dkf66 Samba Member
Joined: March 06, 2015 Posts: 2 Location: Kamloops BC Canada
Posted: Sun Aug 02, 2020 9:18 pm Post subject: vdo tach wiring |
need help wiring an old vdo tach, the numbers -12 -6 15 +
+ is power but 15 could also be power, any help would be helpful
Thanks |
dkf66 Samba Member
Posted: Tue Mar 30, 2021 11:08 am Post subject: Re: vdo tach wiring |
any old vw guru's out there? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Tue Mar 30, 2021 12:06 pm Post subject: Re: vdo tach wiring |
I don't know but are you sure this is a negative ground tach that will work in your VW?
I'm wondering if it's positive ground since the tachs I have seen have a "1" to connect to the coil instead of a 15 but terminal 15 is the other post on the coil.
I'm wondering if positive ground tachs connect to terminal 15 instead because the coil connections to the distributor are reversed on a positive ground car too?
-12 could be 12v power for a negative ground car
-6 for 6v
+ for the positive ground
15 for the coil _________________ How to Post Photos
jeansbus Samba Member
Joined: January 19, 2010 Posts: 1 Location: Normandy, France
Posted: Mon May 31, 2021 10:55 am Post subject: Re: vdo tach wiring |
Hello,
I have a VDO tachometer identical to yours. N.O.S, but there was no manual. I found a wiring on the net.
could you plug in yours?
greetings from Normandy
Jean Michel
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Jun 01, 2021 3:24 am Post subject: Re: vdo tach wiring |
It could be its reading the dip of voltage on terminal 15 when the points close as the rpm signal.
Pure speculation on my part. _________________ .ssS! |
