BFB Samba Member
Posted: Wed Jun 17, 2020 3:35 pm Post subject: inverted head step ? |
has anyone ever machined an " inverted step " into a head so the cylinder can recess into it and decrease the deck height ?
i have a small stroker im working on, using up some parts i have and pistons im using are B's and deck height is a little to much. weeellll, last guy i had turn my cylinders down a little took 6 weeks to get it done and not any others i can find to do it. then i thought, i bet itd be easier to find someone to machine a recess into the head and wouldn't that accomplish the same thing?
for that matter, i could modify the blade on my flycutter to just cut the step...
like to hear why this would or wouldnt work, not about decking the case or running longer rods etc. there's enough threads about that _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
mark tucker Samba Member
Posted: Wed Jun 17, 2020 3:54 pm Post subject: Re: inverted head step ? |
yes you could, but I would rather do the cylinder or use a longer rod. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Wed Jun 17, 2020 6:21 pm Post subject: Re: inverted head step ? |
Sure it's possible, tho it isn't better. The heat path is longer. But within reason it would work fine.
I'm not going to say that altering the stroke, or rod length, stroke, or case surface, or cylinder length is no more or less difficult and is better, because you already know that. Oh wait I just did. |
Nightshift Samba Member
Posted: Wed Jun 17, 2020 7:03 pm Post subject: Re: inverted head step ? |
Hydrocarbons will increase due to the partially burned and or slower burning fuel left in the slight (crevice volume) gap between the head and the cylinder. This is also why we try to run the top rings as high as we do on the pistons. That area is known as crevice volume. We need to make good use of the air/fuel mixture and keep it in the combustion chamber for optimum performance and emission's. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Wed Jun 17, 2020 7:18 pm Post subject: Re: inverted head step ? |
richardcraineum wrote: |
like to hear why this would or wouldnt work... |
Concentricity. Make the cut wide enough to account for any shift in bore center between the case and heads. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
