Turnswrenches Samba Member
Joined: May 02, 2019 Posts: 552 Location: Dawsonville, GA
Posted: Fri Jun 12, 2020 3:29 am Post subject: Getting frustrated with this 32/36 Weber... need replacement |
I've been tuning carbs for 35+ years and I have never had so much trouble trying to make something run right.
Previously seemed OK... but didn't go on any extended drives or long enough to get things good and hot.
Yesterday I took it for about a 30min ride and it started giving me issues again.
Plenty of heat to manifold, proper SVDA distributor, points/timing are spot-on, etc... yet I still have a stumble at tip-in and when secondary opens.
"I am done"
It should not be this much bull$hit to make a stock bug run right.
Can someone recommend a proper carb / intake kit that will run right out of the box ?
I have a bone stock, fresh 1641 dual port.
I am not too concerned about performance...(ie: dual carbs) I just want it to start, idle and run smooth through all the gears with the most simplicity. Will go duals if they can be made to run right.
I have an old original 34pict-3 carb and unknown intake... but dont trust it.
I want brand new stuff that is 100% reliable and correct.
What do I need to buy to make this car run nice ?
I am getting tired of wrenching on this thing and getting nowhere. I have an obscene amount of time and money into this car and im starting to feel like it may soon be time to pull the plug on this project.
I could have built a perfect running 67 Camaro by now... and feel maybe that would have been a smarter project.
Last edited by Turnswrenches on Fri Jun 12, 2020 5:25 am; edited 1 time in total |
anthracitedub Samba Member
Posted: Fri Jun 12, 2020 3:51 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
I’d put a stock, clean intake and a German 34 with nice throttle shaft bushings on it... you can trust this set up. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Fri Jun 12, 2020 5:16 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Turnswrenches wrote: |
I have a bone stock, fresh 1641 dual port. |
Get a rebuild German Solex from Tim @ https://www.volkzbitz.com/ _________________ Glenn
Member #1009
#BlueSquare |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Fri Jun 12, 2020 5:30 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Stop stop stop.
You need to learn to interpret what the engine is tellin´ya.
If it is at tip in on the second barrel its the second barrel idle which is too small. Up it 0,5 and see how it responds.
Stock engine needs stock timing right? WRONG! Just about every time you change something, being it exhaust, carbs or something else, the timing is affected.
First thing to do is increase idle timing to 10 -11degrees. Just leave it there on a stock engine, then you can adjust the total timing later. Readjust idle etc. take it for a drive and see how it responds. The stumble is likely lessened but not gone, so up the second idle jet 0,5
A Camaro or just about any medium tune 350 is easy. You just pour some fuel in and if only 7 of 8 cylinders that catches on, who cares as long as it runs well at WOT.
Youre not running an old or a cheap blue Bosch coil by any chance are ya? If so, that wohnt help you either. |
Posted: Fri Jun 12, 2020 5:45 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Alstrup wrote: |
Stop stop stop.
Timing is 10 degrees btdc at idle and full advance is 30 degrees. (vac hose off/plugged)
I cant put any more timing in it. I already have heat issues I need to sort out. It will get to 400 degrees on #3 under a load or running down the highway.
It will settle down to 350's-380's if I roll out of the throttle... but it's still way too hot for a bone stock engine.
All the tins and gaskets are on the engine.
I'm wondering if these ebay cylinder heads are my issue. (brand new also)
I need to remove the decklid and see if that helps at all.
I will also try a Porsche 356 alt pulley to speed up the fan. (I have a welded/balanced fan)
I have a 3.88 trans... so highway driving is primary issue. Just putzing around local back roads it's not too bad until I get to a hill.
The stumble is at both ends. Initial tip-in... and again when secondary opens. I've jetted it to the point where it cant possibly need more jet. O2 sensor is telling me this.
I think I may turn the secondary idle speed screw in a tad to help get more airflow through that throat to help transition.
Coil and distributor are brand new.
Actually EVERYTHING is brand new.
Last edited by Turnswrenches on Fri Jun 12, 2020 8:20 am; edited 2 times in total |
Coyotemutt Samba Member
Joined: June 16, 2017 Posts: 360 Location: Pecos, New Mexico
Posted: Fri Jun 12, 2020 6:17 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
What's the AFR at tip in then? If it is where it should be, it shouldnt be stumbling. The stumble comes from either gas or spark being delivered improperly (as in bad spark timing/strength or incorrect AFR).
If a hot spark is igniting a ~13:1 ratio at the correct moment, the only possible outcome is smooth operation. Well, I suppose things like poor compression, leaky valves, or other mechanical problems could cause a stumble too. But on a healthy engine, it should be smooth if spark and fuel is correct. |
Posted: Fri Jun 12, 2020 6:30 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Sorry for two posts, but a couple other little things.
If you haven't verified with a vacuum gauge that you're getting the right amount of vacuum to actuate the vacuum canister, you need to do so. VW used many different carbs and many different distributors and they were designed to work together. You have a carb that VW never used and an aftermarket reproduction distributor. The odds of them working together properly are slim.
