Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Mon Jan 16, 2023 8:25 pm Post subject: Re: "There she dribbles...." |
orwell84 wrote: |
If you drive it to work, you can’t park in the same space everyday. |
When I go to the Volvo dealer to pick up my 30% discounted parts, I park it over the O and fill in the middle with oil _________________ .ssS! |
75 Westy FI noob Samba Member
Joined: November 04, 2022 Posts: 330 Location: MidWest
Posted: Wed Jan 18, 2023 3:24 pm Post subject: Re: "There she dribbles...." |
airschooled wrote: |
No sweat on any oil pumps over here, but my main seal likes to puke if I fill more than half a quart over full… Robbie |
My oil pump may be leaking.. hard to tell bc its all covered in grease. My parts guy is unsure which gasket goes on the pump. Is it ‘same as the beetle’ as he says ? your comment about the main seal makes me think I might leave mine alone and just try not to overfill.
airkooledchris Samba Member
Posted: Wed Jan 18, 2023 3:45 pm Post subject: Re: "There she dribbles...." |
The problem with that area is it was right by the fan. Whatever leaked was blown all over everything here.
Clean it all really well and add a little UV dye to the oil. When it's up and running again, get your UV light out and trace it's source/s.
There's quite a bit of oil up on top, so it could be breather, oil pressure sender, there's so many potential sources. Clean it all really well. While in this area considering tossing the 009 and getting a proper vacuum advance distributor.
SGKent Samba Member
Posted: Wed Jan 18, 2023 4:18 pm Post subject: Re: "There she dribbles...." |
airkooledchris wrote: |
I was thinking the same that Chris said. The only thing I can add is look INSIDE the shroud and see if oil is slung all around it. If so it could be the front seal. Or it could be a bad o-ring on the distributor, or a bad oil sender like Chris said. I would have cleaned it first really well with some solvent and a pressure washer, and looked for the leak trail. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jan 18, 2023 4:44 pm Post subject: Re: "There she dribbles...." |
Oil cooler seals were def bad..
All the other bits may be too.
That pic is after a jumbo can of PB Degreaser.
It all looked like the bottom before. Ran out of spray before i got to the oil pump. Filter housing was really caked
Cant run it to check for leaks without the shroud tho.. bc the timing is off.
(Rookie mistake #37)
Figured i would change all the seals/gaskets and pressure switch while im in.
Trying to source oil pump gasket.
Good idea about the Dist. Mechanic switched it on me years ago. May upgrade to original one day.
Last edited by 75 Westy FI noob on Wed Jan 18, 2023 5:12 pm; edited 1 time in total |
Posted: Wed Jan 18, 2023 4:53 pm Post subject: Re: "There she dribbles...." |
SGKent wrote: |
The only thing I can add is look INSIDE the shroud and see if oil is slung all around it. If so it could be the front seal. |
I will check inside the shroud and see.
I think its mostly on the back/outside of the shroud.
Posted: Wed Jan 18, 2023 5:32 pm Post subject: Re: "There she dribbles...." |
Notice Alternator is still connected… I couldn’t get that adjuster bolt to budge. |
SGKent Samba Member
Posted: Wed Jan 18, 2023 6:04 pm Post subject: Re: "There she dribbles...." |
Quote: |
75 Westy FI noob -> Trying to source oil pump gasket. |
Autohaus AZ 111-115-111B Engine Oil Pump Gasket. Good quality. I just used one the other day. Better than the VR kit one. A little thicker but not significantly so. Now let me share a bit of advice. Leave the oil pump alone. Period. Just retorque the nuts if you think they are loose. There are a plethora of threads on this forum where people broke the ears off their T4 pumps and destroyed them trying to get them out, only to find they would not budge. By the time they loosened the bolts above and below the pump and got the pump out, they not only had destroyed their NLA oil pump, but also had a case seam leak to deal with. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jan 18, 2023 6:49 pm Post subject: Re: "There she dribbles...." |
I will take that advice. Thanks !! |
Posted: Sun Jan 22, 2023 1:08 pm Post subject: Re: "There she dribbles...." |
I left the oil pump alone…
Changed the main seal there, hopefully reseated the flange well enough but not sure how deep it seats. Mine had no ‘fan hub sealing ring’. Are they in some engines but not others ?
