Fuse #12 keeps blowing...
ProspectiveOwnergon
ProspectiveOwnergon is offline
PostPosted: Sun Jul 26, 2020 4:20 pm    Post subject: Fuse #12 keeps blowing... Reply with quote
So my fuse #12 (1990 camper) keeps blowing ever since I took ownership and got home. Prior, my power mirrors worked, my ac fans blew (warm). Now, once I put the key into the ignition, BOOM...fuse blows.
Since ownership I've done:
1. New radio (had to fox the driver front speaker wire that was grounding against the master cylinder)
2. Installed a new radiator fan relay
3. Disassembled the front driver door panel (found PO or prior, someone had snipped the black/yellow to the power mirror switch with a bigger red wire). These connections seem solid.
4. Attempted to use rear wiper...nothing, just liquid sprays
No idea what to check or how to diagnose now. I have an AC appointment on tiesday and if fans aren't running, they can't diagnose anything...
Last edited by ProspectiveOwnergon on Sun Jul 26, 2020 6:39 pm; edited 1 time in total
vanagonjr
vanagonjr is offline
PostPosted: Sun Jul 26, 2020 4:31 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Should list year and model details,
ProspectiveOwnergon
PostPosted: Sun Jul 26, 2020 6:40 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
in my head I kept saying... type the year... type the year... guess what I forgot... Haha.
1990 Camper
bobbyblack Premium Member
bobbyblack is online now
PostPosted: Mon Jul 27, 2020 7:57 am    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
While not a solution to your #12 fuse issue, you CAN get power for the A/C from the always powered section of the fuse panel. I think there are a few open on the back, in the P section.
Careful, P's are unfused.
Read this one...
https://www.thesamba.com/vw/forum/viewtopic.php?p=2814987
Not sure where tencentlife pasted the info from, but it was a post prior to that one. I looked around a bit, couldn't find the original.
EDIT:
tencentlife wrote:
The earliest surviving instance is here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=239158
I think the original was lost in the server failure that happened back then.
So that explains my confusion; from post -> https://www.thesamba.com/vw/forum/viewtopic.php?t=239158
More info.. quoting thatvwbusguy: "S12 refers to Fuse 12" in this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=619094
Hence, don't use G1 & G3 if you want to avoid fuse 12, if using the G's (ignition on)
'87 Westy 'Flossie','86 Westy 'R1','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch
VicVan
VicVan is offline
PostPosted: Mon Jul 27, 2020 8:22 am    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Quick tip: put your type and year model in your signature.
Fuse 12 on your van is for:
    Cruise control
    A/C
    Power window
    heater fan
    power mirror
    Rear wiper
If you're out if time, and need to get ready for tomorrow's appointment, unplug all of these except the A/C. Hopefully the A/C is not the culprit, if so your fuse won't blow and they'll be able to work on it.
Now, for proper diagnosis: you see that all of the elements on that list are electric motors. If the fuse blows, one likely cause is an electric motor is seized. Turn everything off (fans controls to 0), etc), put a new fuse in, and turn these things on one by one. When the fuse blows, you've got your culprit.
For others: could this be the ignition switch?
'90 Westiti, 2.1 auto
tencentlife
tencentlife is offline
PostPosted: Mon Jul 27, 2020 8:59 am    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
From an earlier thread where I first posted the list that I developed, that's where.
See innovative Vanagon accessories at the Vanistan shop:
Hmmm, provincial much?:
"I wouldn't go much on whats written on the samba, they love a "theory" and rarely ask any Europeans what is actually correct."
PostPosted: Mon Jul 27, 2020 10:18 am    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Ahh, thanks. I found that listing quoted a few other places, but not the original post. I was kind of interested.
And to the OP, How about disconnecting the wiper motor in the back. Got to take off the wallboard, ya, but since it is probably seized, and causing your trouble, try it?
-bobby
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Jul 27, 2020 10:35 am    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
ProspectiveOwnergon wrote:
So my fuse #12 (1990 camper) keeps blowing .... once I put the key into the ignition, BOOM...fuse blows.
Since the ignition switch has a switch that's operated as soon as key is inserted.....
Do you mean that S12 fails literally when you insert the key?
Neil.
1981 Westy air cooled to 15 ABA swap: http://tinyurl.com/y9n4xob8
50 ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
ProspectiveOwnergon
PostPosted: Mon Jul 27, 2020 1:13 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Neil.
I haven't checked WHEN it blows and if it is once inserted or turned to aux position. Will test tonight.
    Cruise control (CC)
    A/C
    Power window (PW)
    heater fan
    power mirror
    Rear wiper
Will put in my sig!
I don't have CC, PW.
Is the heater fan the one under the rear bench?
Can I just unplug the connector at the mirror controls in the panel to see if it's that?
Rear Wiper, where is the easy disconnect for this?
Vanagon Nut
PostPosted: Mon Jul 27, 2020 1:29 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Neil.
Cool. I took what you wrote quite literally partly because it's electrical stuff but also because who know's what someone may've done with the wiring. My guess is that the Su circuit triggered by key insertion, is not involved.
