sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Sat Jul 11, 2020 11:10 am Post subject: 914 trans mounts replace? |
I assume these are shot? replace? thoughts ?
_________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Sun Jul 12, 2020 7:50 am Post subject: Re: 914 trans mounts replace? |
ok then I'm getting crickets dumb ? I assume I'm changing them. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Mon Jul 13, 2020 11:15 am Post subject: Re: 914 trans mounts replace? |
you have to remove to see if the center is cracked. If so new ones are a dime a dozen |
Posted: Mon Jul 13, 2020 4:39 pm Post subject: Re: 914 trans mounts replace? |
I took them off ya they are cracked . new one's are on the way. thanks _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Thu Jul 16, 2020 12:30 pm Post subject: Re: 914 trans mounts replace? |
replaced with 911 mounts fronts where fine. no more jumping around.
64 crew cab
55 rag top beetle
66 beetle
69 GVert Samba Member
Joined: October 20, 2014 Posts: 61 Location: San Jose, CA
Posted: Wed Sep 30, 2020 1:09 pm Post subject: Re: 914 trans mounts replace? |
That relay looks like it was installed pretty well.
I once left the relay hanging from the wires and left the 914 in the rain. It started cranking on its own, so I had to disconnect the battery until I could dry out the relay and get it mounted properly. I call that car Christine... _________________ Aircooled? Drive one a day, that's all I ask! |
