Whaanga Samba Member
Joined: May 07, 2016 Posts: 628 Location: Rochester, NY
Posted: Fri Jul 03, 2020 5:03 pm Post subject: Fuel hose at tank inlet |
Hello,
It’s time to change my fuel hoses. I installed the ones on the bus four years ago and driven about 7,000 miles. Per recommendations here I used Gates Barricade hoses and have run non-ethanol gasoline. (Except for the last few full ups).
I’m curios to see/learn how others have attached the fuel line to the 90* inlet on the bottom of the tank. You can see from the photo that I have two clamps. For whatever reason, when I installed just the fuel injection clamp, I got a little leakage at the inlet. But when I add the other circle clamp, there is no leakage - and it’s been dry for the past four years. (Maybe I have the clamp too tight.) If I recall correctly, there is no barb on the 90* inlet, plus I wonder why VW used this type of angled configuration?
As always, I’m grateful to learn from the collective wisdom here.
Thank You,
Jeff _________________ Late 1973 Bay w/a transplanted 914 Engine |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Jul 03, 2020 8:19 pm Post subject: Re: Fuel hose at tank inlet |
You don’t need to change those hoses _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Sat Jul 04, 2020 3:04 pm Post subject: Re: Fuel hose at tank inlet |
Is that a carb tank? FI has an outlet and inlet.
If you are going to drain the tank and replace those, clean the screen. That said, that is a low pressure line and the Gates line will last a very long time. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jul 04, 2020 3:09 pm Post subject: Re: Fuel hose at tank inlet |
The angled outlet is the aftermarket replacement version, the OG one pointed straight down and was shorter. I don't know why they weren't beaded, although none of the other fittings in the system were either. If it bugs you wrap a ring of solid copper wire around the pipe near the end and solder it on, instant bead (not while on the tank of course). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
