Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Mon Jan 25, 2021 5:58 pm Post subject: Re: Cross Country in a 66 Square |
Nice.
Good to see you chasing out all the hidden little rusted spots these cars all seem to hide.
What are your plans for finishing out the interior?
If your original door panels, carpet, etc. are still in reasonable shape,
It would give you a far better end result to clean and preserve these pieces vs. using the new aftermarket junk parts that are available now.
I'd hope they even saved window scrapers, door seals, window seals, window trim, etc.
Originals in good shape are far more desirable than aftermarket,
And they're free! _________________ Bus Motor Build
What’s That Noise?!? |
grenadeAcorn Samba Member
Posted: Tue Jan 26, 2021 9:56 am Post subject: Re: Cross Country in a 66 Square |
Clatter wrote: |
Nice.
And they're free! |
Door panels are good, seat covers will get replaced and im sure all the rubber. So yeah probably going to go through all the same struggles you are _________________ 1967 VW Type1
1966 VW Type3 (Squareback)
1967 Land Rover Series 2a 109 (NOTAVW)
1964 Ford Galaxie 500 FB (this one either) |
Posted: Tue Jan 26, 2021 2:34 pm Post subject: Re: Cross Country in a 66 Square |
IIRC,
TMI did tool up to make those unique ‘66-only seat covers.
Roll-over top seams, textured centers, smooth outer.
Best be getting going if you want a set made.
You’re likely to talk to trolls bent on selling you their generic not-really-any-year mutant cheapies before you can get someone who knows.
Took me a couple of years to get the right seat covers for my ‘67,
But they eventually did it.. _________________ Bus Motor Build
Posted: Wed Jan 27, 2021 11:17 am Post subject: Re: Cross Country in a 66 Square |
Clatter wrote: |
IIRC,
But they eventually did it.. |
That's good to know, another option may just be to repair; they are in pretty good shape with only the drivers side bolster needing a fix. _________________ 1967 VW Type1
Posted: Wed Jan 27, 2021 1:36 pm Post subject: Re: Cross Country in a 66 Square |
grenadeAcorn wrote: |
Clatter wrote: |
IIRC,
That's good to know, another option may just be to repair; they are in pretty good shape with only the drivers side bolster needing a fix. |
That's good to hear.
Sometimes those vinyl repair guys can work some real magic.
Repaired originals are going to be better than even the best stuff from TMI.
How are the carpets?
That's one of those things most regular VWs would be a no-brainer to replace,
However,
Like a lot of other things, it's a different game for the type 3.
Carpets are one of those things that can really look great with a good cleaning.
Fortunately,
TMI headliners aren't that bad.
You'll want to re-use or dye the pinch-welts around the door openings if you want to to be correct,
As they are two-tone to match the door panels and headliner. _________________ Bus Motor Build
Erik G Samba Member
Joined: October 16, 2002 Posts: 13269 Location: Tejas!
Posted: Wed Jan 27, 2021 2:56 pm Post subject: Re: Cross Country in a 66 Square |
carpet = call Lenny |
Posted: Thu Jan 28, 2021 10:01 am Post subject: Re: Cross Country in a 66 Square |
Clatter wrote: |
Clatter wrote: |
IIRC,
However,
Fortunately,
As they are two-tone to match the door panels and headliner. |
I don't think the carpet is worth saving to be honest is was unraveling in a few spots but I cant remember if i paid that much attention to it. _________________ 1967 VW Type1
Posted: Thu Jan 28, 2021 10:02 am Post subject: Re: Cross Country in a 66 Square |
Erik G wrote: |
Thank you _________________ 1967 VW Type1
Posted: Thu Jan 28, 2021 10:20 am Post subject: Re: Cross Country in a 66 Square |
Taking care of some of the things I can on this thing while Chris is working his magic; Tires removed from the wheels,
Now the question is, where is the best place I can send these things for polish and detailing?
