charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Sun Jul 19, 2020 11:28 am Post subject: Clutch linkage |
I pulled the engine today and saw this. Wtf is going on here. Missing a part? Everything works, but I’d rather put the right part in.
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9808 Location: Mt Lemmon, AZ
Posted: Sun Jul 19, 2020 11:51 am Post subject: Re: Clutch linkage |
I don't think anything is missing but the position of that arm doesn't look right to me.
Possibly someone added the Craftsman socket to take up a gap caused by an internal problem? |
westydriver Samba Member
Joined: July 08, 2017 Posts: 54 Location: Eastside of Nebraska
Posted: Sun Jul 19, 2020 12:00 pm Post subject: Re: Clutch linkage |
I'm one for half assin a job but that is next level genius. |
Posted: Sun Jul 19, 2020 12:32 pm Post subject: Re: Clutch linkage |
@halfassinvanagonassasin did the work I think.
Anyone have any idea what internally would cause this to sit like that? |
Vanagon Nut Samba Member
Posted: Sun Jul 19, 2020 1:11 pm Post subject: Re: Clutch linkage |
stock engine/flywheel?
Slave cylinder looks like a newer aftermarket type? Issue there? Posts here of that possibility? I seem to recall that there was a fairly recent post about clutch slave travel.
Failing forks at clutch cross shaft?
Air in hydraulics?
It would be nearly impossible to install the operating lever indexed incorrectly.
The cross shaft bushings (outer) would have to be incredibly worn out to allow lever to sit further down, were that even possible.
1988 West DIY 50º ABA
VE7TBN |
old_man Samba Member
Joined: June 19, 2018 Posts: 1381 Location: Newfoundland
Posted: Sun Jul 19, 2020 1:32 pm Post subject: Re: Clutch linkage |
Vanagon Nut wrote: |
I believe the thread you remember was about the wrong lever being installed. Two kinds out there that index differently.
Edit: 251 141 713 B for gas, 251 141 713 C for diesel. |
Posted: Sun Jul 19, 2020 2:00 pm Post subject: Re: Clutch linkage |
old_man wrote: |
I seem to recall that there was a fairly recent post about clutch slave travel. |
Thanks. That may well be. This may be the thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=738721&highlight=clutch+lever+length _________________ 1981 Westy DIY 15º ABA
VE7TBN |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Sun Jul 19, 2020 3:01 pm Post subject: Re: Clutch linkage |
There's my socket. Wondered where it got to. Now I can stop wondering about where it went. _________________ ☮️ |
Posted: Sun Jul 19, 2020 5:01 pm Post subject: Re: Clutch linkage |
I don’t know what’s stock and what’s not (stock aircooled). Recommend taking the trans out and checking it out?
Ran fine when I was driving it around |
Posted: Mon Jul 20, 2020 9:12 am Post subject: Re: Clutch linkage |
Ok. I'd wondered that if the engine was not stock and used an adaptor plate, (especially a home made plate), would that plate thickness affect distance of clutch pressure plate fingers to throw out bearing.
VE7TBN |
Viva.Sabata Samba Member
Posted: Mon Jul 20, 2020 11:04 am Post subject: Re: Clutch linkage |
I think you’re missing the bolt that made up the distance between the socket and the plunger. And, yeah, I thought I might’ve been my missing socket too, but it’s not 10mm 😜😜😜
I’ve actually done this on a wearing clutch disk when I was 17. It lasted about a week before I was replaced it. I agree - tear it down now before you get stranded somewhere _________________ Sabata
1987 Westy Full Camper, Peloquin 5-Speed 2wd |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Jul 20, 2020 9:30 pm Post subject: Re: Clutch linkage |
There are two different lengths of slave cylinder push rods. _________________ Schau in das Buch |
Posted: Wed Jul 22, 2020 7:35 am Post subject: Re: Clutch linkage |
dgbeatty wrote: |
There are two different lengths of slave cylinder push rods. |
example?
What years had the different ones? Which ones is shorter/longer? |
