jpeters Samba Member
Joined: May 06, 2005 Posts: 1025 Location: Woodsfield, Ohio
Posted: Sat Jun 06, 2020 7:09 am Post subject: Poptop Scissor Lift Mechanism Color |
I've disassembled everything for my pop top restoration. It seems that the original scissor mechanism hardware was just galvanized metal. Unfortunately, mine is rusted and pitted, has paint overspray, etc.
I'd like to do some rust prevention and then paint it, but what color? Just flat gray, metallic, nickel? Any suggestions? _________________ '73 Westy (dual stock carbs, SVDA w/ compufire)
'68 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=484180
'65 Westy SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=435614
'65 Bug
'63 Bug
neverdnf on Instagram |
Clara Samba Member
Posted: Sat Jun 06, 2020 9:13 am Post subject: Re: Poptop Scissor Lift Mechanism Color |
Can you get yours re-galvanized?
I was restoring, I would want it to look like original.
from gallery, pics I took:
Almanor23 Samba Member
Joined: November 20, 2019 Posts: 27 Location: SF Bay Area
Posted: Sat Jun 06, 2020 10:14 am Post subject: Re: Poptop Scissor Lift Mechanism Color |
Eastwood makes a lot different spray can paints to mimic the color of metal.
Here is one option:
https://www.eastwood.com/por-15-detail-aerosol-paint-stainless-41818.html
If you check their website, you might find a direct galvanize replication. Also, depending on where you live, you might find a plating shop that can dip it for you. |
Posted: Mon Jun 08, 2020 4:59 am Post subject: Re: Poptop Scissor Lift Mechanism Color |
I ended up finding some gray/silver epoxy appliance paint at the local hardware store. Turned out pretty good. Will wear on some of the moving parts, but I think anything else would also. Replaced everything with stainless hardware while I was at it.
For comparison:
'65 Bug
'63 Bug
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Jun 08, 2020 11:32 am Post subject: Re: Poptop Scissor Lift Mechanism Color |
I like it. The one on the right looks pretty decent too. |
