klcarrie Samba Member
Posted: Fri Jul 10, 2020 9:24 am Post subject: Is this Throtte Plate Broken? |
Hi all,
I'm interested in purchasing a set of NDIX 32 carbs from an Ebay seller.
The seller sent images of an "NOS" NDIX 32 carb for my review.
I would like to confirm the condition of the cast throttle plate.
Is it broken?
Image attached.
Thanks,
Kevin
These Images below are uploaded after first response.
_________________ Pritchin'
Currently looking for:
- Bay Bus Pinion Nut Socket
- 64-67 big nut (rear) drums and brake parts, 46mm axle nuts (Big Nuts)
'55 Wolfburg Pannel Project
'55 Wolfsburg SC Project
'71 Westy
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Fri Jul 10, 2020 9:30 am Post subject: Re: Is this Throtte Plate Broken? |
No it's not broken but that might be a aftermarket 32ndix rather than a oem Zenith. Not sure if the originals had the balance slot or not. Could also be the cold start enrichment feed. Been a long time since I Looked at one. |
vwoldbug Samba Member
Posted: Fri Jul 10, 2020 2:11 pm Post subject: Re: Is this Throtte Plate Broken? |
Is that slot for single carb application. |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Sun Jul 12, 2020 4:36 pm Post subject: Re: Is this Throtte Plate Broken? |
These zenith carbs with the split are not broken ...these where used for a single manifold most vw engine in the 60s used these types of carbs for there engines also porsche 356 industrial engines also used a single zenith like these here's a add of a vw single zenith manifold just so you get the idea 👇👇👇👇
https://www.thesamba.com/vw/classifieds/detail.php?id=2383041 |
Posted: Sun Jul 12, 2020 4:53 pm Post subject: Re: Is this Throtte Plate Broken? |
Thanks all! _________________ Pritchin'
'71 Westy |
Dan Ruddock wrote: |
There is no Aftermarket zenith unless you can say porsche are after market .. reason I say is these zenith carbs were first used in the late 1930s and 40s the french flathead engine used these carbs porsche in the 50s started testing these on there engine and notice they worked so porsche bought the rights and castings.. the early zenith castings would have had made in France over the years others have bought the rights since porsche wasn't using them anymore .... so let's just say these are not authentic porsche 356 zenith carbs since other manufacturers used the same castings /rights..... |
saddlesore1 Samba Member
Posted: Wed Jul 15, 2020 10:52 am Post subject: Re: Is this Throtte Plate Broken? |
These are definently not NOS (New Old Stock) based on the dirt and grime. They have been use for sure.
I would say they are not original to Porsche. If you would like a photo comparison let me know. I have originals in my cabinet since i am running Webers (they are way more reliable) |
blood Samba Member
Joined: October 01, 2015 Posts: 50 Location: nashville tn
Posted: Fri Jul 31, 2020 6:24 pm Post subject: Re: Is this Throtte Plate Broken? |
Never seen a 356 with Zeniths that had starter pull levers but my 1973 Styer Puch Daimler Pinzgauer has a pair of 32ndix carbs that do run them. You should recheck the I’d numbers on your carbs as there may other internal differences. |
Posted: Sun Feb 28, 2021 9:39 pm Post subject: Re: Is this Throtte Plate Broken? |
Thanks all for the info.
Seller was not amicable to authenticate NOS claim.
Went with these instead:
https://www.thesamba.com/vw/classifieds/detail.php?id=2399392
For a VW application. The rebuilder's attention to detail is high, so I'm looking forward to introducing the setup to a stock to mildly engrossed Type 1 application. _________________ Pritchin'
'71 Westy |
