sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Tue Jun 30, 2020 7:15 pm Post subject: Re: How can I fix this leak...? |
I believe the kits come with two paper gaskets because the same kit is used on Buses of the era but Buses use both paper gaskets because of the reduction gearboxes that Beetles don't have. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jun 30, 2020 5:41 pm Post subject: Re: How can I fix this leak...? |
… even with new seals, my newly re-done ass leaked - twice - so, I asked a friend for a real-good axle bearing and he gave me a nice NOS one and I re-built that whole sucker again - that was at least 5 years ago - that was it! Needed a new bearing - the race was worn... on the '60 SC
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
cb1990s Samba Member
Posted: Tue Jun 30, 2020 5:24 pm Post subject: Re: How can I fix this leak...? |
Thanks. Have looked at videos. Was wondering why the kits come with two paper gaskets when all the vids seem to show one used in install. |
gt1953 Samba Member
Posted: Tue Jun 30, 2020 5:01 pm Post subject: Re: How can I fix this leak...? |
In your photo behind the wheel showing the oil spray, the oil is coming from the weep hole at the bottom where the axle meets the backing plate. Clean all of the oil off, drive it for a few days then reinspect. Do look at the videos. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Jun 30, 2020 2:54 pm Post subject: Re: How can I fix this leak...? |
Where exactly is the rear ‘axle’ seal? From what I’ve been reading it does indeed seem that there is in fact no paper gasket seal behind where the axle bolts onto the backing plate. All the seals and sealing components are in the front. |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 348 Location: Noblesville, IN
Posted: Tue Jun 30, 2020 2:43 pm Post subject: Re: How can I fix this leak...? |
Bad rear axle and/or hub seals. Do them them both -- http://www.vw-resource.com/rear_seal.html _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
Posted: Tue Jun 30, 2020 2:03 pm Post subject: How can I fix this leak...? |
What’s the cause of this leak? I’m 95% sure it’s transmission oil as it smells when I wiped some on my finger and smelt it (so not brake fluid). But why is it leaking out the back...? I have read that there isn’t a gasket on the rear of the plate, only inside the hub... this diagram
seems to show that too.
I have bought a new rear hub seal kit to replace that but do I need to take the whole hub off to address the leaking behind it...? And will I need to remove the brake cylinder fully for that? Thanks.
