fredybear Samba Member
Posted: Wed Jun 17, 2020 8:26 pm Post subject: Lets Build a Motor, Anyone Wanna Help???????? |
Ok lets start simple.........82 crank, fk-8, had this short block sorta together for 15 yrs....ouch, just took it apart today. Everything still beautiful.
Case it still 85s.
Have CB Wedgeport heads, 1.4 rockers.
Question? Carbs, Pistons, Exhaust to match the wedgeports with the fk-8 ??
Good Combo???
Anyone, Anyone???? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Jun 17, 2020 9:04 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
You have 82mm crank, FK-8 cam, 1.4 rockers, & wedge port heads
I'd Get 94mm pistons, sell the FK-8 and get an FK-10, 48 IDA's with the Berg 35/40 venturies, 10:1 CR, 1 3/4" exhaust _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
nsracing Samba Member
Posted: Thu Jun 18, 2020 12:46 am Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
I can help w/ machining and balancing -
what else you got? |
74 Thing Samba Member
Posted: Thu Jun 18, 2020 7:29 am Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Which wedge port heads do you have? |
Posted: Thu Jun 18, 2020 1:26 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Ill post some pics of the mess. Got the head back in 05 from ETR, if anyone knows/remembers who that is.?
I need to send them to CB to get em straightened out.....
Anyone here use beehive springs????
Pics to come... |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Thu Jun 18, 2020 5:07 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Yeah I like to use beehive oval wire springs.
There are four or five different kinds people have found ways of making fit, which handle different lifts. Depends on the lift and pressure you need.
They are kinda expensive. |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Thu Jun 18, 2020 6:00 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
fredybear wrote: |
Pics to come... |
Yes I use them and sell beehive conversion kits. Yes they are pricy but because of the long spring life are a good value.
https://www.thesamba.com/vw/classifieds/detail.php?id=2077442 |
Posted: Fri Jun 19, 2020 7:09 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Here ya go.....The two middles were cut, anyone notice anything? Can they be welded back and re-cut??
Now the Beehives, the fat spring is for the big holes and the skinny spring is for the standard holes.
These were bought in 06...
Which springs for the fk-8?
I have 44s forgot to mention, Bologna Webers.....
The wedgeports - fk-8 - 44s, would they go together? and what size pistons? exhaust......
Been out of the loop since 2000s....Back to my money sucking VW
More pics to come |
Posted: Mon Jun 29, 2020 10:20 am Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Hello Heloo
Been working on the express van.
Yesterday installing new channel seal metal for engine compartment...
Head, whatyaall think?
Springs?
Hellooo |
Posted: Tue Jun 30, 2020 10:18 am Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Hello
The Head question, the spring question?
Ideas?
Can the heads be welded up and re-cut?
Whats the difference between the fat beehive springs and the skinny behive springs?
I see different rpm ranges for the springs 7000, 7250, 7500
anyone? |
Posted: Tue Jun 30, 2020 10:33 am Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Yes the heads can be welded to fix the hole in the port. Where are you? |
c77owen Samba Member
Joined: July 07, 2017 Posts: 454 Location: Kansas City, MO
Posted: Tue Jun 30, 2020 11:08 am Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
vwracerdave wrote: |
I'd Get 94mm pistons, sell the FK-8 and get an FK-10, 48 IDA's with the Berg 35/40 venturies, 10:1 CR, 1 3/4" exhaust |
^^^Agreed^^^^ I have a near similar set up (86mm crank, 044 SuperPro CNC heads) and it screams! |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Jun 30, 2020 12:19 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
FK-8 is a great cam for that application.
Agreed with big set of IDA carbs will get the max out of your setup.
Get ready for low 12sec 1/4mi passes.
Get the head welded up. Then just go with VW650 springs.
the rust on those beehives is cause to pitch them. |
Posted: Tue Jun 30, 2020 1:13 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
socal/la
Im gonna take a ride to rimco/fat to hook up the case and stuff.....
What about the 40mm vents in the 44s? ac.nets website says it'll boost up performance and makem breathe like 48s
True? anybody do that? |
Posted: Tue Jun 30, 2020 1:15 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
The springs were stored and the moisture got em. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Tue Jun 30, 2020 2:19 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Dan Ruddock wrote: |
I probably misunderstood, but I thought the OP was talking about the valve guide bosses which have been machined down. |
Posted: Tue Jun 30, 2020 6:13 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
I would take the heads to Steve Tims in Riverside. Dan |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Tue Jun 30, 2020 6:21 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
and the case to Brothers in Ontario, CA _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
Posted: Wed Jul 01, 2020 12:30 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Road Trip Should I build it myself or have them do it?
How bout the vents? 40s? Are they easy to change out?
Checkin in..... |
Posted: Fri Jul 10, 2020 6:09 pm Post subject: Re: Lets Build a Motor, Anyone Wanna Help???????? |
Carb jets, 14 yrs in carb.
Safety first
Holes
Cam Go Round
Parts are being worked on.
Its Turbo time.
Comments |
