vwfye Samba Member
Posted: Sat Aug 21, 2021 1:14 pm Post subject: Re: The Roach |
Installed front fenders wiring included, hood pins and rear polycarbonate window today.
_________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Bobnotch Samba Member
vwfye Samba Member
Posted: Sun Aug 29, 2021 1:06 am Post subject: Re: The Roach |
When i can afford it _________________ 64 No'back Speedster "Pearl"
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
vwfye Samba Member
Posted: Sun Aug 29, 2021 10:08 am Post subject: Re: The Roach |
Nope. Not track legal yet. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Sep 01, 2021 11:05 pm Post subject: Re: The Roach |
The day I brought it home:
Now:
Done? No... but much closer to being something! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Sep 02, 2021 10:50 pm Post subject: Re: The Roach |
Next is adding a tab where circled to keep the fender off the rear of the 8 inch wide slicks.
vwfye Samba Member
Posted: Fri Sep 03, 2021 3:12 pm Post subject: Re: The Roach |
I was having tire rub issues backing the red car up. Thought it was both sides...come to find out, the right side was almost 1.5" inboard! This is the same side that I had to reshape the rear fender around the light. Just got it all squarish again. No more rub!
I am very glad I happened to start on that side. Also, that car had negative camber and was rubbing. I raised the rear about an inch to lesson this a bit and still no rub. It was a good day!
Posted: Sat Sep 04, 2021 6:03 pm Post subject: Re: The Roach |
vwfye wrote: |
Or you could have added a 1 inch strip of metal to the inner wheel well lip (the John J. method) of getting wider tires to fit in the rear. Looks good though if you fixed it correctly. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Sep 04, 2021 6:14 pm Post subject: Re: The Roach |
That was the plan initially, but it all fits with these wheels' offset. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Oct 05, 2021 9:16 am Post subject: Re: The Roach |
Next up is sorting out the front tie rods and coilover shocks on the T1 beam conversion for racing. I think I will start with 2000lb springs and see if they can support the nose with driver in the car. Race height is only 4 inches to the bottom of the beam... so things all change, even the tie rod length gets much shorter. _________________ 64 No'back Speedster "Pearl"
Posted: Tue Oct 05, 2021 4:09 pm Post subject: Re: The Roach |
vwfye wrote: |
Next up is sorting out the front tie rods and coilover shocks on the T1 beam conversion for racing. I think I will start with 2000lb springs and see if they can support the nose with driver in the car. Race height is only 4 inches to the bottom of the beam... so things all change, even the tie rod length gets much shorter. |
Any pics of it? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Tue Oct 05, 2021 4:17 pm Post subject: Re: The Roach |
Nada _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Oct 14, 2021 11:45 pm Post subject: Re: The Roach |
Ended up ordering new tie rods. Seems I have late BJ spindles and dog bone with early ball joints. That's a failure waiting to happen... so, just waiting for the new to arrive. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Oct 15, 2021 9:56 am Post subject: Re: The Roach |
Realized I will need to go to a 22x4x15 front runner tire to avoid rub at the height I want the nose at on the track. It's just money and time, correct? _________________ 64 No'back Speedster "Pearl"
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Sat Oct 16, 2021 11:16 am Post subject: Re: The Roach |
W1K1 wrote: |
I know the superbeetle spoiler certainly helps at high speeds to keep mine stable
Yeah, but does he have the horse power to push it? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Oct 16, 2021 11:10 pm Post subject: Re: The Roach |
Not sure I want one on a drag car. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Oct 26, 2021 11:15 am Post subject: Re: The Roach |
The tie rods finally arrived! There is supposed to be a break in the rain later this week, so... We will see if my toe in/out can be remedied! If that happens, I will finally start to see some light at the end of the tunnel. Woot! _________________ 64 No'back Speedster "Pearl"
