Nestico18 Samba Member
Posted: Wed Aug 12, 2020 7:00 am Post subject: 1835 Dual Carb Issues and Opinions |
A few years back, I bought a rail with a “rebuilt” 1835 in it. It had dual solex 40/44’s on it. The guy said it sat for a year before I bought it but when it was running, he said it was an animal and ran great. I’m new to these so I’m not sure what the route is to go. I had rebuilt the carbs and messed with tubing them a little bit but it never seemed to run as well as he claimed. It seems pretty sluggish. Someone had told me that these carbs were too big for what I was running. What’s everyone’s opinions or suggestions as to what I should do. I’m sick of seeing it sit and I just want to get it running already before I lose interest in it. |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Wed Aug 12, 2020 7:14 am Post subject: Re: 1835 Dual Carb Issues and Opinions |
You should be able to get it running like an animal again. What you probably need to do is a a complete tune up, valve adjustment, double check all the spark plug wires, points etc and then get your timing right, and thorough cleaning of the carburetors and then clean them again. Confirm that there are no leaks. At the manifolds. And that you have good clean fuel. Then you have to sync and tune the carburetors You could have worn carburetors or fuel pump but my experience has been that thorough cleaning and proper tune up and adjustment will get and old engine back to life. You will have to do some research here on the samba to figure out all that stuff but it isn’t rocket science and can be completed pretty quickly. Welcome to the Samba |
manxvair Samba Member
Joined: January 11, 2011 Posts: 231 Location: Arizona
Posted: Wed Aug 12, 2020 10:53 am Post subject: Re: 1835 Dual Carb Issues and Opinions |
Did you happen to write down the jetting sizes while you were rebuilding them? |
Posted: Wed Aug 12, 2020 7:49 pm Post subject: Re: 1835 Dual Carb Issues and Opinions |
I do not remember what jets are in it, but do you recommend a certain size I should be running? |
dustymojave Samba Member
Posted: Fri Aug 14, 2020 1:14 pm Post subject: Re: 1835 Dual Carb Issues and Opinions |
That dual Solex 40-44 AIS setup is known by the original brand name they were developed and sold under "Kadron".
For best info on that "Kadron" carb setup, I strongly recommend you talk to Jeff Lain at KaddieShack. He specializes in those carbs. His name on the Samba is "57Baja".
http://www.kaddieshack.com/
I have Kadrons on my Baja with an 1835. Because Kadrons sometimes have issues with slosh from the fuel bowl vent into the carb throat, I also have one of Jeff's "HI-FLO™ Off-Road Rough Terrain & HP Enhancement Kit for Kadrons". Jeff was inspired to make those based on his seeing the brass tube I put in my carbs back when he was 1st starting KaddieShack around 2009. Then when the brass tube broke in one of my carbs recently, I went ahead and ordered one of his kits. I liked that the air cleaner mount crossbar is up out of the throat of the carb too.
Jeff can get you rebuild kits and advise you on proper jetting for your engine. Although it sounds like they are already set up for your engine, but may need some rebuild.
Note that modern fuels with alcohol can eat some carb internals and will very quickly turn into thick gooey stinky varnish that will gum up a carb that's been sitting. _________________ Richard
SoCalBajas Member
