67 bus engine 1500 how to clean out oil passages in a 1500 1600
vwuguy Premium Member
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Fri Jul 31, 2020 8:42 am    Post subject: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
This 67 bus engine is about to get a cleaning. Thought this might be something worth a video.
What do other vw folks do to clean out these oil passages correctly?
Does anyone redrill them a few thousandths larger?
Smile
easy e
easy e is offline
PostPosted: Sun Aug 02, 2020 2:17 pm    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
You’ll get the idea...
http://www.huelsmann.us/bugman/FilterTech.html
Braukuche
Braukuche is offline
PostPosted: Sun Aug 02, 2020 4:10 pm    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
That’s a bit of overkill.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
vwuguy is offline
PostPosted: Mon Aug 03, 2020 8:03 am    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
ok read the article was wondering what tools do other vw folks use to clean the oil passages out?
Is there any kind of long drill you could use to redrill them to hone them clean again?
Smile
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Aug 03, 2020 11:42 am    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
A drill is not going to hone the passage/s. A drill cuts metal, so there is going to be a lot of tiny bits of metal stuck here and there ready to pop loose later.
Even if you use a hone after drilling, the hone is designed for hard ferrous metals, not soft sticky magnesium/aluminum alloy. So any hone would be coated with the softer metal, and no longer act as a hone.
Also if you look, the bigger passages are tapered to get the proper flow to each oiling point.
In Stereo, Where Available!
Braukuche
PostPosted: Mon Aug 03, 2020 11:58 am    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
I use a series of small round brushes from the local Ace Hardware and degreaser like Gunk followed by the water hose and finished with compressed air.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
vwuguy is offline
PostPosted: Mon Aug 03, 2020 12:47 pm    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
has anyone tried to cut the case so the passages are visible then clean them and use epoxy to fill the spots cut off..
is enlarging the oil passages a good idea?
In a single relief case is there any extra oiling spots that could be drilled into the case to add more oil flow?
Smile
Eric&Barb
PostPosted: Mon Aug 03, 2020 7:50 pm    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
No, taper of the passages helps keep oil flow even to each bearing, even in a hot engine with lower oil pressure.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Aug 03, 2020 11:59 pm    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
get a series of rifle cleaning brushes with brass bristles. Don't break one off inside. Make sure it is loose enough to run in and out.
That said, if someone has run non-detergent oil in that case for a long time it will take long rods with flutes carved in it to loosen the stuff. I vividly remember working a day and a half in a machine shop to clean oil passages out in a 1930's Buick motor that was run a long time with non-detergent oil. Lots of compressed air too. I use a pressure washer too to run high pressure water thru the passages after scrubbing them.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
RWK
RWK is offline
PostPosted: Tue Aug 04, 2020 4:57 am    Post subject: Re: 67 bus engine 1500 how to clean out oil passages in a 1500 1600 Reply with quote
If you don't want to do it yourself, maybe you can find this service there
https://www.westmichiganultrasonic.com/engine-parts-cleaning-services
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
