epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Thu Jun 11, 2020 3:04 am Post subject: Advice on small dremel metal cutting wheels |
Hi Folks
I need to do some fine metal cutting ( 0.5 - 1.0mm thickness metal) - and my grinder is just too big for such fine metal cutting...
I am thinking to use my dremel, but the little red metal cutting disks are way too brittle and fragile.
So I am thinking to buy some of these bigger blades https://www.pricemania.sk/rezne-kotuce/dremel-dsm540/
Does anyone have experience with these? They look good, but I think I would need also to buy the adapter which holds them, no?
https://www.youtube.com/watch?v=y7Uugwya0_8 It's not clear whether or not you must buy this adapter extra...
Thanks
Ed _________________ www.edwardpowell.com |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24376 Location: NYC/Upstate/ROW
Posted: Thu Jun 11, 2020 3:23 am Post subject: Re: Advice on small dremel metal cutting wheels |
Iβve cut M10 hard steel bolts with those reinforced Dremel wheels
They are excellent. The bayonet mount is a but expensive but excellent vs fussing with that stupid little screw. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 560 Location: Grove City, OH
Posted: Thu Jun 11, 2020 4:34 am Post subject: Re: Advice on small dremel metal cutting wheels |
I also once used the little red ones and would break 4 before I was able to cut through anything. I switched the metal with diamond version a few months ago and never looked back. I'm using the Harbor Freight equivalent with my Dremel since they are so much cheaper (and no bayonet mount) but I would guess there's no Harbor Freight in Czechoslovakia. _________________ '74 Thing
'83 Westfalia |
Posted: Thu Jun 11, 2020 4:38 am Post subject: Re: Advice on small dremel metal cutting wheels |
I have used those little red cutting wheels and used individually they break in 5 seconds. I saw a video recommending to double them up --- I tried that and when used carefully actually work very well that way. Not much breaking at all.
I found some insanely cheap sets of these red ones, and ordered about 100psc, for about $5! ....so let's see how these work. _________________ www.edwardpowell.com |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1520 Location: Wisconsin
Posted: Thu Jun 11, 2020 5:21 am Post subject: Re: Advice on small dremel metal cutting wheels |
From looking at your links, it seems to me that the Dremel EZ Lock system uses a proprietary-shaped hole in the cutting discs, and a corresponding shaped 'peg' on the mandrel.
The disc to which you linked is NOT an EZ Lock, but instead uses a standard round hole; so it would likely use a standard round mandrel. Be sure to confirm hole diameters match before buying & using.
FWIW, I've used standard Dremel fiber-reinforced cutoff discs for countless small jobs and have never broken one:
https://www.grainger.com/product/3W842 _________________ Camp Westfalia
Camping Tips β’ Newsletter β’ Cool Campervan Apparel
www.CampWestfalia.com |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17297 Location: Brookeville, MD
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10131 Location: Where?
Posted: Thu Jun 11, 2020 9:51 am Post subject: Re: Advice on small dremel metal cutting wheels |
Fiber-reinforced cutting discs work very well. Unless you are pulling down a very high wage or there is a state of emergency where an added couple seconds could mean your life, the EZ-lock discs are not worth the extra cost. Not even close. It only takes a few seconds to replace the normal fiber-reinforced discs that have a screw in the middle but the cost is way less. More recently I purchase some of the super-cheap ones off ebay.
https://www.ebay.com/itm/60pcs-Mandrel-Fiber-Glass...Sws65dyNWg
On inspection, their manufacture is less precise than the actual Dremel wheels but they seem to work fine. The price per wheel makes them the clear winner for cost per job completed. YMMV.
That's SIXTY wheels for $9.66 vs. FIVE for $14.98 in the link djkeev just posted! 16 cents per wheel vs. THREE DOLLARS!
khughes Samba Member
Joined: July 13, 2013 Posts: 914 Location: Phoenix AZ
Posted: Thu Jun 11, 2020 9:55 am Post subject: Re: Advice on small dremel metal cutting wheels |
Indeed, I've cut tons of stuff with these EZ-lock reinforced discs. I used them to cut away and shape the oil pan mounting boss (for oil return clearance) when I installed my turbo. Pretty amazing actually, and well worth the $$. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Posted: Thu Jun 11, 2020 10:16 am Post subject: Re: Advice on small dremel metal cutting wheels |
| epowell wrote: |
I found some insanely cheap sets of these red ones, and ordered about 100psc, for about $5! ....so let's see how these work. |
This sort of post reminds me of how stupid I am
What a simple, great idea. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2408 Location: Adobe Jungle USA
Posted: Thu Jun 11, 2020 10:41 am Post subject: Re: Advice on small dremel metal cutting wheels |
The Dremel EZ-Lock cutters work well for all sorts of fine cutting, but follow these three instructions. Go slow and donβt push too hard, because the center will pop out under too much pressure. Prevent the disc from getting too hot by having a spray bottle on hand, stop regularly and spray the disc to cool it down. Also try to cut at 90ΒΊ because side pressure builds up heat FAST and the glue will break apart. Doing this, the EZ-Lock cutters last a LOT longer. _________________ Vanagon β83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
0cean Samba Member
Joined: February 29, 2012 Posts: 1153 Location: California
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12410 Location: Santa Cruz, CA
Posted: Thu Jun 11, 2020 11:02 am Post subject: Re: Advice on small dremel metal cutting wheels |
That is a tile cutting blade. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10518 Location: Sunshine Coast B.C.
Posted: Thu Jun 11, 2020 12:11 pm Post subject: Re: Advice on small dremel metal cutting wheels |
One main reason I finally wore out my Dremel was due to use of the EZ metal cutting discs. I used the Dremel a lot for that purpose.
Wear face protection. It's a small tool but the Dremel with that disc will grab. Use both hands but try to keep the vents on tool open.
Neil.
_________________ 1981 Westy DIY 15ΒΊ ABA
(VW Gas I4)
1988 Westy DIY 50ΒΊ ABA
VE7TBN |
Posted: Thu Jun 11, 2020 12:21 pm Post subject: Re: Advice on small dremel metal cutting wheels |
5 of my 6 girls report they work well for dismembering toxic males; I had to buy six Dremels but at least get the bits in bulk _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Thu Jun 11, 2020 12:30 pm Post subject: Re: Advice on small dremel metal cutting wheels |
| 0cean wrote: |
2nd on this tool... the screw-on disks will spin and loose cutting ability. |
If that happens it is simply due to operator error. Never happens to me. |
Posted: Thu Jun 11, 2020 12:46 pm Post subject: Re: Advice on small dremel metal cutting wheels |
Thanks for all of these amazing replies - I wish I had asked years ago. Trying to do complicated body work with only a grinder for cutting out rust is not practical.
Currently I actually need these small bits for cutting thin metal fingerboards on my guitars, but thank God there is so much overlap between guitar building and vanagon repairing  _________________ www.edwardpowell.com |
4Gears4Tires Samba Member
Posted: Thu Jun 11, 2020 1:33 pm Post subject: Re: Advice on small dremel metal cutting wheels |
I have never experienced the discs spinning on the screw either. I don't even see how that would happen with the red discs, they are so fragile I would think the amount of force required to stop it from spinning would cause it to explode. I must be very gentle on the pressure with the fiber discs compared to you monkeys!
The fiber reinforced discs are great for cutting steel. I never use the red discs for anything hard, soft metals and plastics only. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
