BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Sat Jul 25, 2020 4:57 pm Post subject: Bedding procedure for Disc Brakes |
For those that have done a Disc Brake conversion, could you share your bedding procedure? I searched and apparently nobody bothered to post any details. Also please list what calipers you used and what type of pads. Thanks.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sat Jul 25, 2020 5:41 pm Post subject: Re: Bedding procedure for Disc Brakes |
BIGMIKEY wrote: |
Mike T |
for better responses tell us what you drive ,what year ,is it standard or super ? |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat Jul 25, 2020 6:38 pm Post subject: Re: Bedding procedure for Disc Brakes |
Disc brakes don't need bedding in! After 50 miles of sedate driving you will have removed the glaze off the disc and the brakes will be fine. Indeed a couple of hard stops after that will help remove the glaze even more. When they are brand new, the pads take a bit longer to stop, but not dramatically so.
My car has the original VW discs (1968 Euro beetle RHD) factory standard.
ATE discs with single pin standard (asbestos) pads. I think "metal" pads just wear the discs away too quickly. Later model discs came with two pins to hold the pads.
After market set-ups are fine. It's only a very light car so you get a bit of a shock of how small the brakes are compared to modern day cars. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Bama Dave Samba Member
Posted: Sat Jul 25, 2020 6:40 pm Post subject: Re: Bedding procedure for Disc Brakes |
I presume you mean BLEEDING procedure on a Type 1 Beetle. Probably get many opinions and some doomsday pontification from others. No real magic, just patience.
Here’s how I do it. I install everything. No bench bleeding or anything else. Once all connections are good, I fill the reservoir. I pump the pedal a bunch just to get some fluid moving. Then I open both sides rear bleeder valves and let them sit open a few hours (gravity works nicely). Put a container under each to catch fluid, if/when it drips. Then, with an assistant, I bleed the right rear, then left rear, then the right front, then left. Assistant pumps and holds the pedal, then I open the valve briefly and close. When the valve is open, the pedal will go all the way down. Repeat that about 15 times each corner and it should be good. Recheck each corner in the same order after all are done. Have to watch the reservoir levels throughout and top off accordingly. I have done this every time and it has worked every time. Your results may vary. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Sat Jul 25, 2020 8:09 pm Post subject: Re: Bedding procedure for Disc Brakes |
Bama Dave wrote: |
Here’s how I do it. I install everything. No bench bleeding or anything else. Once all connections are good, I fill the reservoir. I pump the pedal a bunch just to get some fluid moving. Then I open both sides rear bleeder valves and let them sit open a few hours (gravity works nicely). Put a container under each to catch fluid, if/when it drips. Then, with an assistant, I bleed the right rear, then left rear, then the right front, then left. Assistant pumps and holds the pedal, then I open the valve briefly and close. When the valve is open, the pedal will go all the way down. Repeat that about 15 times each corner and it should be good. Recheck each corner in the same order after all are done. Have to watch the reservoir levels throughout and top off accordingly. I have done this every time and it has worked every time. Your results may vary. |
Much the same as Bama Dave, but I may go 3- 5 more cycles past the fluid running clear. _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
Posted: Sat Jul 25, 2020 9:33 pm Post subject: Re: Bedding procedure for Disc Brakes |
DOH!
I took his wording literally meaning BEDDING, not thinking BLEEDING. Spell check anyone?
Maybe it wasn't bleeding obvious to me. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Sat Jul 25, 2020 10:01 pm Post subject: Re: Bedding procedure for Disc Brakes |
viiking wrote: |
DOH!
Maybe it wasn't bleeding obvious to me. |
and i thought it was for installing. What a drag it is getting old. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Sat Jul 25, 2020 10:15 pm Post subject: Re: Bedding procedure for Disc Brakes |
I use what I was taught at one of the big brake educational sit downs. Similar to this webpage from Wagner. They may have been the one!
“An effective burnish cycle to seat the friction materials into the opposing rotor and drum surfaces requires approximately 200 stops. The 200 stops are consistent with the burnish procedure outlined in the Federal Motor Vehicle Safety Standards FMVSS 105 and FMVSS 135. 200 stops may not be practical for many repair shops. Therefore, we recommend the following burnish procedure:
Make approximately 20 “Complete Stops” from 30-mph
- OR –
20 “Slow-Downs” from 50-mph to 20-mph with light to moderate pedal pressure
NO PANIC STOPS
Allow at least 30 seconds between brake applications for the brake pads or shoes to cool down
It is critical to follow cool down procedures to avoid damaging NAO, Ceramic and Semi-Met friction material as well as the rotor/drum
No high speed stops and/or braking under heavy loads that could result in glazed or otherwise damaged linings
Using these guidelines, the friction materials will have conformed to the surface of the rotors and drums for improved stopping performance. In addition, the thermal conditioning of the friction materials during this process will increase the stability of braking effectiveness over a greater range of temperatures compared to when they were first installed. It’s a good practice for the repair shops to communicate with their customers that their technicians have conditioned the friction and rotors and that the customers should continue this process by avoiding aggressive braking for the next couple of days. Good communication of this information will be helpful and prevent comebacks.“
https://www.wagnerbrake.com/technical/technical-tips/break-in.html _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sat Jul 25, 2020 10:35 pm Post subject: Re: Bedding procedure for Disc Brakes |
I drive a 1973 Standard beetle. I recently installed disc brakes from a 1974 Karmann Ghia. Rebuilt Girling Calipers and Centric metallic pads. I was interested in the bedding in procedure that people used. Interesting to see that apparenly noone has ever heard of it. No, not bleeding. I did search before posting. No results at all.