A fuse popping like that typically means there's a short between positive, ground. Since wires have been cut, a positive wire could be contacting ground.
I'd disconnect the batteries then measure for a short (continuity) between S12 contacts in fuse box and ground.
Neil.
VE7TBN
ProspectiveOwnergon
PostPosted: Mon Jul 27, 2020 1:54 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Neil.
Neil.
Having never done a continuity test, but just watched a YouTube video, if I hear noise when touching a ground, that means I am shorting a wire. If I DON'T hear anything, then what's my next step?
Btw, on the fuse, is it the top or bottom connection that gets it's power?
VicVan
VicVan is offline
PostPosted: Mon Jul 27, 2020 2:12 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
That leave us with:
    A/C
    heater fan
    power mirror
    Rear wiper
No, it's the one in the dash, blowing air to windshield and footwells. Put it on 0, or better yet, disconnect the plug behind the switch.
Yes for power mirror connectors
Rear wiper, maybe there's a plug behind the hatch cardboard, as I think was suggested by somebody else above.
VicVan
VicVan is offline
PostPosted: Mon Jul 27, 2020 2:13 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Depends on the year model Razz
So test it with a voltmeter.
Vanagon Nut
PostPosted: Mon Jul 27, 2020 4:13 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
By "noise" I assume you mean the tone (or buzz?) some VOM's emit when seeing "0" Ohms. aka continuity.
IIRC, this testing stuff is shown in the Bentley manual and is likely explained far better than I can but I'll try anyways. Wink
It'd be prudent to test for a short to ground at supply (gets power) and load fuse contacts but since the fuse blows, if there's a short, it'll be on the load side. If no noise and/or 0.00 Ohms, under those circumstances, there is no short (fault) between circuit(s) on that fuse and ground (vehicle frame). But....
A short could happen once a load is turned on. i.e. positive wires post switch, the part itself, shorts to ground once energized. Along with VicVan's comment, disconnect all loads on that fuse. If fuse doesn't blow, add one load at a time till it does.
Years after I started using a VOM, oddly enough during my tenure as a Vanagon owner, I got into the habit of connecting the meter probes together to check meter and probe function. For most of us, the meters we can afford tend to have cheap probes that fail soon leading to false readings.
I'm no expert and I don't mean this in a snarky way but by using your VOM to test for a short you're not "shorting" a wire. You're testing (measuring) for continuity between two points. Sometimes we want see continuity, sometimes not. e.g. seeing unwanted continuity (short) between the positive and negative sides of a circuit.
You want electricity to flow from battery to load, then through load to ground. If a positive wire were to break away and connect to ground,or vice versa (ground wire to positive) it's a "short" or fault. Electricity is now taking a shorter incorrect path to ground.
Neil.
VE7TBN
ProspectiveOwnergon
PostPosted: Mon Jul 27, 2020 8:46 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Ok... you get ONE guess as to what the cause of my fuse blowing is. Here is my rear wiper motor (I unplugged and electrical taped the wire from the harness)
Rear wiper motor
Last edited by ProspectiveOwnergon on Tue Jul 28, 2020 6:35 am; edited 1 time in total
Vanagon Nut
PostPosted: Mon Jul 27, 2020 11:30 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Did the wiper motor case actually rust through or is that hole due to heat damage?
The motor had seized I assume.
VE7TBN
ProspectiveOwnergon
PostPosted: Tue Jul 28, 2020 6:34 am    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
It looks like it burned through as the insulation doesn't have rust and there is no rust on the hatch. Additionally, the hole is on the downward side. Taped the lead wires but left the motor in there as it was 9pm and I wanted to go to bed. Next time I have the rear hatch panel off it will come out.
Vanagon Nut
PostPosted: Tue Jul 28, 2020 10:39 am    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Did you disconnect, reconnect loads to determine that wiper motor was the fault?
This thread shows heat damage at connector to fuse panel as cause of rear wiper (etc.) not working:
https://www.thesamba.com/vw/forum/viewtopic.php?t=649073&highlight=rear+wiper
Your post has reminded me to double check what's going on inside the rear hatch on my '88. IIRC, this connector is for the wiper motor:
VE7TBN
ProspectiveOwnergon
PostPosted: Tue Jul 28, 2020 2:05 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
My connector had a LITTLE burning as I had to crack the plastics apart, but nothing like that. Will have to check out the back of my fuse oanel I guess for added measure. Though...I can't get it out due to a MASSIVE relay at the top hanging up against my dash
Vanagon Nut
PostPosted: Tue Jul 28, 2020 2:17 pm    Post subject: Re: Fuse #12 keeps blowing... Reply with quote
Thanks for that info.
Back in 2013 or so, I assume I at least cleaned the connector contacts, maybe wrapped some tape on wires but frankly can't recall for sure. Of late, I've seen intermittent wiper behaviour. (doesn't always park). I assumed it was due to a the relay but maybe not. Embarassed
Neil.
VE7TBN
