SoCalVolks Samba Member
Posted: Fri Jan 06, 2017 7:29 am Post subject: Which Clock is Correct for my 1954 VW? |
Can someone please tell me which clock would be correct for the grill in my 1954 Volkswagen (still 6V)?
I've seen both Perohaus 6V and 8 day wind up. I've also seen the VDO version that does not say Perohaus.
I'd like to purchase one that would have been the correct original accessory.
Thank you! |
AndrewCologne Samba Member
Joined: September 05, 2015 Posts: 71 Location: Cologne
Posted: Fri Jan 06, 2017 9:00 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
Thats the exact same one I have originally in my Feb. 1955 Oval which should match to your '54 model. _________________ 1950 Split Window Grey
1955 Oval Window Stratosilber
1982 Porsche 911 3.0 SC Black |
Posted: Fri Jan 06, 2017 9:07 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
Thank you!!! |
bigdish2 Samba Member
Posted: Tue Feb 06, 2018 1:02 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
My March 54 clock.
_________________ For lastest finds check out
@texasvintagevdubs on Instagram or Facebook
In the stash
1954 & 63 Vert
1956 Dove blue camper
(2) 1958 23w deluxes
1958 PGSG 11w og paint
1958 logo dd panel
1959 dove blue 11w
(5) 15w deluxes
(2) 1960,63,65 double cabs
1963 swr/bg 11w og paint
1964 limo bus 350 powered
1964 SO36 Dormobile flipseat Westy
1966 (2) so42’s og paint
1969 (2) porsche 912s
1969 dart swinger 340
(3) Porsche 911s sunroof,targa,cab |
mbaldwin19 Samba Member
Posted: Fri Jul 27, 2018 10:21 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
I need the glass for the Perohaus 1954/55 clock. I'll buy a junker clock to use the glass, as my clock is in good shape, missing glass.
MikeB |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Fri Jul 27, 2018 5:54 pm Post subject: Re: Which Clock is Correct for my 1954 VW? |
mbaldwin19 wrote: |
MikeB |
Ads should be posted as a WTB ad in the classifieds but I'm going to leave your post in place in case anyone can give you an alternative or knows of a source.
If it's simply glass and what looks like a single hole in it, can someone cut one for you? _________________ How to Post Photos
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Jul 28, 2018 12:39 pm Post subject: Re: Which Clock is Correct for my 1954 VW? |
when I bought my 2/55 there was an 80mm hole, in the dash, to the left of the speedo. I was told it was for a clock - priced a few and were outrageously priced.
One day, at a garage sale, I saw a AA battery clock and it measured 80mm. I got it for a buck and double-side taped it in - looks great and was a buck... keeps great time too.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Matts Bug Parts Samba Member
Posted: Sat Jul 28, 2018 4:04 pm Post subject: Re: Which Clock is Correct for my 1954 VW? |
The short answer to your question is any correct for VW oval beetle clock dated for the period you are comfortable with, you have not mentioned which month your car was built in. There are very few correct 6 volt clocks available but they are out there. I am not sure why, it could be that fewer were made than the mechanical wind-up ones or they were unreliable and tossed when they stopped working or both. Below is an overview of correct clocks as best I know from 20+ years of buying and restoring them, the focus is on the mechanical ones.
At Matt's Parts we only sell correct original oval grill clocks - just because the housing is 80MM does not mean it is a VW clock yet my competitors would have you think that. For some years now most clocks advertised on Samba and eBay are not correct clocks.
Two companies that I know of made correct clocks for ovals with clock faces that match the oval speedometer face: VDO and Kohler.
VDO - the history as I know it.
--The earliest oval grill clocks came out in 1952:--the glass was flat,
--the housing was the deepest so the face could sit lower in the housing held by 3 "long legs" suspended from the housing edge so that clock hands clear the glass
--Numbers and slashes on the faces could have a blue/green tinge to them as opposed to white of the later clocks.
--Hands painted either white or military brown
--Knob is longer than later version-in particular the part of the knob that goes below the glass since the clock face sits lower than later clocks with curved glass. The knob is held onto the shaft by a longer bolt.
--In a few cases the flat glass clock had a knob that screws onto a shaft and the has a heavier set screw.
--earlier production has date stamped into the housing. Some later production units are in tachometer housings and with out date stamps. These were made well into the late 1950's and perhaps into the 1960's..
The later VDO versions:
--the glass was curved,
--the housing was shallower and the face is suspended by 3 "short legs" suspended from the housing edge
--the suspension by short legs concept was abandoned in later production units in favour of the face being held to the clockworks by 2 screws-just like speedo faces.
