jeffinohio Samba Member
Joined: February 02, 2017 Posts: 197 Location: Scio Ohio
Posted: Tue Jul 14, 2020 6:47 am Post subject: Correct distributor help for 1970 Bug |
Car has a 1600cc single port with a 30pict 3.Came with an 009, want to put the correct svsa distributor back on.Can anyone help me find one?Thanks. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31272 Location: Hot Arizona
Posted: Tue Jul 14, 2020 7:05 am Post subject: Re: Correct distributor help for1970 Bug |
Manual transmission _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15976 Location: North Florida, USA
Posted: Tue Jul 14, 2020 7:55 am Post subject: Re: Correct distributor help for1970 Bug |
I believe the table above that Cusser posted is from glutamodo. Here's another table from glutamodo which includes 30Pict-3 carbs:
You need to look at the base flange# on your carb and match it to either table. This stamped number is normally on the side of the base of the carb, but from the chart it says yours may be on the bowl. Find this number and compare with the table to see the matching distributor model#. Look for something like this on your Solex carb:
While I agree that the 205T is the correct match for the "VW 226-1" stamped manual transmission 30Pict-3 carb but this does NOT mean the 205T will work with the autostick version of the carb which was designed to work with the 205AA, 205AD or 205AE distributors. Which carb do you have? You may not have the original carb that came with your manual transmission. Match the distributor to the carb... not the transmission. _________________ AshMan40
Posted: Tue Jul 14, 2020 8:44 am Post subject: Re: Correct distributor help for1970 Bug |
Thanks all,I will check for the carb number after work. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Tue Jul 14, 2020 9:00 am Post subject: Re: Correct distributor help for1970 Bug |
Jimbug57 wrote: |
I think you're looking for 113 905 205 T - that's vacuum and mechanical.] |
The 113 905 205T is not vacuum and mechanical, it's vacuum only. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Jul 14, 2020 9:46 am Post subject: Re: Correct distributor help for1970 Bug |
mukluk wrote: |
Jimbug57 wrote: |
The 113 905 205T is not vacuum and mechanical, it's vacuum only. |
adva is correct for this carb I believe. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Posted: Tue Jul 14, 2020 9:47 am Post subject: Re: Correct distributor help for 1970 Bug |
Svsa. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Tue Jul 14, 2020 9:48 am Post subject: Re: Correct distributor help for 1970 Bug |
FYI... there's an button in the upper right. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jul 14, 2020 11:15 am Post subject: Re: Correct distributor help for 1970 Bug |
Glenn wrote: |
FYI... there's an button in the upper right. |
thanks Glen.Never noticed it. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
riceca Samba Member
Posted: Tue Jul 14, 2020 11:20 am Post subject: Re: Correct distributor help for 1970 Bug |
113 905 205 T is the correct one. If you are looking for a match for your "B6" engine https://vwnos.com has some. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6558 Location: Houston, Texas
Posted: Tue Jul 14, 2020 5:25 pm Post subject: Re: Correct distributor help for 1970 Bug |
113 905 205 T should work well. You can of course use many different distributors in combination with that carburetor.
If you have a 1600 single port and plan to stay with a single port then that is the way to go. If you ever go to dual port you will do better with a 34 PICT 3 and an SVDA or a DVDA. _________________ www.vwnos.com [email protected]
wcfvw69 Samba Purist
Posted: Wed Jul 15, 2020 2:02 am Post subject: Re: Correct distributor help for 1970 Bug |
The 113905205T SVA distributor is excellent after restoration. You need to make sure the vacuum canister holds vacuum as well.
This distributor is one of my top sellers. I run one on my 1969 bug too. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jul 15, 2020 4:20 am Post subject: Re: Correct distributor help for 1970 Bug |
riceca wrote: |
Thanks everyone.Just ordered one from vwnos. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
