harrymarlin Samba Member
Joined: June 07, 2018 Posts: 723 Location: Washington, DC
Posted: Mon Jul 20, 2020 10:41 am Post subject: Hinge cap, plug, or cap nut? |
Looking at my early 67 convertible, there is nothing over the door hinges - not a cap or plug. What should be there, and what color (transparent or black, if plastic) - and does anyone have a picture? My parts guide suggests the following, which, as you may see, suggests, for mine (and any from 1/59 - 12/66), there should be one Cap - where would that be?).
113 831 433 Cap nut — Hinge pin 111 831 423/A/B, up to Chassis No. 2 149 709 (1)
111 831 433 A Cap — Hinge pin 111 831 423 C/D/E, from Chassis No. 2 149 710 up to 117 999 000 (1) [HPM: Note, I can't find this part!]
311 831 439 A Plug — Door hinge
from Chassis No. 117 496 034 up to 117 999 000 (3)
from Chaisis No. 118 000 001 (4)
1/67 - 043 grey-black
1/67 - 908 transparent
Thoughts? _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Mon Jul 20, 2020 1:07 pm Post subject: Re: Hinge cap, plug, or cap nut? |
Early 67's (up to 12/66 by your chart) had the same hinges as earlier cars, that is a flat top hinge pin you lubricated through a slot in the top finger like this
They look the same as 66 and earlier
Late 67-> up VW went to a shorter hinge pin leaving a recess in top covered by a clear plastic cap
The early clear caps deteriorated quickly, turning yellow and will typically crumble when you removed them.
Not sure when they changed but later cars had black caps that stood up better to UV rays. _________________ -Bruce
An ounce of prevention is worth a pound of cure.
Posted: Mon Jul 20, 2020 1:11 pm Post subject: Re: Hinge cap, plug, or cap nut? |
61SNRF wrote: |
Early 67's (up to 12/66 by your chart) had the same hinges as earlier cars, that is a flat top hinge pin you lubricated through a slot in the top finger |
So, because they were flat, the early 67s (and earlier cars) did not have any hinge cover? When a passenger side mirror was added, was the hinge changed out, then?
Thanks! _________________ -Harry
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Mon Jul 20, 2020 1:45 pm Post subject: Re: Hinge cap, plug, or cap nut? |
The hinge was changed out for one with threads if the car wasn't fitted with one with the threaded one. I've done it once, I had to hire a VW hinge pin removal tool to do it.
Thanks for the part numbers harrymarlin. Does your bug have the thread sticking out for an accessory mirror, or no thread so it needs a plug?
I have the original cap for my RHD 65 Sedan, pics of it below, I intend on repainting it. I have seen both hinge pins with threads for the accessory mirror, and ones without. For a 1967 convertible I have no idea, but from what you wrote above I would think so. This is the cap, hope it helps, although of no use to you if you need a plug:
fifthcenturycheese wrote: |
_________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury)
cb1990s Samba Member
Posted: Fri Jul 24, 2020 1:27 am Post subject: Re: Hinge cap, plug, or cap nut? |
harrymarlin wrote: |
61SNRF wrote: |
Thanks! |
On my UK 67 (which came from the factory with only a driver side mirror) all of the other hinges have the little caps as described, whereas the drivers side upper hinge - where the mirror is - has the little slot for oiling.
The caps are designed to be removed for lubrication; you’re meant to put a few drops of engine oil in the top and there’s a recess on the side of the pin for it to seep down and lubricate the hinge. The caps are very important to stop water and other muck getting in. |
Posted: Mon Aug 10, 2020 5:19 pm Post subject: Re: Hinge cap, plug, or cap nut? |
I believe this is what I would be looking for for my US spec 67 (NavyGeneral points out the part number on this supports it's a mid year version, but it seems small enough):
http://www.thesamba.com/vw/classifieds/detail.php?id=2267658
If I had a hinge pin, this:
http://www.thesamba.com/vw/classifieds/detail.php?id=1565236
NavyGeneral also pointed out that if the top of the hinge is hard, it most likely doesn't need a cover.
61SNRF Samba Member
Posted: Tue Aug 11, 2020 6:45 am Post subject: Re: Hinge cap, plug, or cap nut? |
You've seen the two examples I've posted above so it's either one or the other.
For best answer post some pics of your hinges in question. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Wed Dec 02, 2020 2:10 pm Post subject: Re: Hinge cap, plug, or cap nut? |
I finally got a chance to look at my hinges, and it looks like they don't need caps (I'm not sure how I got so confused!). They are as 61SNRF noted, above. Thanks for all of the responses! Now I have some hinge caps I don't need.
Posted: Wed Dec 02, 2020 3:23 pm Post subject: Re: Hinge cap, plug, or cap nut? |
For what it’s worth my UK market ‘67 base model (1200) has the hinges with the little plastic caps (and no slot in the hinge itself for oiling) on all but the drivers upper hinge (because the slot is needed there for the threaded pin). My hinges are all original. It shipped with only a single mirror (drivers side) hence no slot on the passenger side upper hinge, nor one of those threaded caps.
The black plastic caps had been painted over on all the other hinges as I’d imagine is quite common, but in reality they are designed to be removed so you can drop some oil on the top of the hinge pin (it is recessed by around 5mm) and then replace the plastic cap.
Posted: Wed Dec 02, 2020 3:26 pm Post subject: Re: Hinge cap, plug, or cap nut? |
That’s what mine looked like - until I poked at the paint and it peeled away to show the plastic cap underneath. However before you anything like that just check that the hinge DOESNT have a slot in it for oiling - if it doesn’t have the slot then it’s got a plastic cap on it and in theory you should remove the paint on top and then you’ll see the little cap that clips in and out for oiling the hinge. It’s your call though - the paint looks nice, and I’m sure spraying at the hinge from both sides with some good penetrating oil will be adequate enough. |
Posted: Fri Dec 04, 2020 1:26 pm Post subject: Re: Hinge cap, plug, or cap nut? |
cb1990s wrote: |
However before you anything like that just check that the hinge DOESNT have a slot in it for oiling - if it doesn’t have the slot then it’s got a plastic cap on it and in theory you should remove the paint on top and then you’ll see the little cap that clips in and out for oiling the hinge. |
Thanks cb1990s! It looks like all of my hinges have slots, so I guess I don't need the covers/caps I thought I did. I appreciate everyone's information in me getting to this understanding! _________________ -Harry
