ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Tue Jun 09, 2020 6:42 pm Post subject: 40H flywheel shims |
Anyone have a lead on 40H flywheel shims? I actually ordered a bunch from S&S Aircooled parts , they had them advertised as 40h shims but they were the same shims that go on cranks from 1500 to 1600. I called them and they said the ones I ordered were for late 40H. This is my first 40H rebuild I did not realize their was a difference between late and early 40, but what is really strange is that the ones I received are the same size as the ones for a later 1600 so it confuses me as to why they are even listed as 40H. But I am kind of stuck right now he says no one makes an early 40H shim, any ideas as what to do? Thanks _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
creideahm Samba Member
Joined: March 30, 2014 Posts: 134 Location: Pittsburgh
Posted: Tue Jun 09, 2020 7:38 pm Post subject: Re: 40H flywheel shims |
What sizes do you need. I have some. _________________ Stay calm and Bug-on |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Tue Jun 09, 2020 8:00 pm Post subject: Re: 40H flywheel shims |
Try Bus Depot. They list them as 1200-1300 shims because the early 1300's were the same as 1200 40hp. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Jun 09, 2020 9:55 pm Post subject: Re: 40H flywheel shims |
For USA 40HP models there WAS not a difference in flywheels shims between early and late. The only real breaking point was the November 1964 change to short stud heads, (nothing to do with the crank) and by Aug 1965, the 1200/40HP SAE engine was no longer sold in the USA. The change to different endplay shims lines up with the lengthened shoulder on the crankshaft for the O-ring flywheel and that happened around 9 months after the 1200 engine stopped being sold in the USA market.
As mentioned above, if you want early and late for USA models, look to the 1300 engine.
_________________ Andy T.
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Tue Jun 09, 2020 11:42 pm Post subject: Re: 40H flywheel shims |
I only had my hands in one 40 horse. It was probably almost 10 years ago and couldn't source any. I ended up ordering "good used" from flea bay. This has been discussed before. I'm surprised a good source isn't available.. maybe the vintage speed guys know where to get some? |
Posted: Wed Jun 10, 2020 4:11 am Post subject: Re: 40H flywheel shims |
DM me _________________ Stay calm and Bug-on |
Snort Samba Member
Posted: Wed Jun 10, 2020 7:15 am Post subject: Re: 40H flywheel shims |
ConcreteAce wrote: |
Snort wrote: |
yowzer its gotta be a misprint $88.35 for just one
https://www.busdepot.com/113105285 |
Here is one for $2.09
https://www.busdepot.com/113105283
A phone call would be in order. |
Posted: Wed Jun 10, 2020 8:52 am Post subject: Re: 40H flywheel shims |
I actually ordered a couple of those. but by my measurements I am going to need the larger shims. creideahm is actually helping me out with some shims. I mainly ordered them (they have the 30 and 24 at about the same price) to see if they are even the right size. LOL the shipping was 13 and the shims were 14. If they are the correct size I will probably order a few to keep on hand for the next time. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Wed Jun 17, 2020 4:22 pm Post subject: Re: 40H flywheel shims |
Well so I got the shims in from the busdepot. They are the same size as the ones from S&S which are to small to fit over the step in the crank. Luckily creideahm has hooked me up with an assortment of sizes so I can get the end play set. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Thu Jun 18, 2020 2:19 pm Post subject: Re: 40H flywheel shims |
That is also a problem for us in Germany, there is not one online shop that has the right shims for early 40hp listed. |
Posted: Thu Jun 18, 2020 3:12 pm Post subject: Re: 40H flywheel shims |
The parts/service shop I used to work at in Fort Collins, CO, VRBA'S PARTS, I remember that we had some of those early/6V flywheel shims. I just called up Brian, the owner, and he says he's still got some of them and I mentioned why I was asking. You might try him. 970-484-2011 _________________ Andy T.
RWK Samba Member
Posted: Fri Jun 19, 2020 4:55 am Post subject: Re: 40H flywheel shims |
Anyone have the OD and ID? I have several sizes don't know whats what, might be nice to know. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Wed Jun 24, 2020 10:46 am Post subject: Re: 40H flywheel shims |
glutamodo wrote: |
The parts/service shop I used to work at in Fort Collins, CO, VRBA'S PARTS, I remember that we had some of those early/6V flywheel shims. I just called up Brian, the owner, and he says he's still got some of them and I mentioned why I was asking. You might try him. 970-484-2011 |
Hey Andy, Thanks for making that call. I was able to get the proper endplay set with the shims creideahm sent me. So I am good to go. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Wed Jun 24, 2020 7:34 pm Post subject: Re: 40H flywheel shims |
Glad you got it sorted out.
Brian said he still had what I recalled, mostly NEW shims, by the way! _________________ Andy T.
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Jun 24, 2020 7:54 pm Post subject: Re: 40H flywheel shims |
… Bughaus has 'em in various thicknesses - 24, 30, 32, 34, 36mm = $2.945 each. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Wed Jun 24, 2020 8:42 pm Post subject: Re: 40H flywheel shims |
Cool. Are they verified for the correct I.D.? _________________ Andy T.
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Jun 25, 2020 7:53 am Post subject: Re: 40H flywheel shims |
No, Bughaus only has the later shims, not 40hp shims.
That's the point, no one is making 40hp shims anymore and they are hard to find.
The ones with the A suffix on the part number are the later shims, not 40hp. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
