Insulating the heat tubes
Dan2973
Dan2973 is offline
PostPosted: Thu Jun 11, 2020 6:25 am    Post subject: Insulating the heat tubes Reply with quote
Insulating the heat tubes. Was just wondering what you guys use to wrap around the heat tubes under the rear seat? I used silver foil duct tape to make sure I covered any gaps but what else do you guys use to insulate them?
ZEKE65
ZEKE65 is offline
PostPosted: Thu Jun 11, 2020 6:53 am    Post subject: Re: Insulating the heat tubes Reply with quote
I used Heatshield Products hook and loop Thermaflect sleeve.
https://www.heatshieldproducts.com/thermaflect-sleeve-velcro
1965 VW Sedan, 1968 C10 Step BB, 99 C5
Schnitzelfuss
Schnitzelfuss is offline
PostPosted: Tue Dec 10, 2024 6:30 pm    Post subject: Re: Insulating the heat tubes Reply with quote
Apparently the factory used insulated padding and burlap and some sort of cover is required https://www.thesamba.com/vw/forum/viewtopic.php?t=743028&highlight=rear+seat+heat
I need both sides for my 1966 restoration, used ones in decent shape are hard to find here in the US. I found a picture of a new one sold by Heritage and noticed they are perforated- I can’t figure out why? Seems to me to be a flawed design but maybe I’m missing something?
rcooled
rcooled is offline
PostPosted: Tue Dec 10, 2024 7:34 pm    Post subject: Re: Insulating the heat tubes Reply with quote
Schnitzelfuss wrote:
Apparently the factory used insulated padding and burlap and some sort of cover...
This is the original factory padding in the rear seat area of my '63 Beetle.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
meranda
meranda is offline
PostPosted: Wed Dec 11, 2024 2:07 am    Post subject: Re: Insulating the heat tubes Reply with quote
I notice your car has seat belt mounts, were they original?
Currently filling the garage
1961 beetle cabrio
1971 Superbug
1974 Porsche 911S Targa
1968 1500 Beetle A Project!
Past Garage fillers dozens of type1 &type3 VWs
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan
Schnitzelfuss
PostPosted: Wed Dec 11, 2024 4:06 am    Post subject: Re: Insulating the heat tubes Reply with quote
Rcooled that’s an amazing photograph. It also helps me immensely as my project had no interior whatsoever when I found it. Despite their production numbers there can’t be many remaining with an original interior all the way down to the floors like yours.
Something about the design of those heat tubes or their location or maybe even that cozy covering must have accelerated their demise as they are missing from every parts car I've inquired about. They pop up now and then over in the UK but shipping doubles the typical asking price. I will likely end up having to fabricate my own.
Schnitzelfuss
PostPosted: Wed Dec 11, 2024 6:36 am    Post subject: Re: Insulating the heat tubes Reply with quote
Ya know looking at the picture again it looks like a big old couch back there! The back fenders make nice armrests. Maybe I’ll skip the back seat and just upholster that area, toss a couple throw pillows in the corners and move on.
zerotofifty
zerotofifty is offline
PostPosted: Wed Dec 11, 2024 9:34 am    Post subject: Re: Insulating the heat tubes Reply with quote
You best be a midget, or have a convertible if you want to sit there. The rear glass and roof give little head room back there.
It does look comfy, but no head room.
rcooled
rcooled is offline
PostPosted: Thu Dec 12, 2024 6:49 pm    Post subject: Re: Insulating the heat tubes Reply with quote
As far as I know, yes. You can see that the insulation is neatly cut away around each threaded insert. Same for those in the tunnel too. Dealer-install or DIY wouldn't have been that careful.
Schnitzelfuss
PostPosted: Sun Dec 15, 2024 4:34 am    Post subject: Re: Insulating the heat tubes Reply with quote
Heritage confirmed the supplier stated that yes, the pipes are perforated (no, they do not have the flap valve installed either) so my question is why? There’s no solid tube routed inside the perforation so it’s not like the perforation is a heat shield. Why purposely drill numerous leak holes in a tube designed to carry heated air from the engine all the way forward to the windshield? Only reason I can think of is that the Y tube insulation wrap must always be present and serviceable and that will keep most of the heated air moving forward while also providing some radiant heat to the rear seat for the passengers back there, even with the flap valve closed. Without the insulation wrap I would think the rear seat would become a very hot seat real quick and there wouldn’t be any effective defrost.
viiking
viiking is offline
PostPosted: Sun Dec 15, 2024 2:44 pm    Post subject: Re: Insulating the heat tubes Reply with quote
Perforated tubes did not come in until at least after 1968. My 68 has solid heat tubes.
