firerod Samba Member
Joined: September 01, 2014 Posts: 37 Location: United States
Posted: Fri Aug 27, 2021 1:25 pm Post subject: Muffler with oil filter/pump |
I am building a 1776sp with single carburetor. I have a oil pump with the screw on filter. Does anyone know what stock style muffler will clear the filter? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Fri Aug 27, 2021 1:43 pm Post subject: Re: Muffler with oil filter/pump |
I just built a 1776 and the filter/pump pushed the pulley tin into the pulley so I had to grind off a good amount of the pump cover for it to fit. _________________ Glenn
Member #1009
#BlueSquare |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 572 Location: South of Raleigh
Posted: Fri Aug 27, 2021 2:50 pm Post subject: Re: Muffler with oil filter/pump |
Someone can correct be if I'm wrong, but I think the main issue is if it has the extra pipe for the heat riser system? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Fri Aug 27, 2021 5:52 pm Post subject: Re: Muffler with oil filter/pump |
johnnyvw164 wrote: |
This is correct.
I searched for a muffler with the heat riser tube connected to the right side. Then down into the right side exhaust outlet. They are made. But hard to find.
I managed to find a Leiristz. It wasn't cheap.
But it did fit the engine like a NOS part would. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 851 Location: South Florida
Posted: Fri Aug 27, 2021 6:15 pm Post subject: Re: Muffler with oil filter/pump |
67rustavenger wrote: |
This is correct.
But it did fit the engine like a NOS part would. |
Early stock mufflers ran the tube out left peashooter, the switch to right was 1971-72, based on Wolfsburg West part numbers 113251053AJ & 113251053AK.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113251053AJ |
windfish Samba Member
Posted: Fri Aug 27, 2021 7:25 pm Post subject: Re: Muffler with oil filter/pump |
fwiw, both of these Dansk mufflers from wolfsburgwest have the exact same part number (113251053AK), bought a few years apart.
The older one interfered with the filter pump, the newer one worked fine.
I emailed wolfsburgwest and they confirmed:
"Thank you for the email.
The current muffler does have the preheat tube on the passenger side of the car, thus allowing you to be able to mount the oil filter as shown.
Old production were opposite as you are verifying yourself." |
Posted: Sat Aug 28, 2021 6:46 am Post subject: Re: Muffler with oil filter/pump |
Thank you for the replies and part number. I will get the one with passenger pre-heat. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Aug 28, 2021 7:46 am Post subject: Re: Muffler with oil filter/pump |
US (non california) bugs in 73/74 went to an EGR system with its filter and plumbing on the left side...so the heat riser pipe was moved to the right side...so these were the go- to muffler for filter/pump combos...of course the hole where the EGR tubing hooked up needed to be plugged or welded up...in the second pic windfish posted you can see the stub for the EGR pipe sticking out of the side of the #4 exhaust pipe just behind the box for the paper heater hose hookup....it would have been a 113 251 053 AQ, not an AK...but was probably sold as an AK "supercession" since theoretically it would still fit the earlier cars |
glutamodo The Android
Joined: July 13, 2004 Posts: 26310 Location: Douglas, WY
Posted: Mon Aug 30, 2021 4:14 am Post subject: Re: Muffler with oil filter/pump |
According to VW they changed to a right side preheat pipe for model year 1972...
_________________ Andy T.
