Ghia Trunk cable - knob will not budge!
russelltatedotcom
russelltatedotcom is offline
PostPosted: Tue Aug 04, 2020 1:16 am    Post subject: Ghia Trunk cable - knob will not budge! Reply with quote
Hi Guys, I searched for this problem already but could not find an answer, if anybody can shed some light i'd be grateful.
The trunk release mechanism seems to be frozen on my Ghia. Not at the latch end but at the knob end behind the drivers door, it just will not move?
I've tried WD40 a few times and tapped it with a hammer, but did not want to go too mad as I might break the original white release knob.
Luckily the trunk is frozen open no closed and the latch does move OK if you push it with your finger
Does anybody have ideas on how I can free the mechanism up?
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Tue Aug 04, 2020 5:53 am    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
I’m suspecting rust. Where the knob enters there is a steel sleeve held on by two screws. The cable itself runs through a plastic tube.
Disconnect the cable from the latch at the rear and see if you can rotate the knob. Pull the 1/4 panel and the back seat and look at the assembly. If you can get to the screws you should be able to pull the whole thing out.
Volkswagen!
(Compression 8.7:1)
Marcdeb
Marcdeb is offline
PostPosted: Tue Aug 04, 2020 7:31 am    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
I originally thought you were asking about the "Front" trunk!. Just to avoid confusion, you are referring to the Deck Lid, or Engine Lid release. Smile
There is some very detailed information on the deck lid release and how it works on Page 2 (5-13-0Cool of this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
Here is another very helpful thread on the Deck Lid Release.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...e+is+broke
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
russelltatedotcom
PostPosted: Wed Aug 05, 2020 9:14 pm    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
Sorry deck lid (rear)
russelltatedotcom
PostPosted: Thu Aug 06, 2020 6:11 pm    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
Here's the funny thing there are no screws or bolts around the knob, How do get the cable/shaft OUT to replace?
sputnick60
sputnick60 is offline
PostPosted: Fri Aug 07, 2020 2:20 am    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
Judging by your mirrors we are talking about a '66 or a '67?
My car is a '66 and the way I removed that pull wire involved disconnecting it from the striker and giving it a heave. Out she came.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Era Vulgaris
Era Vulgaris is offline
PostPosted: Fri Aug 07, 2020 5:18 am    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
The knob is attached to the cable. When you buy a new cable it comes with a new knob on it.
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
russelltatedotcom
PostPosted: Fri Aug 07, 2020 8:26 pm    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
thanks I;m just not sure if it's going to budge, released or attached to the lack at the deck lid.
Era Vulgaris
PostPosted: Sat Aug 08, 2020 6:49 am    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
The place it's most likely stuck is in the sheath right behind the knob.
Have you tried a prybar and a BFH?
It's possible you may just have to sacrifice this one to the Ghia gods, and buy a new cable.
Currently own:
Previously owned:
Steelz21
Steelz21 is offline
PostPosted: Sun Oct 18, 2020 5:09 pm    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
I had the same problem.
I sprayed Fluid Film down the cable and forced it through with compressed air. I did this at both ends and it’s slick operating now.
runamoc Premium Member
runamoc is offline
PostPosted: Tue Oct 20, 2020 7:20 am    Post subject: Re: Ghia Trunk cable - knob will not budge! Reply with quote
when the cable breaks the rear engine lid will lift
Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
