Oil Cooler Studs
kerian159
kerian159 is offline
PostPosted: Tue Jun 23, 2020 4:58 am    Post subject: Oil Cooler Studs Reply with quote
Working on getting my engine put back together after 3 years Mad , i'm noticing a few things that need to be corrected so I won't have to pull the engine out again for a while. One big thing is the Oil Cooler nuts won't torque up to the proper rating, I looked at the studs and the threads are all buggered up. Does anyone know the part # or a decent replacement for this or can I just go get some all thread that has the same thread pitch for the case? It's the top stud that is the offending item.
1976 Type II Westy P22
"Growing older, but not up!"
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jun 23, 2020 7:56 am    Post subject: Re: Oil Cooler Studs Reply with quote
I think you will need to find someone with a junk case to pull one from. They aren't going to be common because they come with the case on a T4 and they have been NLA a long time on T1 doghouse engines. But you could possibly get a bolt the correct length, and cut it off.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
orwell84
orwell84 is offline
PostPosted: Tue Jun 23, 2020 9:09 am    Post subject: Re: Oil Cooler Studs Reply with quote
Maybe you could find some in the classifieds. If not either the cut down bolt or threaded rod seem like good options. I think I would prefer the bolt. I don’t think there is much torque on the nuts so it should work out.
Vee Dub Nut
Vee Dub Nut is offline
PostPosted: Tue Jun 23, 2020 9:15 am    Post subject: Re: Oil Cooler Studs Reply with quote
How about these:
https://www.thesamba.com/vw/classifieds/detail.php?id=2080115
Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut
orwell84
orwell84 is offline
PostPosted: Tue Jun 23, 2020 9:23 am    Post subject: Re: Oil Cooler Studs Reply with quote
And there ya go!
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Tue Jun 23, 2020 9:32 am    Post subject: Re: Oil Cooler Studs Reply with quote
Ken at the Busco helped me out a few times when I was trying to find odds and ends in my Type 4 rebuild. It would be worthwhile at least emailing him to see if he has anything.
http://www.thebusco.com/
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
kerian159
PostPosted: Tue Jun 23, 2020 9:55 am    Post subject: Re: Oil Cooler Studs Reply with quote
ha well that works Smile i'll get in touch with Ken as well, thanks
old DKP driver
old DKP driver is offline
PostPosted: Tue Jun 23, 2020 12:19 pm    Post subject: Re: Oil Cooler Studs Reply with quote
bel metric.com
Should have them also.
V.W.owner since 1967
