Stockholm VW Samba Member
Posted: Thu Aug 06, 2020 6:03 pm Post subject: Radio always hot? |
The radio in my 66 bug is always hot wired. If I leave it on (with volume on or off) it drains the battery. Even with key out. I thought the radio was supposed to go through ignition.
Does it not?
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Thu Aug 06, 2020 6:08 pm Post subject: Re: Radio always hot? |
Welcome to VWs.
that's the way they were done from the factory. _________________ Glenn
Member #1009
#BlueSquare |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Aug 06, 2020 6:20 pm Post subject: Re: Radio always hot? |
Shouldn't run the battery down when the radio is off. You can change the wire so it is off with the key. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Thu Aug 06, 2020 6:46 pm Post subject: Re: Radio always hot? |
Glenn wrote: |
Welcome to VWs.
that's the way they were done from the factory. |
Thanks! I guess I just need to remember. |
Posted: Thu Aug 06, 2020 6:48 pm Post subject: Re: Radio always hot? |
60ragtop wrote: |
Shouldn't run the battery down when the radio is off. You can change the wire so it is off with the key. |
No, not when it’s off, but if I turn volume down and leave it in overnight. ☹️👎
Like I said, just gotta remember. Or Like you said, have an auto-electrical tech wire it through ignition. |
Glenn Mr. 010
Posted: Thu Aug 06, 2020 6:57 pm Post subject: Re: Radio always hot? |
Stockholm VW wrote: |
It's just a matter move moving the wire on the fuse panel to a keyed hot. Should take about 10 seconds _________________ Glenn
Member #1009
#BlueSquare |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Aug 06, 2020 7:00 pm Post subject: Re: Radio always hot? |
I'm second-owner of both my 1970 and 1971; both had dealer installed radios. The 1970 was wired "always hot" and the 1971 was wired "switched hot".
But easy to switch over.
Modern stereos typically have a switched red wire with inline fuse and an "always hot" yellow wire for clock and station memory. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Aug 07, 2020 2:06 pm Post subject: Re: Radio always hot? |
If you need to turn the radio down, just turn it off.
If you have the radio on, leave it turned up enough to hear it easily with the engine turned off. _________________ In Stereo, Where Available! |
Posted: Fri Aug 07, 2020 3:37 pm Post subject: Re: Radio always hot? |
Eric&Barb wrote: |
If you have the radio on, leave it turned up enough to hear it easily with the engine turned off. |
Good idea. I guess I just have to “relearn”. LOL |
Posted: Fri Aug 07, 2020 3:59 pm Post subject: Re: Radio always hot? |
We have faith in you!
Being able to turn off the engine and turn on the radio without frying the points (key turned to "Run" position with engine off can do that) is worth relearning. _________________ In Stereo, Where Available! |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Eric&Barb wrote: |
I had to learn that the hard way, too ! _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
Posted: Fri Aug 07, 2020 4:22 pm Post subject: Re: Radio always hot? |
67 Florida Deluxe wrote: |
Eric&Barb wrote: |
I had to learn that the hard way, too ! |
I know, right? 🤪 Thanks. |
Posted: Fri Aug 07, 2020 4:24 pm Post subject: Re: Radio always hot? |
Eric&Barb wrote: |
Being able to turn off the engine and turn on the radio without frying the points (key turned to "Run" position with engine off can do that) is worth relearning. |
This is good to know. Learning new stuff every day in this forum. 👍 |
Posted: Fri Aug 07, 2020 4:28 pm Post subject: Re: Radio always hot? |
After over three decades with these ACVWs, and over 400,000 miles between us driving them, STILL LEARNING new stuff. _________________ In Stereo, Where Available! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Fri Aug 07, 2020 4:40 pm Post subject: Re: Radio always hot? |
This is not stock but I've seen a few VWs where they left it hooked to "Hot" but set up a separate on/off switch.
So you don't burn up the points but don't have to mess with the on/off volume turning either.
Or find and install an era-correct Blaupunkt - they have a push on/off on the volume knob. _________________ How to Post Photos
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
