Two Glove Boxes Samba Member
Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 246 Location: Cambridge UK
Posted: Sat Apr 10, 2021 3:49 am Post subject: Re: 1959 Mango walkthru metal rehab. |
German Krew wrote: |
Isn't it funny when you hear people say at shows their VW is rust free when anyone that has done the metal work really knows rust hides everywhere.
I think they mean that the rust is free, ie the rust comes for no extra charge, |
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Sat Apr 24, 2021 2:32 am Post subject: Re: 1959 Mango walkthru metal rehab. |
I got the e brake lever in and would like someone to confirm that the angle is correct. Does this look right?
All comments are appreciated!!!
Thanks |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Sat Apr 24, 2021 6:23 am Post subject: Re: 1959 Mango walkthru metal rehab. |
I've never considered the difference having an early walk through with the shifter further back. It's just right there in the middle of the walk through!
I don't know the correct angle of the e-brake and I'm sure someone will beat me to getting the info you need but I've got to say, I love the look of the early crooked e-brake. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Sat Apr 24, 2021 6:35 am Post subject: Re: 1959 Mango walkthru metal rehab. |
Okie Adam wrote: |
I don't know the correct angle of the e-brake and I'm sure someone will beat me to getting the info you need but I've got to say, I love the look of the early crooked e-brake. |
Me too! The straight shifter set back by the seat is really cool too! |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sat Apr 24, 2021 6:53 am Post subject: Re: 1959 Mango walkthru metal rehab. |
The E Brake handle in Sept 58 straight shifter Kombi.
Factory position. Looks like about six or seven degrees off of vertical.
Looks like yours is angled a little too much to the passenger side.
If I run a straight edge up from mine, the line intersects the dash at the bottom of the second full vertical slit to the right of the radio hole.
Yours looks like it intersects at the bottom of the fourth vertical slit. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Sat Apr 24, 2021 6:59 am Post subject: Re: 1959 Mango walkthru metal rehab. |
Riff Raff wrote: |
Yours looks like it intersects at the bottom of the fourth vertical slit. |
Oh wow! Excellent information! Looks like I’m going to persuade it over a bit.
Much appreciated Riff Raff! |
Posted: Sun May 23, 2021 3:07 am Post subject: Re: 1959 Mango walkthru metal rehab. |
It’s been a while since I updated the thread. Progress has been made but still more to do. I finished up the nose:
I got the heat log in (I missed taking a picture of it installed (looks like a heat log))
I fixed the rot above the cargo doors:
Now I’m trying to fix the roof:
It’s been a challenge trying to stay focused and make time for everything but this bus will get worked on sooner than later. |
Posted: Wed Jul 07, 2021 10:31 am Post subject: Re: 1959 Mango walkthru metal rehab. |
I have been picking away at the bus. I am making progress now. I feel like I'm getting close to the finish line. I plan to make a punch list soon. For now, I have the roof 95% done:
I made a spare tire tray and welded it in:
I welded up a bunch of holes on the luggage tray:
I welded the E brake mount in place (6 degrees from vertical. Thanks Riff Raff!)
I smoothed out the long rocker:
I also master coated inside the engine compartment and one of the wheel wells. I am working on the heat ducting now. I want to put the piece that goes from the cab floor to the windshield in first, but it is rusted solid. I have been soaking and scraping but it's still not moving. It will though. I know it wants to. |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Wed Jul 07, 2021 2:37 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
you work is inspirational! _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Wed Jul 07, 2021 2:39 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
zuggbug wrote: |
you work is inspirational! |
I’m living my dream and still having a blast!
Thanks zuggbug! |
boulderz Samba Member
Posted: Sun Jul 11, 2021 6:02 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
Will be awesome to see this one with welding complete and where it goes next. Killer work.. |
Posted: Tue Jul 13, 2021 8:42 am Post subject: Re: 1959 Mango walkthru metal rehab. |
boulderz wrote: |
Thanks boulderz! |
Posted: Tue Jul 13, 2021 8:46 am Post subject: Re: 1959 Mango walkthru metal rehab. |
Matt C has been up for the last few days working on his bus (while I was gone camping and fishing and having fun (sorry Matt!)) The bottom is all Master coated now. There are a few spots that need welding, and the cable tubes and heat ducts need to be put on. We are trying to wrap up the bottom and get this bad boy back on the ground!
Posted: Mon Jul 26, 2021 11:48 am Post subject: Re: 1959 Mango walkthru metal rehab. |
I am attempting to finish off the underside of the bus now. I put in all of the cable tubes, and am now working on the heater ducts. Once this is done we will touch up the bare spots with Master coat before we put the grey underneath. I am not sure if there is an easy way to install the tubes or the heat ducts. I definitely chose the most difficult way possible.
Posted: Mon Aug 02, 2021 9:07 am Post subject: Re: 1959 Mango walkthru metal rehab. |
One more piece to the puzzle knocked out:
once this bad boy is installed, the bottom will be ready to finish off! i can't wait to see some grey!!! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Aug 02, 2021 12:09 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
here is you a question from a non-expert (that would be me): would it make sense to zink metal spray pitted metal like this prior to applying a permanent finish like a powedercoat? Seems like it would both, prevent rust, and also fill in the pits?
not exactly sure of the actual terminology, but i mean spraying it with molten zinc. _________________ regards
Uli
Posted: Mon Aug 02, 2021 12:17 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
mandraks wrote: |
here is you a question from a non-expert (that would be me): would it make sense to zink metal spray pitted metal like this prior to applying a permanent finish like a powedercoat? Seems like it would both, prevent rust, and also fill in the pits? |
Probably would. The silver Master Coat that I have been using is very thick and actually does fill in the pits. It can be sanded to a smooth finished base prior to painting. The powder coating that I have done in the past (as a hobbyist) shows everything underneath. I bought some lab (lap)? Metal from Eastwood which is like a metal paste that withstands the 400 degrees temperature when baking the powder. It’s like metal bondo. The Master Coat would melt and smoke in the oven. |
Posted: Wed Aug 11, 2021 9:33 am Post subject: Re: 1959 Mango walkthru metal rehab. |
The underside is ready for paint:
zehbeh Samba Member
Joined: February 16, 2008 Posts: 249 Location: Stuttgart
Posted: Wed Aug 11, 2021 11:34 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
wow. thats a great and clean looking underside. Keep on the good work. |
