Tall Bloke Samba Member
Joined: October 07, 2005 Posts: 233 Location: UK>Ohio>UK
Posted: Fri Aug 07, 2020 6:25 am Post subject: 36hp Riechert dual carb - options on distributor |
I am in the process of getting the Riechert dual carb set up ( 28 pci )and wanted to know which was the better option I have.
I currently have the original Bosch VJU4BR8 - should I keep this and run the vacuum line to one of the carbs (or both using a Tee piece) or use an existing old Bosch 009 distributor (Made in Germany) and block the vacuum lines to the carbs.
I am seeing that the most popular route would be use the 010, but this would be further down the road once funds allow.
Thanks _________________ -------------------
All of 30 horses ! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Fri Aug 07, 2020 6:29 am Post subject: Re: 36hp Riechert dual carb - options on distributor |
Tall Bloke wrote: |
Thanks |
010
_________________ Glenn
Member #1009
#BlueSquare |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Fri Aug 07, 2020 1:46 pm Post subject: Re: 36hp Riechert dual carb - options on distributor |
I have heard that running a VJU4 BR8 without vacuum will act like a VJ4 BR8, that later was Superceeded by the 019.
The 019 should be a better choice than a 009.
Glenn know this better than me 🙂 _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Glenn Mr. 010
Posted: Fri Aug 07, 2020 1:48 pm Post subject: Re: 36hp Riechert dual carb - options on distributor |
It is true the mechanical curve of the VJU4BR8 is the same as a VJ4BR8 (019).
I'd still get a 010 when you have the spare cash. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Aug 08, 2020 6:23 am Post subject: Re: 36hp Riechert dual carb - options on distributor |
In response, confirming as an interim solution , the original distributor without vacuum advance is preferable to using the 009 until the 010 is available. _________________ -------------------
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Aug 09, 2020 7:50 am Post subject: Re: 36hp Riechert dual carb - options on distributor |
Yes. if you are interested in vintage appearances you might want to consider a VJ 4 BR 25 which was stock on the "bastard" Bus engine for 1960. The 010 which is the re-release of the BR 25 didn't appear on the scene until about 1968. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Aug 09, 2020 9:48 am Post subject: Re: 36hp Riechert dual carb - options on distributor |
Thanks tasb. _________________ -------------------
swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Posted: Tue Nov 24, 2020 8:48 pm Post subject: Re: 36hp Riechert dual carb - options on distributor |
Your build is not Okrasa, and is not dual port, but Okrasa did use the vacuum line, and connected it to the drivers side carburetor. _________________ https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
Posted: Mon Nov 30, 2020 2:44 am Post subject: Re: 36hp Riechert dual carb - options on distributor |
I have a dual 28PCI single port. My heads have had some work to improve them. I had a stock exhaust and TDE tailpipes. I initially used a VJ4BR8 which seemed to match the engine OK. I then added Speedwell 1.4:1 ratio rockers and a Vintage Speed Sebring exhaust; I initially used the VJ4BR8 but then moved to a VJR4BR25. This really suited my new setup, and was a noticeable improvement. _________________ Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253 |
