malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Wed Jun 10, 2020 6:35 pm Post subject: type 4 Compression Ratio calc question |
I am shooting for 7.3 CR. To get there I need 0.075" deck height. That is out of spec. My searching here tells me that too much deck height can cause engine problems, poor mileage, etc....
The heads are Camper Specials with a 55.2 total cc. The pistons have a 10 cc dish. 2.0 engine.
As the picture above says: 0.065 deck height would be at the top of optimal range and the CR would be 7.4.
Are all my numbers correct? Any ideas to get me to 7.3 and stay in deck height optimal range?? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Wed Jun 10, 2020 6:43 pm Post subject: Re: CR calc question |
You might want this in the Engine forum. If you do, PM me and i'll move it. _________________ Glenn
Member #1009
#BlueSquare |
SGKent Samba Member
Posted: Wed Jun 10, 2020 6:45 pm Post subject: Re: CR calc question |
These were an engine I built that runs fine and smogs legal as well.
Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4
Chamber 49 cc 49 cc 49 cc 49 cc
Piston Dish 11 cc 11 cc 11 cc 11 cc
Deck 0.105 0.105 0.105 0.105
Bore 94 mm 94 mm 94 mm 94 mm
Stroke 71 mm 71 mm 71.mm 71.mm
Calc comp 7.3 7.3 7.3 7.3
Spacer 0.071 0.071 0.071 0.071
who cc'd the heads and was the step part of that measurement?
Are you measuring the pistons at the wrist pin at TDC?
Are the cylinders bolted down with a plate or something like this?
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Wed Jun 10, 2020 6:51 pm Post subject: Re: CR calc question |
I am guessing that Hoffman CC'd the heads. Cause someone used a sharpie and wrote on a very special piece of paper in big letters..... 55.2
yes, I bolted the cylinder down. If pictures were not such a bitch to add, i would show you..... I have a magnetic mount just like you, but mine is black.
So let's assume I did it exactly like you would have..... now can you help? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Wed Jun 10, 2020 6:55 pm Post subject: Re: CR calc question |
Posted: Wed Jun 10, 2020 6:59 pm Post subject: Re: CR calc question |
so your 0.105 deck height vs. my 0.075.... All will be well? Why are you ok going over spec and out of optimal?
I am assuming that you measured the CC's on the dish? Cause the published CC on my pistons is 10. If mine are also 11, I am creaping toward 0.06.... _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Wed Jun 10, 2020 7:07 pm Post subject: Re: type 4 Compression Ratio calc question |
double post _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
airschooled Air-Schooled
Posted: Wed Jun 10, 2020 7:36 pm Post subject: Re: type 4 Compression Ratio calc question |
If you're confident in your measurements, I would run it. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Wed Jun 10, 2020 7:49 pm Post subject: Re: type 4 Compression Ratio calc question |
asiab3 wrote: |
If you're confident in your measurements, I would run it. |
what is your thought on deck height on the high side?
The more i putz with calculator, the better everything looks.
the accuracy of the calculator could be fine tuned a few decmial places on all cells. deck at 0.066 = 7.3 0.065 = 7.4 _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Wed Jun 10, 2020 8:03 pm Post subject: Re: CR calc question |
.075" with a .030" step is the same as a deck of .105" on the smaller combustion chamber number of 50.2cc.
My heads have the step cut out, yours don't. The difference between 7.3CR and 7.4 CR is nothing in the world of power or efficiency. You'll want to choose based on a good steel shim set that is available. I'd run 7.4 if that is what your shims give you.
In other words - if one shim set gives you 7.1, and the next gives you 7.4, and the next gives you 7.8, run with the 7.4 on a 2L. Type one buses I would be comfortable at 8.0:1. Not on a 2L bus. 2L Porsche yes. 411/412 yes, but not on a bus because of the heat at freeway speeds. Around town and up small hills around town, sure. Sustained freeway, especially in the heat of summer - no.
Here is the reason I don't care about performance as one thinks of it in a bus engine. I care more about longevity. It is a different thinking cap. Bus engines get beat to death on long freeway drives.
. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Wed Jun 10, 2020 8:05 pm Post subject: Re: type 4 Compression Ratio calc question |
I am enjoying .065” on my Type 1 these days.
Realistically, no human being will feel a .2 difference in CR in a stock Volkswagen bus.
Robbie
PS- a bay bus has a lower drag coefficient than a bug _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Wed Jun 10, 2020 8:29 pm Post subject: Re: type 4 Compression Ratio calc question |
asiab3 wrote: |
Robbie
PS- a bay bus has a lower drag coefficient than a bug |
good to know. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Wed Jun 10, 2020 8:41 pm Post subject: Re: type 4 Compression Ratio calc question |
asiab3 wrote: |
True - but a bus has more frontal area, thus more drag. Drag coefficient is the ratio of the two. Thus, a bus needs more power to push through the air than a bug, at the same speed. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
SGKent Samba Member
Posted: Wed Jun 10, 2020 10:29 pm Post subject: Re: type 4 Compression Ratio calc question |
telford dorr wrote: |
asiab3 wrote: |
True - but a bus has more frontal area, thus more drag. Drag coefficient is the ratio of the two. Thus, a bus needs more power to push through the air than a bug, at the same speed. |
hence why my 71 1600 dp bus when it was with a totally stock engine topped out about 75 -76 mph vs my dad's 62 stock Beetle 1200 that topped out about 100 mph - flat and level. Put a bus into a headwind and see what happens to the speed... . _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jun 11, 2020 6:59 am Post subject: Re: type 4 Compression Ratio calc question |
OK let's say I am gonna shoot for 0.069 deck height. That is gonna require a shim.
The gasket kit came with what I suppose are sealing rings. They are ~0.008" thick. What is best?
1. Use the sealing ring and a 0.030 barrel shim
2. Don't use the sealing ring and use a 0.040 barrel shim _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Thu Jun 11, 2020 7:30 am Post subject: Re: type 4 Compression Ratio calc question |
you use 1 shim at the base. They cannot be stacked. No sealing ring at the top. Without knowing what measurement you are getting above the cylinder wrist pins now, it is impossible to know what size to put at the base. What is your measurement with no shim? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jun 11, 2020 8:10 am Post subject: Re: type 4 Compression Ratio calc question |
Cylinder lightly wrench tightened, and no shim under the barrel, piston at TDC, I get 0.027”.
Just like Tom Wilson’s book, I slid feeler gauges under a ratchet extension in several places. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Thu Jun 11, 2020 8:43 am Post subject: Re: type 4 Compression Ratio calc question |
if your goal is .069" then you would need a .042" shim. .027" + .042" = .069". Do the measurement above the wrist pin to prevent the piston from rocking.
But you won't find a .042" shim. Your choices will be .040" or .050". A .040" will give you 7.39:1. A .050" will give you 7.25:1 which when everything tightens will probably be 7.3:1. Either would be fine. The "compressed gasket thickness" below is the step. It is nice to see you so involved in your engine build. In general. I'd say that the average engine build standard here in the Bay forum has greatly improved with engine builds where one pays attention to small details. 10 - 15 years ago many were just buying crate motors from folks who did marginal work.
Posted: Thu Jun 11, 2020 9:07 am Post subject: Re: type 4 Compression Ratio calc question |
So what is the deal on not stacking shims?? I have read some posts with folks putting multiple shims. Others say multiple shims can give you another place for a leak. Is that your reasoning? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Thu Jun 11, 2020 10:05 am Post subject: Re: type 4 Compression Ratio calc question |
malcolm2 wrote: |
So what is the deal on not stacking shims?? I have read some posts with folks putting multiple shims. Others say multiple shims can give you another place for a leak. Is that your reasoning? |
you do not stack shims. It will compromise the seating of the cylinders. You buy the shim set that you need if you lack the proper ones.
Have you ever read this? I use a steel shim but the factory called for an aluminum shim. http://kentcomputer.com/77VW/techbull.pdf
