even the best of jack stands....have poor footprint and stability.
So I saw these dirt bike stands. Rated at 1000 pounds each. I started calculating. Lets say thats less than accurate. Lets say....700 lbs?
The car weighs 2200 lbs with an engine and supsension in it....dry. I also planned to have only one end of the car at a time off the ground just for stability sake.
I also wanted to evenly spread the load to put less weight on any of the sheet metal. These bike stands are going.....as noted.....just about an inch or two rearward of the subframe and the lower drip rail rests on them.
Even though they have a thick rubber matt riveted on top.....I wanted to spread the load.
So...I got three 8 foot long 2"x 6" studs. I got ten 5/16" x 3" torx lag screws. I used five to lag bolt the first two boards together...and used the last five to lag bolt the third board to the other two......kind of a poor mans laminated beam.
I use this beam standing on its narrow edge with the 6" direction vertical. Tgey boards are stronger this way.....just like in a house cieling joist. This beam spans between the two motocycle stands. The stands are 18-20" high. The beam gives you right at 24".
The placement of the beam angles the nose up high.....so in the area of the front of the subframe.....you have about 36" minimum clearance under tbe spare tire well. I can sit under the front end on my rubber maid plastic stool and have my head up right in the middle of where the gas tank was.
To lift the car up this high....safely?
You need a good floor jack.....and jack stands to start. Fill the rear tires with air.....block them BOTH sides. Put on the parking brake.
Make a pair of blocks of about 1 foot long of stacked 2" x 6" board. Screw them together and screw a small block to it that fits in the round disk at the end of your jack so it cannot slide sideways. Make sure the jack is DEAD CENTERED with the sub frame and the jsck wheels are aligned so it rolls straight.
Make sure virtually everything is out of the trunk wo the car does not have a weight bias to one side.
Put the block of wood under the rear most bolt on the subframe...and jack slowly up to yhe max. The car should balance nicely. When you reach your limit....put jack stands under the corners of the car just rearward of the front fenders on that little cup shaped knob on each side.
Lower the jack....and attache a thicker block. When you get it up high enough for the comhine bike stand and beam.....remove the jack stands.....position the bike stands......and with help....left the beam and slide it in. Then lower the jack. Ray |
Posted: Wed Jun 17, 2020 8:44 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Ray,
Thanks for detailed explanation. So I plan to get some more done on the front and rear brakes and then throw the rear wheels on and use this method to support the car for looking at the front suspension.
You said, "Put the block of wood under the rear most bolt on the subframe". I"m not sure what point you are talking about exactly. Can you clarify or post a pic of where the wood is supporting the subframe?
Do you like any of these brake bleeder kits at rockauto?
https://www.rockauto.com/en/tools/brake+&+wheel+hub,tool,brake+bleeder+tool,1000608
The length of tube looks very short. The local car parts place had a terrible selection (if any at all) of clear tubing. But I'm all about what makes the easiest job of bleeding the brakes.
-Scott |
Posted: Wed Jun 17, 2020 9:56 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
scott3t wrote: |
Ray,
-Scott |
Put the jack right where the purple circle is. The board will impress into the big washer and bolt and help hold it steady.
Hold off on on the bleeder kit. Really....pressure bleeding is best ...but the hoses between the MC and reservoir must be tight and new. I clamp them.
One of the issues with bleeding type 4 brakes is the very circuitous brake line system. It gets bubble bypassing inside. It can take several bleeding's. Part of the issue is that the bleeder valves need to be barely cracked open...1/4 turn. This way you have to build pressure to vent.
The stock bleeder valves tend to bypass air through the threads on the return stroke. If staying with the stock bleeder valves...I tend to seal the threads with Teflon tape.
Great money spent are these:
Speed bleeder valves #7100....same as Porsche 914
http://www.speedbleeder.com/autochart.htm
The chart
http://www.speedbleeder.com/size.htm
The sealant in the threads takes care of the leaks. Crack it 1/4 to 1/5th of a turn. Put a hose on it that fits tight...clear vinyl is fine...with the end submerged in fluid.
When just starting..leave the bleeder valve closed....pump up the brakes hard. Put a padded stick on the pedal against the front seat. Get out and just barely crack the bleeder open. Lots of air will pop out. Do this about 3 times. Then check fluid level. Then leave a speed bleeder cracked open about 1/4 turn and get in and just pump the brakes about 10 times.
When done and the pedal is on the floor...prop it there with the stick...then get out and close the bleeder. With this method...something as simple as this works well.
https://www.turnermotorsport.com/p-176959-turner-m...Z8QAvD_BwE
Ray |
Posted: Fri Jun 19, 2020 9:39 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Ah ok that’s what I was wondering. So actually putting the jack under the axle carrier.
I’m back at it this weekend. I‘ll take out the master cylinder and go from there. I’m waiting for some parts as well.
So as I work on the brake lines and rear brakes, I went ahead and sent my calipers for rebuild to Jim Adney from the type 3 posts. He is a big proponent of using Dot-5 Silicone break fluid. Has used it on dozens of cars over several decades and says it’s really good for cars that don’t drive daily because there is less corrosion and less need to rebuild parts.
Was wondering if any of you use the Dot-5? |
Posted: Sun Jun 21, 2020 10:39 pm Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Help! I hope somebody can tell me the answer to the mystery.
I have four different manuals that cover brake master cylinder removal. Three don't even mention disconnecting the clevis - I guess it's so inherently easy and obvious. But until somebody shows me what I'm missing, its the most difficult step. I have everything off or loose except this dang clevis pin. So I'm stuck.
Pulling the pin on the clevis, which it looks like I need to do, is extremely difficult because there is a big spring there that pulls the brake petal up after you push it. And it's really hard to get to. What is the secret?
Some pics below.
This shorter wrench made it easier to get to the brake line nut. Otherwise I had very little room to move the nut.
The spring locks in the clevis pin and is really strong.
The other end of the spring is hooked onto the plate very securely.
Just to show its not immaculate and easy. This is the real world. It made a big difference putting the boards down over the area under the seats so I didn't worry about stepping through the floorboard. And the padding made it possible to do this without hurting a neck or hip or knee.
[/u] |
Posted: Mon Jun 22, 2020 10:09 am Post subject: Re: Scott3t 412 Restoration. Part 1 - Brakes |
Ok rookie mistake. I got the master cylinder out. The books don't mention it because you don't have to mess with that clevis. The push rod isn't really connected to the MC but just pushes up against it I guess.
Moving on.... |
