Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Wed Nov 25, 2020 10:38 am Post subject: Re: The Roach |
Looks like it's ready to go in to me. Then the trans and engine can get off your floor, so you can stop tripping over them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Wed Nov 25, 2020 11:35 am Post subject: Re: The Roach |
Old IRS and trans are still in the car. This is my IRS/framehorns unit. I still have to pull the old one to get the swing arms off the old one and then add a cross bar to the upper shock mounts to limit flex. But progress! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Wed Nov 25, 2020 2:55 pm Post subject: Re: The Roach |
Hardware installed. Next are the trailing arms and stub axles _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Dec 22, 2020 3:59 pm Post subject: Re: The Roach |
Last night, after moving the speedster to a friend's garage, I moved the Roach in the garage so that I could have space around it to get after the rear subframe swap. I will also use this time to install the windshield, make some more repairs and see if I can sort out the hood issues.
Posted: Tue Dec 22, 2020 7:40 pm Post subject: Re: The Roach |
vwfye wrote: |
Looks good. Maybe some work will actually get done in the next couple of weeks. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Tue Dec 22, 2020 8:10 pm Post subject: Re: The Roach |
We were out of state for a funeral for 2 weeks. That sort of thing brings a stop to car work. _________________ 64 No'back Speedster "Pearl"
Posted: Tue Dec 22, 2020 8:41 pm Post subject: Re: The Roach |
vwfye wrote: |
We were out of state for a funeral for 2 weeks. That sort of thing brings a stop to car work. |
OK, I'll let you slide on that one. But you do have a tendency to work at the speed of molasses in winter time. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Tue Dec 22, 2020 8:43 pm Post subject: Re: The Roach |
That is just so others shake their heads... secretly I am efficient. _________________ 64 No'back Speedster "Pearl"
catbox Samba Member
Joined: May 16, 2007 Posts: 865 Location: Portland, Oregon
Posted: Wed Dec 23, 2020 9:52 am Post subject: Re: The Roach |
Bobnotch wrote: |
vwfye wrote: |
OK, I'll let you slide on that one. But you do have a tendency to work at the speed of molasses in winter time. |
I have heard of that work speed described as "PST or Phil Standard Time"
Phil in this case would be Notched.
_________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
vwfye Samba Member
Posted: Thu Dec 24, 2020 12:04 am Post subject: Re: The Roach |
The car is on stands to drop the rear subframe. I noticed, while under it today, that the body is 1/8th inch too far forward.
Now, I need to sort out how to move it that little bit as a one man show. _________________ 64 No'back Speedster "Pearl"
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Dec 24, 2020 12:31 am Post subject: Re: The Roach |
vwfye wrote: |
Now, I need to sort out how to move it that little bit as a one man show. |
_________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Thu Dec 24, 2020 10:03 am Post subject: Re: The Roach |
Tram wrote: |
vwfye wrote: |
Hahaha _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Dec 24, 2020 12:36 pm Post subject: Re: The Roach |
I'm trying to see what I can leverage against. It will happen. _________________ 64 No'back Speedster "Pearl"
Posted: Thu Dec 24, 2020 6:41 pm Post subject: Re: The Roach |
vwfye wrote: |
I'm trying to see what I can leverage against. It will happen. |
Depends on which way they have to go. You can use the bottom of the front fender well to pull the pan forward, or from the pan edge (up front) rearward off a bumper mount. You're only talking an 1/8th inch. You could almost unbolt most of it and bounce the body on the pan too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Dec 26, 2020 5:54 pm Post subject: Re: The Roach |
The wifey decided, rightfully so, that I should no longer be under heavy and awkward things alone. So, today I picked up a lift table and a 48" LED lamp and Thursday I picked up a pair of 6 ton 2" tall jack stands. I am set to "safely" finish pulling the rear subframe and installing the new one. No more hokey balancing... _________________ 64 No'back Speedster "Pearl"
andybla Samba Member
Posted: Sun Dec 27, 2020 3:16 am Post subject: Re: The Roach |
Good decision, always think about your safety so you could cruise later |
Jason37 Samba Member
Posted: Sun Dec 27, 2020 11:18 pm Post subject: Re: The Roach |
When you get to this point, you know it’s been a project too long. Kudos to your wife for enforcing safety...mine might check on me after 5 or 6 hours.
And I know it not be the most desirable method, but a long drift or punch might move the body into alignment. |
vwfye Samba Member
Posted: Mon Dec 28, 2020 3:29 pm Post subject: Re: The Roach |
Unexpected hang up... literally.
Everything is disconnected, but the shift rod coupler will not let go of the transmission! Pretty sure, based on the safety wire, it has never been apart and it does not want to be free. Grrrrrr _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Dec 29, 2020 12:09 pm Post subject: Re: The Roach |
I used a ratchet strap last night to put tensio on the set up. This morning, it had released! Woot!!! Next is to unbolt the pivot pins and then start fitting it all to the updates subframe.
