Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1963 Location: Manitowoc, WI
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Jan 04, 2021 8:55 am Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Do you have a shrinking disk yet? It would be super helpful on that one large panel your working with. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Tue Jan 12, 2021 7:48 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Finally got some time today to work on it, I had a couple hours to work and I started cutting out the rear corner crap. I first cut out the back of the wheel arch and sand poured out so I will have to clean it out somehow. There was plenty of rust covered over with the klockerholm panel. Then I got the kolkerholmen Battery tray out easy, it was welded in with cold flux core welds and only 5-10% of welds were holding and most broke with a little force. The remains of the OG battery tray were a pain. The factory did a horrible install on it. I’ve haven’t seen anything factory that was that botched.
_________________ 1964 sunroof Beetle Restoration "Herbie"
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop |
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 906 Location: SouthEast
Posted: Wed Jan 13, 2021 6:06 am Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Ive always wondered on repairs like you are doing to the windshield lip how people expect those patch panels not to rust from the inside out.
As far as I know once those are welding in there, there is not really any way to paint or rustproof them.
Even with weld through primer, the primer melts where you weld leaving and unprotected line of metal.
How do you deal with this? |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Wed Jan 13, 2021 6:40 am Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
RalphWiggam wrote: |
My windshield ledge repair was similar, though it only required one extra patch. I sandblasted all the rust out before welding in the repair panels and hit it with weld thru primer. I also sprayed some in through the holes is the back of the panel.
One of my restoration manuals recommends removing the windshield every few years to clean and or repair since it is such a rust prone area. I have tried all kinds of things to coat or rust proof the inside of panels. I think the best thing you can do is not drive it in northern winters and make sure that water and moisture are not getting in. I had a repaired rocker panel rust out because of a hole in the metal underneath the smokers window. It took out a new jack point too. A welded up bus will always be more rust prone than one new from the factory. I check often for leaks and like to remove the interior to clean up the floor and interior sheet metal, etc. It’s one reason I will never glue down all kinds of sound deadening material. |
Posted: Wed Jan 13, 2021 8:40 am Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Hmmm, I honestly hadn't thought a ton about it. I did spray weld through primer in before welding it closed. I'm Planning to do an extensive cavity rust prevention on this project, taking out all the plastic plugs and using rust prooffing stuff in rockers, frame rails, dog legs(?), wheel well skins, and the list goes on. If I have a wand setup I could probably coat under the windsheild. Other seams I will blast and seam seal, all the OG sealant is chipping off. I'm thinking of using a lanolin type undercoat by woolwax on all the insides and maybe do a touger coating in the wheel wells but it can't be too hard because I found on my T3 the factory put this hard coating over the metal and painted it but it rusted behind it and it didn't break so it cuased the rust to spread horribly. So I will probably just get it painted well and figure out what to use for them. Something that if it rust under, will fail easy and not cause spreading, but something decently durable. probably nothing like it though. So maybe just wax/oil coating on the chassis. _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Sat Jan 16, 2021 10:32 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Today I decided to install the BN4, I was working on the battery tray and thought I drill the holes in it and decided to go for it all. I forgot to upload one of the battery tray though.
I first started with the recirc hole.
I centered the template on the hole. I found the edges are perfect so where it says to line up may not be accurate for all busses. I used a step bit on the corners and then cut it out and used a die grinder to make the hole nice.
I found that after the recirc it is best to cut the hole then drill out the screw holes using the part as a template. Next was to remove the bench seat out to get to the area to cut
I found that the template has you cut farther into the middle than needed and you can add material to the template
I accidentally cut too far over towards the wheel well
Then I got the hole in the firewall cut out. I had to do some guesstimating and got it spot on.
I found that the piece even had a part number sticker on it still since it was a dealer installed unit.
The bus was very rusty so I will have to work on a new intake pipe
I got the temperature cable installed. I lived it up but pulled all of the wire out. The end of the wire had been bent by someone and I tired to straighten it but it broke. Luckily I had enough slack I was able to cut back some of the outer casing and get enough wire to work. Here is it in
I am going to modify the passenger bus duct for a flex tube like what a westy would have had. I was happy with how it can out, next step: get it running _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Sat Jan 23, 2021 8:46 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Today I pulled out the rest of the interior to clean the inside and inspect. I also tried to fix some of the accident damage. One of the pieces had gotten bent in so I put a piece of wood against it and wrapped it with the sledge hammer and got it back into place I also tried using the shrinking disk on the rear 1/4 panel and not sure how much it did. I found a couple pin holes in the floor and it was pretty solid. The OG insulation was still there and in good shape so I saved it.
Yum, dirt/mold
Then clean
Then you can see the engine fire the damage where it started burning the paint in the air vent. Very close to the trim igniting.
Then the sort of the rust
Posted: Tue Jan 26, 2021 7:56 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Didn’t update on Sunday but I started getting the battery tray welded in and then I ran out of shield gas for welding I did some other miscellaneous things but nothing picture worthy. Yesterday I was able to run into town and get some more shield gas after school.
Today I got the right batter tray welded in the rest of the way. I then got the mudflap area/ inner wheel well structure.
I first taped out where I wanted to cut it out
Here is the comparison of the two pieces. You can see the one that was one the bus had been hacked up in the corner for the old AC lines for the dealer installed AC
Then I got it welded in most of the way. It came out pretty good
Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Wed Jan 27, 2021 1:46 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Stayed up late last night reading this whole thread.. Not sure how i missed it.
Can't wait to see you give this same type of treatment to your type 3.
Couple of thoughts:
Make sure you pull out or cover the glass; grinding sparks can stick to glass and mess it up.
Get that sliding track cover off of there and out of the way.
Plus pull that slider, and the quarter window.
Gonna be a real struggle straightening that panel if you can't reach both sides at once.
You can also pull the dash top.
Not only will you be able to reach in there and see what's bent,
But,
With the windshield out,
It's WAY easier/better to work on dash wiring that way..
You go brother.. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Wed Jan 27, 2021 3:49 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Clatter wrote: |
Couple of thoughts:
But,
You go brother.. |
Thanks for mentioning the glass, I have pulled most of it out and masked the vent windows with masking tape, but I forgot about the rear left window and would have started grinding on it.
How does that top piece come out of the dash? I took out the screws. Do you have to take it all apart or can just the center metal piece come out? I couldn’t find info in the manual.
Thank you! Chipping away at it one day at a time _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Wed Jan 27, 2021 5:14 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
IIRC, there’s a little row of nuts all along up under the dash pad.. _________________ Bus Motor Build
soissisc Samba Member
Joined: April 04, 2007 Posts: 636 Location: Western Pennsylvania
Posted: Wed Jan 27, 2021 5:15 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
Maybe have to unbolt the grab handle too? _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Wed Jan 27, 2021 6:57 pm Post subject: Re: The 447th 1972 bus, A Sierra Yellow Westfalia Tin top build |
All the screws you can see, the ones holding the upper dash piece to the dash - these are under and inside the dash = what clatter said and the grab handle like soissisc said.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
