malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Tue Aug 11, 2020 4:25 pm Post subject: Carb Install questions |
I think I know part of the answer, but please correct me if I am wrong.
I am installing a set of dual weber 44s temporarily to attempt to start this newly built type 4 2.0. The webers are on loan. So.... the gasket kit comes with all kinds of stuff and no directions.
Since I am installing carbs, do I NOT use the phenolic blocks? Just use the 4 metal seals that slide over the intake studs?
2ndly, since these are temporary, I suppose I am gonna need to put fresh seals on when I get the permanent carbs on, correct? Anyone recommend adding a light coat of sealant, now or on the permanent install?
What about just using the phenolic blocks as the temporary seals? good idea, bad idea? Will they work since they kinda change the geometry of the intake and the cross bar, etc....
Give me you thoughts on the whole idea.
THanks _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Wed Aug 12, 2020 5:27 am Post subject: Re: Carb Install questions |
My understanding is the phenolic blocks are only used on the Fuel Injection system (it insulates it from the heat from the head). The carbs need the heat to atomize the fuel better. As for using them as a temporary seal i'd just order a new set of seals for your new carbs they shouldn't cost that much. _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Wed Aug 12, 2020 5:44 am Post subject: Re: Carb Install questions |
Use the metal gaskets.
The FI gaskets insulate the fuel injectors from heat and create proper spacing for them in their bores. I'm sure if you'd be able to use them on carbs, as I recall the carb intakes being thicker than the FI intakes.
With carbs, you want that heat to transfer into those intake manifolds, especially on single carbs, reasons behind why VW had the pre-heat (heat riser) tubes. Duals aren't as bad on icing and staying cold, but any heat from the engine through the intakes will increase fuel atomization.
Sam _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Wed Aug 12, 2020 2:55 pm Post subject: Re: Carb Install questions |
You can use the phenol gaskets on a carbureted engine as a tuning tool. If you live in a hot climate the thick gaskets will keep the heat under control, this is particularly needed after shutdown when running ethanol laced fuels. In a colder climate you want to use the thin metal gaskets to help get heat to the carbs and thus prevent icing and improve atomization. |
Posted: Wed Aug 12, 2020 5:12 pm Post subject: Re: Carb Install questions |
So it is all about the heat transfer. Not much worry about leaks or proper seal. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
busdaddy Samba Member
Posted: Wed Aug 12, 2020 5:23 pm Post subject: Re: Carb Install questions |
Leaks are an issue, good clean flat surfaces on both sides ensure that, but don't re use the metal gaskets since they conform to a particular area just once.
As already mentioned a phenolic spacer between the carbs(s) and manifold(s) is a good idea to prevent heat soak, but for running the metal gaskets keep the manifolds warm and that a good thing.
Pay close attention to the edges of the cylinder tin surrounding the manifold to head joint, they sometimes protrude enough to get pinched and prevent the manifold from seating fully, those leaks are a major PITA, watch for it while installing... _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
