brian rogers Samba Member
Joined: April 14, 2002 Posts: 137 Location: Salt Lake City, Utah
Posted: Fri Aug 07, 2020 6:13 pm Post subject: Headers, what’s good out there. |
As the subject says. What’s good out there? I want to run full tin quandary flaps.
and thermostat. What fits? And what size thinking 1 5/8” on a 2165, 120 cam and kit. Heads are the choke point for now but will get a Fisher book quick port with 40/35 valve. CB Panchito are in the plans a few years down the road. It’s just a driver. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Fri Aug 07, 2020 6:19 pm Post subject: Re: Headers, what’s good out there. |
Berg GB933S is a 1-5/8" that cleans the thermostat. that's what I have.
_________________ Glenn
Member #1009
#BlueSquare |
Bama Dave Samba Member
Posted: Fri Aug 07, 2020 6:20 pm Post subject: Re: Headers, what’s good out there. |
brian rogers wrote: |
I want to run full tin quandary flaps. |
Ok....what? _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
Glenn Mr. 010
Posted: Fri Aug 07, 2020 6:22 pm Post subject: Re: Headers, what’s good out there. |
Last Fall i built a 2017 with a pair of CB 1-5/8" heater boxes matched with a A1 stainless header.
Thermostat fits just fine.
Member #1009
#BlueSquare |
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Fri Aug 07, 2020 8:11 pm Post subject: Re: Headers, what’s good out there. |
Quote: |
Last Fall i built a 2017 with a pair of CB 1-5/8" heater boxes matched with a A1 stainless header. |
Glenn- did you have to cut, reposition and reweld the flanges either on the header or on the heater boxes (HBs)?
edit- I just checked CB's site for those HB. Appears they do not have any flanges at the rear pipe ends, so that you had to have matching ones to the header welded on.
What size valves were in the heads for this engine?
Has the owner (or you) driven the car in cool weather so that he could report on the effectiveness of the HBs? If you did, was the heat output much better than the usual fin-less 1.5" HB?
I have parts for an 82 x 94 mm (2276 cc) engine and somewhat worked 40 x 35 mm valved heads for which an exhaust system like this, especially the CB HB should work reasonably well. |
Posted: Fri Aug 07, 2020 9:16 pm Post subject: Re: Headers, what’s good out there. |
Where that came from is spell check hell.
I want to run flaps and even able to use the thermostat. But my run time is mainly late spring to mid fall. If I get a condensation problem I’m armed. |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Fri Aug 07, 2020 9:32 pm Post subject: Re: Headers, what’s good out there. |
I have 2 A-1 exhausts. Not impressed. _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sat Aug 08, 2020 12:50 pm Post subject: Re: Headers, what’s good out there. |
AA sidewinders usually clear. My current one clears with no bracket grinding whatsoever. I did two others, and they needed a notch cut out on the brackets to clear.
_________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Glenn Mr. 010
Posted: Sat Aug 08, 2020 1:33 pm Post subject: Re: Headers, what’s good out there. |
Rome wrote: |
edit- I just checked CB's site for those HB. Appears they do not have any flanges at the rear pipe ends, so that you had to have matching ones to the header welded on. |
These had the flanges already welded and they aligned perfectly. They were sold by CB and are made by Dansk. Maybe the they are sourcing them from another vendor.
Rome wrote: |
What size valves were in the heads for this engine? |
"Panchito 044™ (40 x 35.5) 90.5/92 Bore (each) w/Dual Hi-Rev Spring Upgrade"
Rome wrote: |
Has the owner (or you) driven the car in cool weather so that he could report on the effectiveness of the HBs? If you did, was the heat output much better than the usual fin-less 1.5" HB? |
Unfortunately then engine has been sitting since I built it and has not been installed yet... long story.
Roland... looking back the exhaust was ordered directly from Tiger @ A1 since I wanted some changes and CB told me to get it directly from him. So maybe the CB HB were sent to him and he welded the flanges. _________________ Glenn
Member #1009
#BlueSquare |
Rome Samba Member
Posted: Sat Aug 08, 2020 5:34 pm Post subject: Re: Headers, what’s good out there. |
Thanks, Glenn. |
LucKaS Samba Member
Joined: December 25, 2015 Posts: 170 Location: Alabama
Posted: Sun Aug 09, 2020 7:41 am Post subject: Re: Headers, what’s good out there. |
Glenn, what’s with the extra support on the rear of your motor? _________________ If only all of life's little problems could be solved with a little PB Blaster and a hammer. |
Bad bug Samba Member
Posted: Sun Aug 09, 2020 8:21 am Post subject: Re: Headers, what’s good out there. |
Glenn wrote: |
Glenn can you get this header today from the bergs. |
Posted: Sun Aug 09, 2020 9:24 am Post subject: Re: Headers, what’s good out there. |
I would imagine you can. How much is your left nut worth to you?? 😂 _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
Posted: Sun Aug 09, 2020 10:48 am Post subject: Re: Headers, what’s good out there. |
It’s looking like I’m going Berg as all the older builders are gone. My main quandary is fit. As Berg said oncest upon a time cry once. |
74 Thing Samba Member
Glenn Mr. 010
Posted: Sun Aug 09, 2020 11:14 am Post subject: Re: Headers, what’s good out there. |
LucKaS wrote: |
Glenn, what’s with the extra support on the rear of your motor? |
Berg rear engine support and Berg tranny crossmember. _________________ Glenn
Member #1009
#BlueSquare |
Dauz Samba Member
Posted: Sun Aug 09, 2020 11:41 am Post subject: Re: Headers, what’s good out there. |
The muffler can be junk. But the 1 5/8" ceramic coat from carcraftstore.com worked fine for me for several years. I did wind up lopping off the muffler it came with and replacing it with a flowmaster. It is an empi brand header. The difference between the empi and bugpack was the empi tucked up into the rear while the bugpack hung down and scraped on everything.
I've said this before, however. If I ever build another NA street motor, I'll run the wasp from CSP |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Aug 09, 2020 12:21 pm Post subject: Re: Headers, what’s good out there. |
Dauz wrote: |
CSP! Nuff said.
CSP EVO Competition. 1 5/8" with heater boxes.
Fit's perfectly under and out of the way of the rear apron. This engine has the thermostat intact.
Just be prepared for some sticker shock when you follow this link.
https://www.csp-shop.com/en/exhaust-heating/csp-ev...9794a.html _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Posted: Sun Aug 09, 2020 12:46 pm Post subject: Re: Headers, what’s good out there. |
Suddenly the berg system is a bargain _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Aug 09, 2020 12:56 pm Post subject: Re: Headers, what’s good out there. |
Glenn wrote: |
Suddenly the berg system is a bargain |
I know! Right?
The EVO has a very unique sound that I cannot even try to describe.
It's just way different that the typical ACVW header sound. _________________ I have learned over the years.
Buy Once, Cry Once!