VW_Jimbo wins the Cupie Doll.
Mike T
rayjay Samba Member
Joined: March 26, 2008 Posts: 1506 Location: Buford GA
Posted: Sun Jul 26, 2020 5:37 am Post subject: Re: Bedding procedure for Disc Brakes |
I wonder if the brake pad manufacturer has recommendations on their website ? I'm surprised there was no info in the box. When I was involved in the SCCA all the brake manufacturers included detailed instructions in the box. |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Sun Jul 26, 2020 9:07 am Post subject: Re: Bedding procedure for Disc Brakes |
New discs and pads on mine have 7k miles on them now. Zero bedding procedure other than normal driving. They stop great, don't squeal so I don't know how I could have improved upon that. |
Posted: Sun Jul 26, 2020 5:04 pm Post subject: Re: Bedding procedure for Disc Brakes |
BIGMIKEY wrote: |
Mike T
VW_Jimbo wins for providing some documented answers. I said essentially the same thing in my post, but did not have the evidence. I remember my Father receiving a pamphlet with his new VW in 1968 which advised the break-in of the engine (not to exceed certain speeds and also to avoid heavy braking for I think 100 miles(?) but that pamphlet is long gone.
Bedding in of brakes of cars before the '80's was commonplace. Not so much now where you expect to spin your wheels leaving the car lot with your new car. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
doug bugg Samba Member
Joined: March 08, 2003 Posts: 349 Location: Minneapolis
Posted: Tue May 17, 2022 6:58 am Post subject: Re: Bedding procedure for Disc Brakes |
I'm going to bump this thread hoping to come up with a definitive(?) way of bedding brakes, if that's possible.
I installed an AC disc brake conversion kit on my '68 bug over the winter. I've only put about 25 miles on it since then and there is a shrill squeaking on both sides under light to moderate braking. I triple-checked parts and install to make sure everything is correct and it is. I even sprayed both sides of the shims with Permatex disc brake quiet.
(I do realize that having put so few miles on it that it's a little early to be worrying about any squeaking, but it's SO obnoxious.)
I started doing some research on possible brake noise and came across the bedding procedure(s). I've been working on my own cars for decades and had never heard of this, man do I feel dumb!
Looking at five different sites, I've come up with five different ways of bedding! I even found one saying it wasn't necessary with disc brakes!
Soooooo any input would be appreciated! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue May 17, 2022 7:55 am Post subject: Re: Bedding procedure for Disc Brakes |
When I first installed my Empi front disc conversion on my 1974 Super Beetle, the squeal was something awful as I approached stop lights and signs. Not when slowing at faster speeds, however. Soft pads, I was told, and after a few hundred miles on the car, the squeal went away. That was about nine years ago, and the brakes still work fine. Every once in a while, I get a slight squeal at slow speeds at stop signs, but nothing like I first encountered.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Tue May 17, 2022 8:10 am Post subject: Re: Bedding procedure for Disc Brakes |
25 miles is nothing! Go for a drive. Like 40 miles there and then 40 back, and get the car up to speed for a duration of time. It is the heat cycle that gets these parts to wear (punny, supposed to be where) they need to be! But you have to be careful! Hot new brakes are not as efficient as bedded brakes. And sometimes you get a soft, spongy pedal for a little while, so longer stops are mandated!
Hope that helps! _________________ Jimbo
TDCTDI wrote: |
Posted: Tue May 17, 2022 4:02 pm Post subject: Re: Bedding procedure for Disc Brakes |
Find a quiet road.
Get up to 60mph and brake reasonably hard (but not lock up).
Repeat half a dozen times.
Go for a drive and see if the squeal had diminished.
Repeat if necessary! _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Tue May 17, 2022 4:15 pm Post subject: Re: Bedding procedure for Disc Brakes |
Find a quiet road.
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Tue May 17, 2022 5:13 pm Post subject: Re: Bedding procedure for Disc Brakes |
"Bedding in" was the buzzword back in the days when disc brakes were a new thing and primarily used for racing...the problem at the time was that the friction material when heated drastically off-gassed the solvents used in the glues that held all the asbestos fibers together...so if you put on a new set of pads and barreled full bore into the first turn and got on the brakes the pads basically hydroplaned on the layer of gases coming out of them and the car wouldnt stop....so bedding in was a series of moderate stops that got the pads just hot enough to get the solvents to boil off ahead of time ....it has never really been an issue with street cars as just normal driving is basically a bedding procedure....just dont do anything stupid, no panic stops and dont overheat them immediately....the source of most brake squeals is not between the pad and the disc (except in some cases where the leading edge of the pad isn't beveled or the material is way too hard) but between the back of the pad and the caliper piston...most modern disc brake setups have a series of shims (or additional friction material) built on to the back of the pads to prevent squeal but what we're dealing with on our cars is WAY behind in technology with a tiny square pad thats a chinese copy of 50 year old parts made as cheaply as possible |
Posted: Tue May 17, 2022 8:03 pm Post subject: Re: Bedding procedure for Disc Brakes |
I’ve been driving on and off my (Dad’s) 1968 Beetle with standard ATE single pin caliper clad front brakes since it was new. Never a squeal from the 50+year old technology.
It seems the squeal is a new car or brake pad manufacturing phenomenon. No anti rattle springs, no anti squeal sprays on the old bug. Some models of BMW have been found to have insoluble front brake squeal symptoms. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