But, mainly im here to ask how to extract the post of the oil pressure sender.
Whats the standard approach for this ..? im rattled.
Anyone have the number for the Canadian assisted suicide pod? may need.
Last edited by 75 Westy FI noob on Sun Jan 22, 2023 1:24 pm; edited 1 time in total |
SGKent Samba Member
Posted: Sun Jan 22, 2023 1:17 pm Post subject: Re: "There she dribbles...." |
always a dangerous situation but it doesn't take a lot of torque. Most likely that was your leak. A QUALITY easy out would be my choice but go gently. You might mount the old sender in a vise and twist on it a little to be sure the easy out doesn't easily shatter. Sometimes they can be junk.
Some extractors are made for thin wall and soft materials.
https://www.mcmaster.com/easy-out-extractors/extractors-for-soft-materials-and-thin-walled-parts-6/
You don't want to drill the fitting because debris can get in the oil. Use an extractor that fits the hole already in the sender. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jan 22, 2023 1:44 pm Post subject: Re: "There she dribbles...." |
The hole in the center is pretty small, so will take a very small extractor. If it isn't tighter than it should be it should unscrew, but if really tight it may not yield before a small extractor breaks. Assuming this is a Type 4 you might be able to rig up a way to apply air pressure to the case from the nipple for the oil filter so you could blow the drillings up out of the hole if you need to drill it larger. Use the utmost care here as anything that gets into the galleys is going to be destructive. |
Posted: Sun Jan 22, 2023 2:07 pm Post subject: Re: "There she dribbles...." |
Quote: |
Anyone have the number for the Canadian assisted suicide pod? may need. |
1-800-Maple-Leafs _________________ .ssS! |
Posted: Sun Jan 22, 2023 2:47 pm Post subject: Re: "There she dribbles...." |
Thanks for the feedback.. I expected recommendations to weld a tap to it.. but prob impossible due to location and material. I’ll try an easy out, maybe order one for soft material if i can find the patience. lol
shroud is off, so i had access with a wrench… it wouldn’t move, so i tapped the wrench (gently) with a hammer. I advise others to not do that. : ))
How about the fan seal ring? ( least of my worries here …)
Mine didn’t have one.. i guess i have time to order one now.
SGKent Samba Member
Posted: Sun Jan 22, 2023 4:05 pm Post subject: Re: "There she dribbles...." |
if you mean #4, look carefully on the crankshaft and on the hub. They hid. If it truly was missing that would be a bad leak. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jan 22, 2023 4:27 pm Post subject: Re: "There she dribbles...." |
Yes, didnt see that ring. i cleaned the flange and the hub.. didn’t see it. Maybe its buried in the base of the flange, or the seal? Does it fit in that little channel at the base of the flange? Bentley does not mention it in the text, but obv shows it in diagram.
Adding disaster pic below for folks who enjoy horror movies.
Posted: Sun Jan 22, 2023 5:27 pm Post subject: Re: "There she dribbles...." |
Im going to soak it in PB Blaster for two weeks, practice the old one (good idea), order the tool, and then put a torch on the case beside it before I turn it.
Hopefully it will move. There can’t be much thread in there.. 1/4-3/8” based on the new one. the new one has a much thinner nut. not positive its right. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jan 22, 2023 5:38 pm Post subject: Re: "There she dribbles...." |
75 Westy FI noob wrote: |
Does it fit in that little channel at the base of the flange? |
Yes, inner edge of the flat part of the flange that faces the crank, there's a step the ring sits in (or should).
Not much I can add regarding the sender remnants, as WT's suggests if drilling is required some compressed air into another opening in the system will blow chips away. Or pump a bunch of grease down the hole with a needle fitting on a grease gun and fill it up solid, then suck out the contaminated grease after with a shop vac, the residual won't cause issues later. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Sun Jan 22, 2023 5:39 pm Post subject: Re: "There she dribbles...." |
type 4 is 10mm straight fine thread I think unless someone has screwed something else in it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jan 22, 2023 5:53 pm Post subject: Re: "There she dribbles...." |
SGKent wrote: |
type 4 is 10mm straight fine thread I think unless someone has screwed something else in it. |
The Type 4 is a 10 x 1mm tapered pipe thread, a Type 1 is a straight thread that requires a gasket. |
