charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Wed Jun 10, 2020 8:10 am Post subject: coolant junction upgrade |
hey all, im about to start my watercooled conversion, and studying the coolant diagrams:
looks like i need to grab a coolant junction for the rear.
should i just get the std plastic one? or are there upgrades or opinions about this? |
jlrftype7 Samba Member
Posted: Wed Jun 10, 2020 8:20 am Post subject: Re: coolant junction upgrade |
I believe both the 1.9 and the 2.1 have choices of standard or Metal Upgrades now. I have the 1.9 and went with the Metal Hose Junctions front and back for my engine. I'm guessing you have the later 2.1 engine? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Wed Jun 10, 2020 8:24 am Post subject: Re: coolant junction upgrade |
Hello there!
Converting from which to what?
I assume you're talking about the coolant tower, or cooling junction:
(source: Van Cafe website)
Van Cafe sells a stainless steel version, which I've seen strongly recommended on the forum:
https://www.vancafe.com/KT-1982103-p/kt-1982103.htm _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4025 Location: Redwood City, California
Posted: Wed Jun 10, 2020 8:51 am Post subject: Re: coolant junction upgrade |
The plastic ones are fine. The SS is nice it just depends on how you are financially.
Buy the plastic one and with the money you save take your computer and have the the Caps key fixed. Caps are used in a sentence so that the reader knows when you begin a new sentence.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Wed Jun 10, 2020 9:05 am Post subject: Re: coolant junction upgrade |
I am converting from nothing to something. Im building the whole cooling system out myself.
So when it comes to this junction, looks like I will only need 1 in (head) and 3 out (thermostat, heater loop, radiator).
Im undecided, but thinking of an EA288 TDI |
Posted: Wed Jun 10, 2020 9:09 am Post subject: Re: coolant junction upgrade |
16CVs wrote: |
Stacy |
h8r |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Wed Jun 10, 2020 9:26 am Post subject: Re: coolant junction upgrade |
It has 2 "In" ports, not 1. That junction is only for VW waterboxer engines. The hose to it from the thermostat is really from left side cylinder head, so the junction combines the hot coolant from the 2 heads and sends it to the radiator.
Mark
charleslabri wrote: |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Wed Jun 10, 2020 9:39 am Post subject: Re: coolant junction upgrade |
The “to something” has to be defined to know what you need. For example, I have a in-line 4 (1.8T) which eliminated the plastic coolant tower in the pic above.
Also, from “nothing” should be defined, I’m assuming you are taking air cooled, so there’s no coolant system - is that correct? _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Wed Jun 10, 2020 9:48 am Post subject: Re: coolant junction upgrade |
The top diagram has a pretty big problem.
The purple hose shows an arrow going toward the thermostat housing but that is only when the engine is cold.
Once the thermostat opens the flow reverses had HOT coolant comes from the left head through the purple hose to join the hot coolant from the right head.
If you think about it you should get that both heads get hot and the small hose from the right side head isn't large enough for all of the hot engine coolant to go to the radiator.
Mark |
Posted: Wed Jun 10, 2020 10:38 am Post subject: Re: coolant junction upgrade |
ok, so to answer a couple questions:
TO: likely an EA288 TDI, boxeer probably. Greg said that the standard 2 lines running into the bay would work fine for the hookups.
Anyone have a coolant diagram from a stock WBX? |
minsk Samba Member
Joined: March 17, 2008 Posts: 899 Location: pittsburgh
Posted: Mon Jun 15, 2020 1:27 pm Post subject: Re: coolant junction upgrade |
anyone have any pics of:
1. where the junction is mounted on the vehicle in the rear
2. where the thermostat is mounted in the rear
3. where the pipes come out into the engine bay for the heater and the rad cooling lines? |
Posted: Mon Jun 15, 2020 2:00 pm Post subject: Re: coolant junction upgrade |
Inline VW engines have different needs than waterboxer engines.
What engine have you decided to use?
Mark |
Posted: Mon Jun 15, 2020 5:03 pm Post subject: Re: coolant junction upgrade |
boxeer VW EA288 TDI.
Greg specifically said i should bring them back into the compartment just like the WBX, but.. i just dont know where those enter in the WBX setup |
Posted: Tue Jun 16, 2020 1:50 pm Post subject: Re: coolant junction upgrade |
so.. not many folks out there run stock '87 vanagons that can take a pic of where the coolant lines hit the engine bay and where the coolant junction is mounted?
ok |
Posted: Tue Jun 16, 2020 1:59 pm Post subject: Re: coolant junction upgrade |
Your proposed engine only has 1 head.
The boxer coolant junction isn't for you.
It is to allow the hot coolant from the left side head to join the hot coolant from the right side head so the joined coolant and go together to the radiator.
Search in the Samba photo gallery for photos of what you want to see.
That is what I do when I need details of things.
Mark |
SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Tue Jun 16, 2020 2:07 pm Post subject: Re: coolant junction upgrade |
ok |
Sorry, I'm at work now and actually don't like to be on a screen after I leave. But, I can tell you the coolant junction is mounted to the front of the firewall (on the opposite side of the where the engine is) in the passenger side rear wheel well.
I can't remember where the various hoses enter the engine bay but I'm sure you can google some photos. Maybe try some of the 2WD WBX build threads on this site. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Tbob Samba Member
Joined: May 26, 2007 Posts: 417 Location: Pensacola, Fl.
Posted: Wed Jun 17, 2020 3:32 am Post subject: Re: coolant junction upgrade |
Listen to the crazyvwvanman. Take that coolant diagram and ignore literally everything in the engine compartment. Since you are doing an inline conversion, all you will need is the main cooling pipes from the front to the back, and depending on what kind of heater you use, heater hoses to your heater. No coolant towers, no bleeder ring, no separate thermostat housing. No hoses, then, to any of that non existent stuff.
For hoses front to back, I used stainless pipes for my stock 1986. Then, the rest of the cooling system was modeled after the old Tiico conversion that put a 2.0 liter Inline in place of the waterboxer. There should be pictures of Tiico conversions in the gallery. Also, Foreign Auto Supply in Harpswell, Maine is the torchholder for these conversions, look at their website. And look op VanagonNuts posts, iirc, he did an inline conversion using standard hoses and custom fittings so he could find a replacement hose anywhere if he blew one. If no one else posts a picture of the routing of the hoses for a conversion, I can within a couple of weeks, as I am on the road and will not be near my van with the conversion until then. Also, the block you are using may need some different plumbing than mine, Greg at Boxeer can guide you, but either way, all you will need is the hoses going front to back. Nothing else from the waterboxer will help you. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
Posted: Wed Jun 17, 2020 12:50 pm Post subject: Re: coolant junction upgrade |
cool. thanks all.
I had never thought of looking at the pics in the forum. I always hated the overclassification when uploading pics- now im thankful.. |
