LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Wed Jul 22, 2020 4:54 am Post subject: Will a 63 lower inner nose strip fit a 67 |
As you can see my lower inner nose strip which holds the front kick panels was removed and not replaced by my body guy over 13 years ago when replacing both the drivers and passengers floor sections. It was mentioned in another thread as I haven't installed Clara's panels yet and didn't spot that missing. A member reached out to me with section from a 1963 bus and it looks similar but I need to know if I should take it or wait till I find a section from a 66-67 bus. I can't imagine how I'll cut that strip out or if I'm wasting time with the process. Should I should just weld in a strip of metal?
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Wed Jul 22, 2020 10:35 am Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
I believe that inner lower nose strip is a part of the floor. I also think that your floor is supposed to sit on top of those bumps. |
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Posted: Wed Jul 22, 2020 10:39 am Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
Do you have a pic with the floor mat out so we can see what is going on with your floor?
Burlyhammer is correct. Lip is part of floor.
If it was my bus I would possibly redo the front floor. It will fix both issues you have. A pic of floor would really help that decision.
Posted: Thu Jul 23, 2020 1:48 pm Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
Does not look correct at all. I'm looking through the build threads for a floor so I can figure it out. Not going to use any of the offered 63 I think I need something else.
Ugh.
Maui Roadsters
Lind wrote: |
Posted: Thu Jul 23, 2020 2:44 pm Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Thu Jul 23, 2020 6:35 pm Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
Burlyhammer wrote: |
Everett picture shows LG's floor is correct for bump location.
Linda you could buy the right side patch, use the channel and throw the rest away.
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Fri Jul 24, 2020 5:02 am Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
The cab floor replacement panels from 13 years ago aren't quite up to par with what is available today. I recognize that patch piece. As previously mentioned, I would consider replacing that side of the floor again if you want to be truly happy with the bus. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Fri Jul 24, 2020 6:50 am Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
Yes as I recall that lip I need was not on the WW replacement piece I purchased in 2008 and good to know they make them correctly now. Wow great pictures thanks folks and now it is so clear to me. I will eventually replace that piece but not in the near future as that will push the project back another 13 years. It will be bothering me until I make the repair but to keep me from being disapointed and slowing down anymore progress I am going to be grateful for answers.
This pic is in the gallery from 2003 WW floor replacement piece. Although he says it has the lip for the kick panel it appears he is incorrect. I guess now when we see bus repairs we can figure what year & company the replacement metal came from.
https://www.thesamba.com/vw/forum/album_page.php?pic_id=44035
Okie Adam wrote: |
The cab floor replacement panels from 13 years ago aren't quite up to par with what is available today. I recognize that patch piece. As previously mentioned, I would consider replacing that side of the floor again if you want to be truly happy with the bus. |
Maui Roadsters
Lind wrote: |
BarryL Samba Member
Posted: Fri Jul 24, 2020 11:56 am Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
With the screws that hold the kick panel and the heater grate holding/aligning the panel I don't think you even need that lip. If it bothers you to see gray then you could put white electricians tape or tan masking tape along the bottom of the kick to fake the lip look. |
Posted: Sun Jul 26, 2020 6:29 am Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
Thanks BarryL, that is exactly what I will do
BarryL wrote: |
Maui Roadsters
Lind wrote: |
BarryL Samba Member
Posted: Sun Jul 26, 2020 11:05 am Post subject: Re: Will a 63 lower inner nose strip fit a 67 |
Also the headlight bucket will hold it in alignment. |