--Numbers and slashes on the faces are white.
--Knob is shorter than earlier version and uses a shorter bolt.
--Some have Perohaus at 6 o'clock and VDO at 12 o'clock and some just have VDO at 6 o'clock
--date usually ink stamped on back of housing.
All of the VDO-Perohaus clocks have essentially the same clockworks made by Kienzle (There are minor meaningless variances).
Kohler clocks
--For Kohler, I have only ever had two. One was crazy unique: you wound the clock by pulling the knob straight out of the face. A string was attached that recoiled and you wound up the clock by repeatedly pulling out the knob, letting it recoil and repeat.
--I do not know who made the Kohler clockworks but they are TOTALLY different than the Kienzle's in the VDO clocks. |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sat Aug 04, 2018 12:19 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
Think clocks was dealer mounted items, not factory fitted? So it could in theory be whatever. Maybe distributors in other countries had their own suppliers of accessories, that could in theory include clocks. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Posted: Thu Aug 09, 2018 11:31 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
1954 Oval Ragtop Perohaus Clock adventures:
Just acquired pristine resto with grill clock installed. Clock ran very slow and short.
Removed clock, oiled and regulated. Broke crystal on reassembly. New crystals
3" on Ebay, $1.50 each drilled for winder and ground to size in a local crystal repair shop for $15 each. Bought original replacement from Matt's Parts in Edmonton have 2 spares now. This clock runs well as long as it is regulated a bit fast. Too slow and it will stop. Keeping it wound helps as it sometimes has to be taken out to restart with side to side rotation. Reinstalling the crystal is touchy, easy to break. As long as no pressure on glass, bezel can be worked off with small screwdrivers and pressed on with finger pressure only on bezel. Recrimp with small punch smoothed around the circumference. I think many of these clocks have not been oiled since the 50's. Cool to have it running again!
MikeB
Tucson |
karmann77 Samba Member
Posted: Fri Dec 06, 2019 3:31 pm Post subject: Re: Which Clock is Correct for my 1954 VW? |
I’ve just acquired a march 1953 VDO clock and I’ve no idea how you wind it up, I think you just turn the knob but I don’t want to try it without knowing first what to do and which way to turn it? |
bluebeetle1968 Samba Member
Posted: Fri Dec 06, 2019 4:48 pm Post subject: Re: Which Clock is Correct for my 1954 VW? |
EverettB wrote: |
mbaldwin19 wrote: |
MikeB |
If it's simply glass and what looks like a single hole in it, can someone cut one for you? |
If someone can get me the dimensions - I can get them cut for you _________________ Jan 1968 1500cc - The family project! Celebrating 30 years off the road....
June 1957 "Big Window" Oval Beetle! Yes it does really exist.... |
AlteWagen Troll
Posted: Sat Dec 07, 2019 9:51 pm Post subject: Re: Which Clock is Correct for my 1954 VW? |
Kjell Roar wrote: |
Think clocks was dealer mounted items, not factory fitted? So it could in theory be whatever. Maybe distributors in other countries had their own suppliers of accessories, that could in theory include clocks. |
Ive seen birth certificates that list the M code for clock, I think that means factory install.
M912 With 4 chromium plated fender beadings
M918 With leatherette instead of cloth material
M922 Illuminable clock in instrument panel
I found the 922 code on IN2VWS site that is now NLA but was listed from a 58 dealers manual _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Sun Dec 08, 2019 12:44 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
AlteWagen wrote: |
Kjell Roar wrote: |
I found the 922 code on IN2VWS site that is now NLA but was listed from a 58 dealers manual |
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
AlteWagen Troll
IN2VWS Samba Member
Posted: Sun Dec 08, 2019 2:24 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
Oval clock option was also M922.....Seen here in a 10-1955 Salesmans Handbook, and a VW factory M option catalog.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
AlteWagen Troll
Frankvolks54 Samba Member
Posted: Tue Jul 28, 2020 9:15 pm Post subject: Re: Which Clock is Correct for my 1954 VW? |
Where can I buy the clock and grille setup.. Is for a 1954 oval...
Thanks for the help.. |
Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5478 Location: Ovaland, CA
Posted: Wed Jul 29, 2020 11:58 am Post subject: Re: Which Clock is Correct for my 1954 VW? |
Frankvolks54 wrote: |
https://www.thesamba.com/vw/classifieds/detail.php?id=2398640
Here is the clock- Kochs sells the reproduction grills. |