nynone4 Samba Member
Joined: August 09, 2004 Posts: 299 Location: Central Illinois
Posted: Tue Feb 02, 2021 7:49 am Post subject: Re: Cross Country in a 66 Square |
I've had good experiences with Alex Magro on Fuchs wheels. He has some ads here on the site. I'd recommend him. _________________ >>Looking for any and all Vic Williams, Peoria Illinois dealership items.<< |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Tue Feb 02, 2021 12:40 pm Post subject: Re: Cross Country in a 66 Square |
Erik G wrote: |
Thank you |
Take it to your local Upholstery Shop & install square weave etc carpet as it will Fit & be edged just how you want it! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Feb 02, 2021 2:30 pm Post subject: Re: Cross Country in a 66 Square |
nynone4 wrote: |
I've had good experiences with Alex Magro on Fuchs wheels. He has some ads here on the site. I'd recommend him. |
Thank you!!! _________________ 1967 VW Type1
lawn ninja Samba Member
Joined: January 02, 2006 Posts: 1009 Location: Round Rock, TX
Posted: Tue May 11, 2021 8:47 am Post subject: Re: Cross Country in a 66 Square |
Two of those wheels are not like the others. Looks like you have one set of early deep 6's. You can tell by the pedals and the cutouts. If you look you can see how around the cutouts for the "windows" it slightly curves up vs being totally flat like the other two. In addition to that, the window that has the valve stem has a small raised portion right around the valve stem that is shaped like a heart. If you set them right next to each other you'll see the differences. _________________ Jason
My 64 1500 S Notchback project here
My 58 sedan project here
My 63 Ghia here |
Posted: Wed Jul 28, 2021 8:23 am Post subject: Re: Cross Country in a 66 Square |
Any more progress pics on the car? Hope it's going well for ya! _________________ >>Looking for any and all Vic Williams, Peoria Illinois dealership items.<< |
Erik G Samba Member
Drewbox Samba Member
Posted: Thu Feb 03, 2022 7:56 pm Post subject: Re: Cross Country in a 66 Square |
This thread is a WILD ride! I got super excited when I first saw it. Ive taken my '72 FI square on 2 road trips now and love to hear about other people taking aircooled VWs across the contry. Then I saw what happened and was flooded with a range of emotions. But Im glad that all is working out and its going to be very nice whn all done and put together.
My short story: I bought my Squareback from the son of the original owner in Seattle back in Oct, 2020. flew up, took it around the block a few times, exchanged money for title and promply hit the road back to Phoenix. Then later in May 2021 I took a trip to Mount Rushmore. 2100+ miles round trip. One of the best road trip Ive done. and plan to do more in the future. |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1419 Location: Chicago IL/CHandler AZ
Posted: Fri Feb 04, 2022 10:17 am Post subject: Re: Cross Country in a 66 Square |
I, too, am curious as to how this is coming along. Sorry to see what occurred during your trip, but this looks like its going to be a gorgeous Squareback! |
Posted: Sat Feb 05, 2022 11:34 am Post subject: Re: Cross Country in a 66 Square |
Since he hasn't answered/been here in a year, I will post what I saw on facebook.
He pulled his square out of Reed's Shop before they got it painted.
He was upset that he had $20K insurance money & cash in the new roof/bodywork and it wasn't finished? _________________ https://imgur.com/user/FisherSquareback/posts
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4186 Location: Pasadena CA/DTLA soon China
Posted: Sat Feb 05, 2022 2:11 pm Post subject: Re: Cross Country in a 66 Square |
Mike Fisher wrote: |
He was upset that he had $20K insurance money & cash in the new roof/bodywork and it wasn't finished? |
$20k? For a few K More he could have my squareback
(Nope! Not and ad! Car not for sale) _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Posted: Sat Feb 05, 2022 10:58 pm Post subject: Re: Cross Country in a 66 Square |
@Mike Fisher, that is a shame. I do not know the story, but if that is accurate, it is unfortunately seemingly typical of far too many auto restoration and body shops. |
