volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Wed Aug 12, 2020 9:11 pm Post subject: Re: Empi 34p3 carb. |
It seems like your carb is flooding...high fuel pressure would do that or a leaking float seal...Bill
Check both...good luck Bill. (VT) |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Jun 17, 2020 4:56 am Post subject: Re: Empi 34p3 carb. |
did you follow the set up procedure that comes with the carbs? VERY important. Very possible your choke is set wrong. You can go to vw-resource.com on how to set that. Also you should ALWAYS clean a new carb before installing it.
I have not had issues with the newer Empi carbs, but have had to set up more than one at the shop that an owner installed and didnt adjust first. _________________ D-Dubya Manx clone - 63 Short pan,1914.
wcfvw69 Samba Purist
Posted: Tue Jun 16, 2020 7:47 pm Post subject: Re: Empi 34p3 carb. |
samk47 wrote: |
I recently finished my trike, it`s a 61 transaxle, recently rebuilt standard 1600, Empi 34p3 carb. with manual choke, (carb. is new), points distributor. Nothing has been hot-rodded. It goes down the road nice and runs fine, but every time I start it I have to hold the throttle wide open til it starts. I replaced the needle & seat, with 2 washers on it, no difference. I added about 2/3 of a can of carb. cleaner to the gas tank, witch had about 5 gal. in it, no difference. I contacted the man who did the motor, ( he races sand rail vws) and he hadn`t ever heard of such trouble. So that`s why I am here, I am hoping some of you guys have some ideas for me. I can`t afford to have a mechanic fix it cause social sec. doesn`t go very far. I would sure appreciate any input you guys have, Thank you very much. samk47 |
What kind of fuel pump are you running on the engine? Is it an electric fuel pump or the original style? Have you checked what kind of fuel pressure you're getting from it? 34-3 carbs like 3 psi plus or minus .5 psi. Many aftermarket fuel pumps can put out 5 psi and above. That high fuel pressure can overwhelm the valve under the float.
EMPI Chinese 34-3 carbs can be hit or miss in quality. Some say they work ok while most avoid them. I had a new one on a VW I purchased. I couldn't get it to work correctly at all. The tolerances in it where terrible. I installed a rebuilt/restored original German Solex 34-3 carb and my problems were resolved. _________________ Contact me at [email protected]
The Samba member since 2004.
samk47 Samba Member
Posted: Tue Jun 16, 2020 5:56 pm Post subject: Empi 34p3 carb. |
