DanHoug Samba Member
Joined: December 05, 2016 Posts: 4798 Location: Bemidji, MN
Posted: Thu Jul 30, 2020 4:35 pm Post subject: RM182B burner jets |
my Google-Foo is failing me....
what is the part number for the Dometic RM182B jet that is threaded on both ends? not the one with threads only on one end.
also. i'm confused on orifice size on these... what i'm reading is that #24 is the correct jet. it is my understanding this number refers to drill bit size and reading the "Propane Orifice Chart" from John Zink Company, a 24 = 0.1520"
here's where it gets odd... had my fridge out for service and cleaned the jet ultrasonically and then when that didn't yield the flame ht desired, i ran a propane jet cleaner thru, Model G03020. this is a cleaner that is 0.0135" diameter and it was tight, in fact i removed a bit of brass with it. there is no way that orifice is 0.1520". NO WAY. i mic'd my cleaner and it is indeed 0.0135"
so now, my fridge flame is good, perhaps even a bit high, but it cools wonderfully. maintains 45F interior when ambient is 85F with the temp control at 9:00 and the burner is cycling between high and low. it gets even colder fully clockwise. prior to the reaming, i had a very quiet flame with poor thermal performance. now it is the classic rumble when listening at the vent. _________________ -dan
www.thefixitworkshop.com |
Vanagon Nut Samba Member
Posted: Thu Jul 30, 2020 6:03 pm Post subject: Re: RM182B burner jets |
If need be, adapt a one end threaded jet?
I'm sure you saw this but here's threaded one end burner:
https://www.busdepot.com/255070509e
Yeah the hole in the burner jet is super tiny. Like a wire strand of fine stranded wire tiny.
If memory serves, there may even have been a burner jet with a different size orifice. For higher altitude use? Anyhow...
I don't see any reference to part numbers in my Dometic service manual.
1988 West DIY 50º ABA
VE7TBN |
WiboBusMan Samba Member
Joined: September 26, 2009 Posts: 141 Location: Canada
Posted: Thu Jul 30, 2020 6:18 pm Post subject: Re: RM182B burner jets |
From the Service Manual (08/89), at page 45. there are two parts listed as follows:
Code: |
Model num. Orifice size and part num.
RM182 24(2928787049)
RM182B 24(2928787506)
As to possible sources, I have no idea if this info is at all still current, but here is quoted from the Service Manual:
Code: |
The Dometic Corporation
Corporate Office
2320 Industrial Parkway
Elkhart, IN 46515
219-295-5228
Warranty Department
205 E. Fenn St.LaGrange, IN 46761
219-463-2191
Technical Services Department
509 S. Poplar St.LaGrange, IN 46761
219-463-4858
And from the Canadian Dometic Refrigerator Manual that came with a 1984 Westy:
Code: |
The most common spare parts are as follows: Jet, heating element, thermostat,
flame failure safety device, thermocouple, electrode, 12/120 V switch, piezo, and are
available at:
DOMETIC SALES CORPORATION
7895, W.W. Hunziker Road
Portland, Oregon 97223
East Oak Ridge Drive
Route 9 , Box 17 A
Hagerstown, Maryland 21740
5755 S.Hoover Rd., Unit 2
Wichita, Kansas 67215
14441 Bonelli Street
City of Industry
California 91744
P.O. Box 490
Elkhart/Indiana 46515
EUROCLEAN CANADA INC.
866, Langs Drive
Cambridge, Ontario
N3H 2N7
(519) 653-8880
4575 Rue Hickmore
St. Laurent, Quebec
H4T 1S5
W _________________ Science has sacrificed Truth on the altar of its narrative. |
Posted: Thu Jul 30, 2020 8:26 pm Post subject: Re: RM182B burner jets |
Wow. Thank you for the part numbers! Perfect. _________________ -dan
vantane Samba Member
Joined: November 03, 2023 Posts: 12 Location: Southern California
Posted: Sat Jan 20, 2024 10:26 am Post subject: Re: RM182B burner jets |
The pilot light won't light. The jet is clogged and I tried to poke it with a needle but no luck.
My instructions were to remove the jet and soak it in lacquer thinner but to do this I must separate the pilot gas tube. How is this to be done without damaging the tube ? |
Posted: Sat Jan 20, 2024 10:28 am Post subject: Re: RM182B burner jets |
that's the thermocouple, not the gas jet! _________________ -dan
R0ckyMtnCamper Samba Member
Posted: Sat Jan 20, 2024 12:15 pm Post subject: Re: RM182B burner jets |
Where did you poke the needle?
I don’t think it is advised to poke anything through the jet, regardless. |
Posted: Sat Jan 20, 2024 2:40 pm Post subject: Re: RM182B burner jets |
R0ckyMtnCamper wrote: |
this is good advice. i used a tapered, triangular pilot jet reamer to open up the narrowed down jet and widened it too much. very large flame on fridge resulted!
clean it in an ultrasonic cleaner, lacquer thinner, isopropyl, etc. and give it time to soften the 40 year old propane residue. like days. _________________ -dan
Posted: Sat Jan 20, 2024 4:55 pm Post subject: Re: RM182B burner jets |
What was I thinking?!
This is the jet. But it doesn't look like a pilot jet.
Posted: Sat Jan 20, 2024 5:01 pm Post subject: Re: RM182B burner jets |
vantane wrote: |
What was I thinking?!! |
it's fine. but i'm curious if you googled something and got an incorrect AI feed. bigger appliances like water heaters, etc have a separate pilot gas line and a main burner line.
this fridge has one line, serves as both 'pilot' which is actually the low flame setting, and 'on', which is a little bigger flame. same gas line. _________________ -dan
Posted: Sat Jan 20, 2024 7:35 pm Post subject: Re: RM182B burner jets |
vantane wrote: |
No, the jet is a small brass piece inside the fire box. It’s inside of the flame tube. |
