varying TIV fans
Page: Previous  1, 2
RalphWiggam
RalphWiggam is offline
PostPosted: Tue Sep 15, 2020 4:39 am    Post subject: Re: varying TIV fans Reply with quote
As soon as I get my bus back from the damn painter, I should have something interesting for you folks.
In fact I have it sitting here waiting to install, but I have no bus!!
metahacker
metahacker is offline
PostPosted: Tue Sep 15, 2020 1:32 pm    Post subject: Re: varying TIV fans Reply with quote
airschooled wrote:
metahacker wrote:
I believe it. We "knife edged" a couple T1 fans (grinding the flat entry point on each fin to a sharp edge to cut down on turbulence)...and I can say that tiny change made a very NOTICEABLE difference in sound.
Now this I can get behind! Can you describe the difference? Did you monitor head or oil temperatures after?
It was quieter Smile I did not collect any data before/after. One could assume that it would flow better and take less power.
It was part of a conversion on a non-stock motor from the terrible modified stock carburetor + clapped out SVDA combo it was running to a full EFI system with a wide-band O2 sensor hall sensor etc. It definitely ran WAY cooler after Smile But that would be because I tuned AFR's on a dyno for several hours....
I would definitely not hesitate to do it again on any T1, though. A T4 cast fan I'm not so sure really needs it (seems less blunt on the edge with the casting process)?
SGKent Premium Member
SGKent is offline
PostPosted: Tue Sep 15, 2020 2:45 pm    Post subject: Re: varying TIV fans Reply with quote
Each fan vane is an airfoil. Sharpening the air foil doesn't necessarily make it work better. Each vane makes the air move the same as a wing does, by pressure differences between the long and short side of the vane. Speed, flow, proximity to nearby vanes, all these things would effect how the fan works.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
raygreenwood
raygreenwood is offline
PostPosted: Tue Sep 15, 2020 2:49 pm    Post subject: Re: varying TIV fans Reply with quote
Type 1 fan is a different type of airfoil than type 4. But you never know. Ray
Page: Previous  1, 2
Page 2 of 2
