W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Tue Dec 29, 2020 12:21 pm Post subject: Re: The Roach |
Quote: |
I picked up a pair of 6 ton 2' tall jack stands. |
everyone should own a set of these jack stands, the little 2 or 3 ton don't go high enough. My buddy has 4 of the 12 ton for his car, so much more space under the car, and the base is super stable. You just need a floor jack that can reach. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Dec 29, 2020 9:17 pm Post subject: Re: The Roach |
I bought some 10 ton jack stands after wrestling with moving the body from a body cart to smaller jack stands/jacks to get the pan back on the car. I use hockey pucks from Amazon to use as buffers between the jack and the body.
They were expensive for jack stands but cheaper than a trip to the ER. |
vwfye Samba Member
Posted: Tue Dec 29, 2020 9:19 pm Post subject: Re: The Roach |
vwfye wrote: |
I used a ratchet strap last night to put tensio on the set up. This morning, it had released! Woot!!! Next is to unbolt the pivot pins and then start fitting it all to the updates subframe.
The cart is HF 500lb unit. That makes it all so much easier. I should have bought one years ago! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Bobnotch Samba Member
Posted: Wed Dec 30, 2020 9:21 am Post subject: Re: The Roach |
vwfye wrote: |
vwfye wrote: |
The cart is HF 500lb unit. That makes it all so much easier. I should have bought one years ago! |
Nice. Glad to hear you got it out.
I have a couple of those carts for moving stuff. In fact I've got a spare engine sitting on one at the moment. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Thu Dec 31, 2020 10:55 am Post subject: Re: The Roach |
Any hints on rwmoving the driver side pivot bolt? No real room to hit the allen wrench with the 3lb sledge. A long breaker bar just tries to flip the unit and a torch will melt needed things.
Thanks! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Dec 31, 2020 1:00 pm Post subject: Re: The Roach |
Bought a HF 17mm 1/2" drive allen wrench. Figure if it breaks while doing the job, it was worth the sacrifice. 4ft breaker bar and the transmission strapped to the table finally got it to move! Now, the PB Blaster soak... _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Dec 31, 2020 11:18 pm Post subject: Re: The Roach |
Oh the joys of custom things...
I was hoping to get the new subframe mounted to the IRS transmission tonight, but...
vwfye Samba Member
Posted: Fri Jan 01, 2021 1:04 am Post subject: Re: The Roach |
My goal was to have my subframe together, before New Years... 14 minutes to spare! Nothing is torqued, tightened or cleaned up, but it is installed!
Good night! _________________ 64 No'back Speedster "Pearl"
Jason37 Samba Member
Posted: Fri Jan 01, 2021 12:03 pm Post subject: Re: The Roach |
vwfye wrote: |
Good night! |
That’s a win! |
Posted: Fri Jan 01, 2021 9:01 pm Post subject: Re: The Roach |
Jason37 wrote: |
vwfye wrote: |
Good night! |
That’s a win! |
Agreed. Who knows, we might see this car sitting on all 4 tires and an engine getting stuffed soon. Now that would be a huge goal to see completed. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sun Jan 03, 2021 7:09 pm Post subject: Re: The Roach |
Never, ever, live in a house while it is a construction zone AND try and build a VW.
That is all... _________________ 64 No'back Speedster "Pearl"
Posted: Mon Jan 04, 2021 3:47 pm Post subject: Re: The Roach |
vwfye wrote: |
That is all... |
I learned that lesson last year...the car lost to the house every time. Something that should have taken a couple of weeks is now coming up on a year. |
vwfye Samba Member
Posted: Sun Jan 10, 2021 12:54 pm Post subject: Re: The Roach |
Yesterday, I spent hours trying to solve an issue with the rear shocks not fitting in the lower pockets. All kinds of complicared things... none cheap or off a shelf. Grrrr...
Then, after hours of looking for parts, I found the answer and it was so... simple. Doh! Raise the bolt hole at the pocket for the lower shock eye. Ah-ha! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Jan 11, 2021 11:11 pm Post subject: Re: The Roach |
So, my shocks didnt fit the lower shock mounts... panic! After hours of complicated or expensive or both solutions... doh!!! Raise the bolt holes in the mounts. Doh! Doh! Doh! That with shorter springs should let my rear ride height as wanted.
Posted: Tue Jan 12, 2021 12:15 pm Post subject: Re: The Roach |
vwfye wrote: |
Looks good. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Jan 16, 2021 10:08 pm Post subject: Re: The Roach |
Did you know that a t3 IRS transmission does NOT have mount holes in it to mount it to frame horns?
I do now! Doh!!! _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jan 17, 2021 10:38 am Post subject: Re: The Roach |
vwfye wrote: |
I do now! Doh!!! |
Yup, the holes are either filled by aluminum "plugs" or aren't drilled at all. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sun Jan 17, 2021 10:49 am Post subject: Re: The Roach |
Just one more issue I wasn't aware of. I will see if there are plugs or I will have to drill. _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jan 17, 2021 11:33 am Post subject: Re: The Roach |
vwfye wrote: |
Just one more issue I wasn't aware of. I will see if there are plugs or I will have to drill. |
That's how you tell if it's a genuine type 3 IRS trans, complete with T-3 gearing. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Jan 17, 2021 12:37 pm Post subject: Re: The Roach |
The 4 mounts on my IRS transmission looks like they are filled with lead? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