The other thing is that you can cause a stumble with too much accelerator pump squirt. If your AFR dips to 10 or 11 when you press the throttle, you probably need less squirt.
Lastly, the phrase "I want brand new stuff that is 100% reliable and correct" does not apply to this hobby. It's actually one of the things I like about it. You can't buy your way into a working car. You have to make it happen with ingenuity and an eye for details. I don't mean that to come off as rude, just encouragement! As far as I'm concerned, the VW hobby requires more attention and is more rewarding. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Fri Jun 12, 2020 7:00 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
i don't see anything here that indicates "bone stock".
you would benefit immensely from some heated intake air. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Fri Jun 12, 2020 7:16 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
borninabus wrote: |
you would benefit immensely from some heated intake air. |
I am not going to that extent.
I've exhausted my patience trying to make this 32/36 work... and will not dump another minute of time or another dime into it.
The whole kit-n-kaboodle is coming off and being replaced with something that will work without hours of frustrating jet changes and attempted tuning.
This is not a race car. With a race car, I would expect this level of crap... and have been down that road numerous times.
I just want this car to start when I hit the key... and drive normally... without a hesitation, stumble, stall, bog, overheating, etc...
If I dont get this car dialed in very soon, it's getting sold... or set on fire. |
Posted: Fri Jun 12, 2020 8:07 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
what is the jetting? The jetting which comes with the 32/36 is a joke out of the box. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Fri Jun 12, 2020 8:17 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
[email protected] wrote: |
what is the jetting? The jetting which comes with the 32/36 is a joke out of the box. |
I will check my notes John.
I bought a bunch of jets from you and have tried everything mentioned in your tech articles.
(I have the Redline kit)
I seem to recall something like:
55/65 idles
160/180 airs
135/190 mains
... but will verify when I get home from work. |
Posted: Fri Jun 12, 2020 8:22 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Erik G wrote: |
Quote: |
I want brand new stuff that is 100% reliable and correct. |
buy a honda? |
I would consider that if they were half as cool as a VW. |
Posted: Fri Jun 12, 2020 9:13 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Ok. That sounds odd.
The cylinderhead temp thaty increases a lot under load (I assume we are not talking a 7% grade hill at 60 mph) indicates lean running, timing not retarded or heads that don´t get cooled well or an O2 sensor malfunction.
Have you tried running that hill with the vacum hose off to see if it makes a difference? |
Posted: Fri Jun 12, 2020 9:40 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
What plugs and plug gap?
Your jetting is rich if anything.
Another thing to check is the closed throttle position of the secondary throttle plate. It's set via a set screw at carb base (you have to remove carb to access it). _________________ It's just advice, do whatever you want with it!
Posted: Fri Jun 12, 2020 9:42 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Alstrup wrote: |
I did actually and it didnt improve enough for me to be convinced it was the issue. It may have dropped by 10 degrees or so... but that could have been anything.
Im thinking about pulling the distributor and locking out some timing so I can have more initial advance without having excessive total.
Last edited by Turnswrenches on Fri Jun 12, 2020 9:53 am; edited 1 time in total |
Posted: Fri Jun 12, 2020 9:51 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
Another thing to check is the closed throttle position of the secondary throttle plate. It's set via a set screw at carb base (you have to remove carb to access it). |
That was another thing on my radar.
Im thinking I may benefit from cracking that secondary plate open a few thousandths to add some airflow and ease/smooth the transition.
Idle O2's are 13.5-14.0-ish.
I dont recall transition numbers but at WOT the O2's will fall into the 10's if I keep the pedal down... so yeah it's plenty rich.
Maybe I will see if I can take it for a ride later and record a video of the wideband while driving. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Fri Jun 12, 2020 9:57 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
I did something once, almost just out of curiosity. I timed the stumble. I then put in a slightly larger accelerator pump jet, and upped the pump until the injection took as long or longer than the hesitation. It worked.
I might be completely imagining this, I think I haven't looked at one of those things in a long time, but isn't there an enrichment from a passage opening up towards the main jet, controlled by manifold vacuum? It almost feels likeI dreamed it up... Ignore that last bit if it's completely crazy, it very well might be. |
Posted: Fri Jun 12, 2020 10:09 am Post subject: Re: Getting frustrated with this 32/36 Weber... need replacement |
FreeBug wrote: |
To this "old-school" guy... it "feels" like not enough fuel and not enough timing.
I have put about all the jet into it that I feel is prudent. I think I may tinker with timing a bit more.
My thoughts:
If there is too much advance curve in the distributor, the timing will fall back too far at idle when total is limited to 30 degrees @ 3000.
In my case, it's falling to 10 degrees btdc. It also over-advances into the 40's at light, no-load throttle.
If I lock out all the mechanical advance and disconnect the vacuum advance... I can set it to approx 25 degrees btdc and it "should" be more responsive with the add'l initial advance and run cooler with less total advance. |
