CV Boot warning, check your metal ear clamp & avoid boot failure
T3TRIS
T3TRIS is offline
PostPosted: Thu Jun 11, 2020 5:25 pm    Post subject: CV Boot warning, check your metal ear clamp & avoid boot failure Reply with quote
Hey everyone, just a heads up to check your CV boots before installing them (ours were Rockford boots but others might have the same issue) and be careful or you might poke a hole in the rubber.
The pinch part of the metal ear clamp that holds the boot to the ring was lined up with one of the CV bolt holes. It made it very hard to slide the bolt through and I ended up poking a hole in the boot itself by pinching the rubber between the CV bolt head and the raised part of the metal ear clamp.
I only noticed when I went back under the van to double check the torques and there was some fresh grease all over.
markswagen
markswagen is offline
PostPosted: Thu Jun 11, 2020 5:46 pm    Post subject: Re: Rockford CV Boot warning! Reply with quote
i've had 2 that have had the clamp in a bad spot, out of a dozen sets now.
with care the clamp can be slid around, out of the way, it's not difficult.
619 201 0310
old_man
old_man is offline
PostPosted: Thu Jun 11, 2020 6:24 pm    Post subject: Re: Rockford CV Boot warning! Reply with quote
The threads of your bolt look a little worn.
khughes
khughes is offline
PostPosted: Thu Jun 11, 2020 6:45 pm    Post subject: Re: Rockford CV Boot warning! Reply with quote
Thanks for the Tip! I have new CVs and Rockford boots waiting for install and that's good to know. I likely would not have noticed either. Would've been some serious gluteal chapping going on...
'86 Westy FAS GenV Turbo (Marvin)
Syncronoid
Syncronoid is offline
PostPosted: Thu Jun 11, 2020 8:24 pm    Post subject: Re: Rockford CV Boot warning! Reply with quote
It's a simple adjustment any competent mechanic could/should address during install. I don't think it's a Rockford-specific problem, but likely just an oversight that got through QA. Do we really need to call out a warning on a specific brand?
'90 Syncro Westy w/2.5L GW
T3TRIS
T3TRIS is offline
PostPosted: Thu Jun 11, 2020 9:26 pm    Post subject: Re: Rockford CV Boot warning! Reply with quote
Good point! I changed the title to make a little less specific.
As far as being a simple adjustment, I wouldnít necessarily agree.
Iíve never been mechanically inclined but since weíve owned the Vanagon, Iíve dropped a couple engines (the one in the van and one in my Subaru -unrelated), removed our transaxle and front diff and sent it out to get rebuilt, Iíve revamped the entire engine bay, learned how to fix rust and even weld a little (though itís ugly), Iíve rebuilt our Syncro gas tank and replaced all fuel lines, Iíve reinstalled the whole darn thing back together adding gauges, redoing harnesses, cleaning things up, troubleshooting and fixing dozens of weird issues, Iíve replaced some bushings, a variety of boots, brakes, etc etc. I wouldnít consider myself an accomplished mechanic but I think Iím probably more competent at this point than the average Vanagon owner. And it seems that the CV boot/joint deal is a right of passage in Vanagon ownership, something that much less experienced owners might tackle.
With that said, I completely missed that little metal ear clamp pinching potential! I wonít in the future, but I missed it nonetheless and it made a mess that couldíve been worse of course. I also COULDNíT twist that boot on the ring without tinkering with the clamp, and I tried. It was tight.
Also, that boot WAS installed by someone Iíd consider a competent mechanic. Before I tinkered with all this, we had our rear joints replaced with 944 and I asked the mechanic to use the Rockford boots. He didnít think twice and installed them without an issue. Maybe thatís where he was competent and I wasnít.
I love the Rockford boot, I replaced ours with another Rockford boot! Iím also going to give them a call at some point to let them know. Maybe itís not something they check for.
Anyhow, I hope this post can help others avoid that issue that I believe is easily missed.
Guillaume and Jennifer
T3TRIS
1987 Syncro GL converted to poptop
- 1994 Subaru EJ22
- Transaxle rebuild
- 215/75-R15
- Mexico paint job
- Front end rebuild
Fun off-roading
T3TRIS
T3TRIS is offline
PostPosted: Thu Jun 11, 2020 9:27 pm    Post subject: Re: Rockford CV Boot warning! Reply with quote
Thanks for the note, these were new but I used another set regardless!
T3TRIS
- 1994 Subaru EJ22
- Transaxle rebuild
- 215/75-R15
- Mexico paint job
- Front end rebuild
Fun off-roading
old_man
old_man is offline
PostPosted: Fri Jun 12, 2020 2:43 am    Post subject: Re: Rockford CV Boot warning! Reply with quote
I could be wrong of the picture could be showing something that is not there.
djkeev Premium Member
djkeev is offline
PostPosted: Fri Jun 12, 2020 4:09 am    Post subject: Re: CV Boot warning, check your metal ear clamp & avoid boot failure Reply with quote
Interesting find!
So many little things one never gives a second thought about.
I never did fir sure.
In my book this is a light bulb "who woulda thunk" moment!
Thanks!
Dave
Ghia
Vanagon
Beetle
