MitchS046 Samba Member
Posted: Fri Jun 12, 2020 10:57 am Post subject: does anyone have exerience with these products? |
hi does anyone have experience with these products or have pointers about them? it is for a 1915 street engine with an stock crankshaft but drilled for an 8 dowel setup comp will be around 9,5:1
second hand JSC strenghtened 1.4 rockers
Mahle C+P.
Engele FK-8 cam
CSP adjustable cam gear
CB 044 heads with big valves, dual springs and titan retainers.
second hand Kennedy stage 1 pressure plate with a 4 puck clutch (which needs replacing) .
Clutch Disc 200 mm gefedert. DAIKIIN (for when the 4 puck runs out)
VW speedshop 42mm IDF thottle bodies.
CSP Cooling System Porsche-Style Type-1 240mm Carbon Fiber.
Scat leightened type-1 flywheel.
Chrome Moly CB Rods 5.400'' ARP 5/16'' for Type-1 Journal and 22mm Pins. weight ca.568g.
Scat gland nut and washer
Lifter Type-1 SCAT 94g.
CSP Push Rod Tubes Type-1.
CSP Oil Pump Cover Type-1 '68-. M18x1.5 Fitting and Pressure Valve.
the dub shop EFI + crank trigger kit. _________________ Slow is smooth, smooth is fast,
~ mark divine |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Sat Jun 13, 2020 5:44 am Post subject: Re: does anyone have exerience with these products? |
Quote: |
Scat gland nut and washer |
Is it the 1 1/2" one? If so and you have a Torque Meister, take a 1 1/2" socket and weld an axle nut on top so you can use the tool on the larger nut.
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Sat Jun 13, 2020 5:48 am Post subject: Re: does anyone have exerience with these products? |
MitchS046 wrote: |
it is for a 1915 street engine with an stock crankshaft |
Why not a counter weighted crank? _________________ Glenn
Member #1009
#BlueSquare |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sat Jun 13, 2020 6:42 am Post subject: Re: does anyone have exerience with these products? |
Dubshop is second to none. Can't go wrong there. |
Posted: Sat Jun 13, 2020 6:55 am Post subject: Re: does anyone have exerience with these products? |
Glenn wrote: |
MitchS046 wrote: |
Why not a counter weighted crank? |
Stock crank is super strong and a lot of people who build performance engines for a living told me to stick with the stock crank _________________ Slow is smooth, smooth is fast,
~ mark divine |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Sat Jun 13, 2020 7:05 am Post subject: Re: does anyone have exerience with these products? |
Needs to be counter weighted to break the 4,000 RPM barrier with out vibrations... Dynamic balancing is needed as well.. RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Glenn Mr. 010
Posted: Sat Jun 13, 2020 7:24 am Post subject: Re: does anyone have exerience with these products? |
MitchS046 wrote: |
Glenn wrote: |
MitchS046 wrote: |
Stock crank is super strong and a lot of people who build performance engines for a living told me to stick with the stock crank |
Built in rev limiter. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jun 13, 2020 7:39 am Post subject: Re: does anyone have exerience with these products? |
RailBoy wrote: |
Needs to be counter weighted to break the 4,000 RPM barrier with out vibrations... Dynamic balancing is needed as well.. RB |
I will defenitely balance the whole assebly when I’m ready _________________ Slow is smooth, smooth is fast,
~ mark divine |
Posted: Sat Jun 13, 2020 7:41 am Post subject: Re: does anyone have exerience with these products? |
[/quote]
Built in rev limiter.[/quote]
Yes was thinking on about 6200 rpm limit to not over rev it also will balance the whole assembly for reliability and longjevity _________________ Slow is smooth, smooth is fast,
~ mark divine |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
I'm on my eighth year of testing that max rpm on stock crank theory........5200-5800 rpm and still going strong.......
40,000 miles are on the bottom end with 13-25 lbs boost. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Glenn Mr. 010
Posted: Sat Jun 13, 2020 7:48 am Post subject: Re: does anyone have exerience with these products? |
MitchS046 wrote: |
RailBoy wrote: |
I will defenitely balance the whole assebly when I’m ready |
How do you balance a non-counterweighted crank?
Of course you can have a stock crank made into a CW. _________________ Glenn
Member #1009
#BlueSquare |
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Sat Jun 13, 2020 8:08 am Post subject: Re: does anyone have exerience with these products? |
Here’s a 9000 rpm dyno pull with a stock crank 1600cc ish.
https://youtu.be/9868ihgGVk8
If it is built correctly it will be fine. sure it might beat up the case sooner than later. Balance it really really good.
Anybody have a stock german 69mm crank that they have broken in half from high rpms, they can show me ? ( crank failure from other components blowing up first doesn’t count ) 😛 |
KROC Samba Member
Posted: Sat Jun 13, 2020 8:15 am Post subject: Re: does anyone have exerience with these products? |
Glenn wrote: |
MitchS046 wrote: |
RailBoy wrote: |
Of course you can have a stock crank made into a CW. |
Any VW crankshaft can be balanced ...Counterweights have nothing to do with balance in theory they are there for strength. bigger the better I would guess. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
Posted: Sat Jun 13, 2020 11:17 am Post subject: Re: does anyone have exerience with these products? |
I can´t show pics, but I have seen it several times especially back in the 90´s when I began to work with hi perf. VW engines. Sometimes it was not just the crank that broke. Sometimes the case broke into 4 or more parts. Short burst hi rpm with a stock crank and (light) rotating assembly in PERFECT balance is okay. Street driving with high rpm sustained like possible if the above gets assembled nice, is just plain stupid. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sat Jun 13, 2020 11:24 am Post subject: Re: does anyone have exerience with these products? |
Glenn wrote: |
How do you balance a non-counterweighted crank? |
Same way the factory did, you drill into the webs to remove a little material.
_________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat Jun 13, 2020 11:45 am Post subject: Re: does anyone have exerience with these products? |
Alstrup wrote: |
luckily it won't be sustained time at high rpms just cruise and the occasional highway/ stoplight pull. _________________ Slow is smooth, smooth is fast,
~ mark divine |
Onceler Samba Member
Posted: Sat Jun 13, 2020 12:21 pm Post subject: Re: does anyone have exerience with these products? |
Make sure the Engle cam and scat lifters are compatible material wise. _________________ 1972 Karmann Ghia |
mark tucker Samba Member
Posted: Sun Jun 14, 2020 8:22 am Post subject: Re: does anyone have exerience with these products? |
SO WHATS STRAIGHTENED ROCKERS?? |
Posted: Sun Jun 14, 2020 9:57 am Post subject: Re: does anyone have exerience with these products? |
mark tucker wrote: |
Quote: |
second hand JSC strenghtened 1.4 rockers |
