Fuel pump relay coil circuit fault = bad input to ECU?
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sun Jun 21, 2020 2:40 pm    Post subject: Fuel pump relay coil circuit fault = bad input to ECU? Reply with quote
hi folks.
Under Vanagon Digifant, if the fuel pump relay 85/86 coil circuit had an intermittent break or constant voltage drop, since the ECU supplies (my term) a ground to energize that relay coil, could the ECU see that as a "bad" input then possibly adversely affect other engine management component(s)?
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
jlrftype7
jlrftype7 is offline
PostPosted: Sun Jun 21, 2020 2:52 pm    Post subject: Re: Fuel pump relay coil circuit fault = bad input to ECU? Reply with quote
Not perceived perhaps, but definitely affecting, since a fuel pump going in and out could affect O2 sensors values due to fuel trim and regulated pressure getting wonky. I would be surprised with our simple systems if anything much is perceived by the ECU.
Later engine management systems have so much more in the way of feedback circuits to give an ECU info.
‘84 Tin Top - Hilga....Auto
RawUmber
RawUmber is offline
PostPosted: Sun Jun 21, 2020 6:30 pm    Post subject: Re: Fuel pump relay coil circuit fault = bad input to ECU? Reply with quote
The ECU sees the Fuel Pump relay coil as an output and doesn't 'know' whether it is working or not (ie, not an input).
Low fuel pressure's effect on engine performance could possibly be measured on the O2 sensor, Air Flow Meter, and Coolant Temp sensor, which could cause the ECU to adjust the fuel injection quantity given the parameters of the moment. However, once your relay is repaired/replaced, everything is back to normal the next time you start your van.
An intermittent relay coil can cause intermittent relay switching, which may add a little wear/tear to the fuel pump, relay contacts, and ECU fuel pump driver transistor, but to what degree would depend upon the circumstance.
Vanagon Nut
PostPosted: Sun Jun 21, 2020 7:30 pm    Post subject: Re: Fuel pump relay coil circuit fault = bad input to ECU? Reply with quote
Very helpful information. Thanks very much!
I'd always thought of this type of relay as behaving in an "on or off" manner; it would work "100%" or fail "100%" Today I wondered if a voltage drop on the coil side could cause the relay switch to sporadically open/close but still work well enough to allow the engine to run. I also wondered that if the 86 leg join to coil was broken, current might instead try to pass through the suppression resistor to the coil.
The relay in question is a "WBX 53" on my Jetta conversion which has Motronic 2.9 but figured asking after Vanagon Digifant would help regardless.
After replacing this fuel pump relay, it feels like starting, running are consistently better and I'm hopeful I've solved the random stall and/or dip in idle when coming to a stop issue.
If the other 53 relay (ECU etc. power) is the same make (design) I'll pull it and see what it looks like inside.
Neil.
VE7TBN
