SlowLane Samba Member
Joined: July 11, 2005 Posts: 1044 Location: Livermore, CA
Posted: Fri Aug 07, 2020 1:42 pm Post subject: Re: Corvair in my bus! |
Alan Brase wrote: |
WRT light front ends: Early SWB Porsche 911's put glued in pig iron counterweights inside the front bumper. Certainly a relocated battery or some engineering would help. OR could just bolt some stock car ballast weights under the nose. Even 60lb would make a difference. |
New criterion when evaluating co-pilots/hitch-hikers/big dogs/significant others: Ballast Potential. "Have another slice of pie, hon. The front end still isn't sticking the corners like it should." _________________ Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett |
mattlockwood Samba Member
Posted: Tue May 25, 2021 9:02 pm Post subject: Re: Corvair in my bus! |
Lots of work on my bus but no posting....photos in random order probably.
So I made added a set of gauges to my bus, Volts,CHT and Oil PSI.
I mounted the gauge holder-flange under the dash, using the heater control lever mounting points, using longer screws.
The CHT is non-lighted, so I took it apart and potted an led bulb holder and bulb inside, wrapped the gauge case in reflective tape on the inside, and wired it for lighting. Currently only have the voltage gauge hooked up. I wired it into the coil lead with a fuse.
Ive got an oil pressure sending unit yet to install (somehow) and a CHT lead to also install, once I figure that out. But for now, I like the location and the matching main gauges/engine gauges lighting.
_________________ 1970 Bay Window Bus.
110 hp 6 cyl Aircooled automatic |
dlwilson Samba Member
Joined: December 14, 2020 Posts: 99 Location: Lake Worth, FL
Posted: Wed May 26, 2021 5:29 am Post subject: Re: Corvair in my bus! |
Sorry for the hijack, but somebody please buy this 1976 Corvair camper in Kissimmee, FL, so that I don't. It's $4500, seems pretty solid, Powerglide, and engine looks like it's had recent work.
https://www.facebook.com/marketplace/item/5823049167706995 _________________ 1977 Bus, with 1973 1.7L engine (rebuild complete, install underway) |
Posted: Thu Jun 10, 2021 10:22 am Post subject: Re: Corvair in my bus! |
….just more ongoing progress...
One of the problems with this installation is the gaping holes where engine tin/baffling should be. I dropped the motor and trans and made some engine tins out of really thin, but rigid aluminum. After the engine is installed, they screw in on the sides. I also used pipe insulation foam in the back...hopefully it can withstand the engine bay heat.
vwmaniaman Samba Member
Joined: June 07, 2005 Posts: 562 Location: Grand Rivers,KY
Posted: Fri Jun 11, 2021 9:14 am Post subject: Re: Corvair in my bus! |
My Dad put Corvair power in a 68 Deluxe bus that he converted to a camper. We lived in Phoenix area at the time and he wanted more power to climb the mountains. He used the Transvair Kit and his first motor was a 140hp. We deemed it too scary to drive with all that power. So we found a 95hp truck Corvair motor. That was a perfect setup. He traded it off without me knowing. Guess he knew I was too poor at that time. Just wish I had gotten it cause it was sweet. I still have the original brochure somewhere in my stuff. _________________ Working on a VW is like fun with a friend!
65 Beetle
75 Westy "Pumpkin Van"
86 Westy "Brown Betty"
87 Cabrio |
Posted: Fri Jun 11, 2021 12:25 pm Post subject: Re: Corvair in my bus! |
If you ever find the brochure, I’d love to see it! _________________ 1970 Bay Window Bus.
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Sat Oct 23, 2021 9:44 am Post subject: Re: Corvair in my bus! |
where did you come up with the engine mounts? _________________ where its cold and snowy |
Posted: Wed Jul 20, 2022 6:34 pm Post subject: Re: Corvair in my bus! |
bigbore wrote: |
where did you come up with the engine mounts? |
Got lucky and found a guy out in Oregon who had one _________________ 1970 Bay Window Bus.
