Small white hose under van dripping water. Do you know what that
Forum Index -> Eurovan Share: Facebook Twitter
mcbbcn
mcbbcn is offline
PostPosted: Tue Jun 30, 2020 12:17 pm    Post subject: Small white hose under van dripping water. Do you know what that Reply with quote
Hi,
I noticed a small white hose dripping water under my 99 camper van. Do you know what is it? And how do I stop it?
Thank you
Abscate Premium Member
Abscate is offline
PostPosted: Wed Jul 01, 2020 8:43 am    Post subject: Re: Small white hose under van dripping water. Do you know what that Reply with quote
drain from a fridge perhaps?
.ssS!
Broseph Stalin
Broseph Stalin is offline
PostPosted: Wed Jul 01, 2020 10:48 am    Post subject: Re: Small white hose under van dripping water. Do you know what that Reply with quote
I bet that is the fresh water system drain for winterizing. Check inside the pantry cabinet and see if the valve is partially open. Might have to replace the valve.
'68 Bus in West Germany, 1977-1979
'67 Riviera poptop conversion in the US, 1984-1990
'95 EVC Winnie, 2018, Sold
'03 EVC Winnie, 2018, Sold
mvaska
mvaska is offline
PostPosted: Thu Jul 02, 2020 1:35 pm    Post subject: Re: Small white hose under van dripping water. Do you know what that Reply with quote
that's exactly what it is. turn on the pump and you'll see lots of water if the valve in the cabinet is open/broken in the slightest
mcbbcn
mcbbcn is offline
PostPosted: Sat Jul 04, 2020 2:18 pm    Post subject: Re: Small white hose under van dripping water. Do you know what that Reply with quote
Thank you so much! The valve was open. I must have left it open after winterizing the pipes and left it open to avoid freezing. I appreciate the pointers! Thanks everyone!
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
