charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Thu Jun 25, 2020 6:59 pm Post subject: Subaru Legacy transaxle in Vanagon? |
this possible?
a neighbor has a 2000-something subaru legacy (manual trans) with a busted engine.
I was looking into rebuilding my aircooled trans to support a 2.0 TDI, but.. should i just pull the subie trans instead or is this a whole world of hurt? |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Thu Jun 25, 2020 7:11 pm Post subject: Re: subaru legacy transaxle in vanagon |
i think your gear ratios would be all wrong, with a tdi engine on a subaru trans.
a better option, perhaps, would be to use a passat transmission, they can be flipped to work upside down, a manual trans from a tdi passat, would have the right ratio's for the engine, there's a company based in the UK, ultimate engineering, they offer kits.
i believe they cut half an inch off the bellhousing, rotate it to the desired angle, and weld it back on again, it's not quite that simple. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Thu Jun 25, 2020 9:47 pm Post subject: Re: Subaru Legacy transaxle in Vanagon? |
Ok. So rebuilding my aircooled trans best way to go? |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Thu Jun 25, 2020 10:58 pm Post subject: Re: Subaru Legacy transaxle in Vanagon? |
The cheapest and simplest option is to find a used air-cooled trans in good working condition.
Problem with that is knowing if a used transmission is actually a good working unit before you install it, and how much life it has left in it.
Used to be I could find used transmissions for vanagons in the local junkyard for 137 $. Too bad those days are gone.
The most expensive and most difficult option is to take a free subaru trans (which turns the wrong way for us vw folks) and modify it to work for your van, including fabricating a shift linkage.
Somewhere in the middle is rebuilding your existing trans. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
