'50 speedometer mounting
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Mon Jun 22, 2020 8:04 pm    Post subject: '50 speedometer mounting Reply with quote
… looked at SINCLAIRE's 1949 speedo picture, posted on 6/22 and noticed it was mounted in the pod, differently than mine -
… and this is my 1950 standard speedo inna' standard pod - looks to me, to be mounted further back in the pod - whattiya' think - is mine mounted incorrectly? And why, do you think? - z
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
finster
finster is offline
PostPosted: Tue Jun 23, 2020 2:34 am    Post subject: Re: '50 speedometer mounting Reply with quote
I think yours looks factory correct zen, as sinclair's looks to be unevenly mounted. is there a gasket ring between the two parts that could be missing on his?
this is from johnshenry - slight recess like yours
66brm
66brm is offline
PostPosted: Tue Jun 23, 2020 5:22 am    Post subject: Re: '50 speedometer mounting Reply with quote
The outer trim ring also looks to be thicker, perhaps there's a difference between BD and sedan?
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
sinclair
sinclair is offline
PostPosted: Tue Jun 23, 2020 10:41 am    Post subject: Re: '50 speedometer mounting Reply with quote
Well it seems it’s 100mm. Brown not chrome and stamped W 0.49 8.49 should I assume this is a Standard August speedo in my July car? As for the depth, should there be a gasket?
FRK
FRK is offline
PostPosted: Tue Jun 23, 2020 5:09 pm    Post subject: Re: '50 speedometer mounting Reply with quote
I think standard speedo have a different ring around the edge. My standard speedo is mounted exactly the same way as yours. Sinclair speedo is for deluxe.
Below is my ‘50 standard speedo pod.
Below is my ‘50 deluxe Speedo pod.
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
johnshenry Premium Member
johnshenry is offline
PostPosted: Tue Jun 23, 2020 6:24 pm    Post subject: Re: '50 speedometer mounting Reply with quote
Yes, Sinclair's looks to be a deluxe pod (certainly, with a 100mm opening). I could be wrong, but the speedo looks like a deluxe with chrome (deluxe) bezel painted brown.
John Henry
'57 Deluxe
'56 Single Cab
FRK
FRK is offline
PostPosted: Tue Jun 23, 2020 6:39 pm    Post subject: Re: '50 speedometer mounting Reply with quote
Yes, Sinclair’s speedo is a deluxe. Deluxe and standard speedos have different bezels.
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
sinclair
sinclair is offline
PostPosted: Tue Jun 23, 2020 9:39 pm    Post subject: Re: '50 speedometer mounting Reply with quote
Stranger and stranger Confused so can an 8-49 speedo possibly be original to a 27-07-49 car?
PostPosted: Wed Jun 24, 2020 7:09 am    Post subject: Re: '50 speedometer mounting Reply with quote
No.
John Henry
'57 Deluxe
'56 Single Cab
sinclair
sinclair is offline
PostPosted: Wed Jun 24, 2020 7:55 am    Post subject: Re: '50 speedometer mounting Reply with quote
johnshenry wrote:
No.
Well that told me Laughing
So now I need to find a standard 49 clock and pod 😣
ZENVWDRIVER
PostPosted: Wed Jun 24, 2020 11:25 am    Post subject: Re: '50 speedometer mounting Reply with quote
sinclair wrote:
johnshenry wrote:
No.
… I wouldda' thought that all clocks from 6/49 to 10/52, were all designed the same - for the deluxe as the brown dial-face looks the same as the speedo, by design - so you mean there is a smaller standard size clock, with standard brown bezel too?
My '50 11A, had a clock, back in '77, but I have changed that pod to a standard blank that I bought earlier this year - my first one, that i'm gunna' put an ( old looking) KDF flying logo sticker on - z
1960 single cab
'87 Toyota MR2
sinclair
sinclair is offline
PostPosted: Wed Jun 24, 2020 12:26 pm    Post subject: Re: '50 speedometer mounting Reply with quote
ZENVWDRIVER wrote:
sinclair wrote:
johnshenry wrote:
No.
Sorry by clock I mean speedo.... Uk slang.
ZENVWDRIVER
PostPosted: Wed Jun 24, 2020 1:35 pm    Post subject: Re: '50 speedometer mounting Reply with quote
… Mr. Sinclaire, I have used that slang as well - referring to, "the miles on my clock" - thanks for the reminder.
z
1960 single cab
'87 Toyota MR2
