blacka1vw Samba Member
Joined: September 11, 2013 Posts: 89 Location: N. Central PA
Posted: Fri Aug 14, 2020 7:04 am Post subject: 79 Bus with remnants of both seat bulkheads |
I was wondering if anyone has seen this in a late bay. We recently got our first bus and were really excited . It’s a 79 it has the remains of a bulkhead behind both seats. Not just a small reinforcement but a full bulkhead like I’ve seen in pictures of earlier bays. They are both cut off now. It appears that the passenger seat has replaced sliders and some grinding was done in that area too. Could it have been built with the fixed passenger seat like I’ve seen in other photos? Maybe there’s something in the mcodes? It says it was built with 2-0-3 seating.
_________________ 64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Fri Aug 14, 2020 7:13 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
What model bus is this? A camper? There isn't a bulkhead behind the driver's seat?
Late model bays didin't have a bulkhead behind the passenger seat as the seat had the capabilities to pivot rearward and add seating to the cargo/camping area. Pretty neat design touch that they carried out to the Vanagon's.
The seam or "cut" section doesn't look very cut to me. Do you have any photos giving scale to the entire "bulkhead area"? Perhaps shot from the rear of the bus forward?
Sam _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Fri Aug 14, 2020 7:58 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
That's a vanagon seat someone added. |
busdaddy Samba Member
Posted: Fri Aug 14, 2020 8:09 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
A Kombi or panel would have come with both bulkheads (unless M coded for Westfalia), the M plate has all the answers (aside from what your PO was thinking). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Aug 14, 2020 7:01 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
alaskadan wrote: |
Definitely Vanagon seats.
Drivers seat track is the original but also the late bus style. It’s title as a 79. I got it with Vanagon seats up front and a 3/4 westy bed in back that’s not original. Got a few holes drilled in the floor. I kinda figured it was a home brew camper at some point. Definitely had a spare tire on the front. I’ll get better pics of the inside posted tomorrow. You can definitely see where it was cut.its not horrible but definitely not Vw quality. I decoded the m plate but I’m no expert. Here’s the plate. I’m just curious about it. It’s awesome getting to know this old Bus.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
Posted: Fri Aug 14, 2020 7:04 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
busdaddy wrote: |
A Kombi or panel would have come with both bulkheads (unless M coded for Westfalia), the M plate has all the answers (aside from what your PO was thinking). |
It has windows with sliders in the middle and solid windows in the rear. What would make it a Kombi model? _________________ 64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
Posted: Fri Aug 14, 2020 7:07 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
Well I don't see any Westfalia codes (but I'm not an expert on M plates), I do see a UP which I think means Portland OR, could be a former Riviera, they preferred Commercial models for conversion bases. Here's a bunch of decoders to try: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Aug 14, 2020 8:07 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
busdaddy wrote: |
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
Posted: Fri Aug 14, 2020 10:13 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
blacka1vw wrote: |
busdaddy wrote: |
It has windows with sliders in the middle and solid windows in the rear. What would make it a Kombi model? |
Not for sure, lots of models could have had that configuration. How about some more pictures of the rear interior, headlining and cab? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
78BusGA Samba Member
Joined: February 01, 2017 Posts: 315 Location: Buford, Georgia
Posted: Fri Aug 14, 2020 10:59 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
No sheetmetal like that on my '78 Kombi. Similar to yours with the slider middle side windows. Mine has the small triangular reinforcements. I see the rubber mat in the B pillar photo which seems to go up to the front seat base, so I am betting since that looks in tact it wasn't configured for a camper.
A commercial layout would seem to make sense, though were even those outfitted with the bulkheads? I don't recall ever seeing a bay that late with bulkheads, even though they are beautiful with early bay deluxe panels mounted.
Think they could have been an add on with end of type 2 production to use up old parts like it is known the Factory to do to, just use up what was laying about?
Have you put your M-plate into the decoder yet? There's a goodly lot of codes on that. The programmer is still adding in odd production codes and might benefit if you have new ones to add if the features of that code can be figured out. _________________ Few will understand the passion and majesty, among the nuts and grease.
Tom H.
My '74 Super 1303 thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=764902&start=60
My '78 Kombi Bus thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=769385&highlight=
'72 Superbeetle (retired), '78 Bus Kombi 2.0FI, '74 1303 Superbeetle |
Posted: Sat Aug 15, 2020 4:37 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
78BusGA wrote: |
Have you put your M-plate into the decoder yet? There's a goodly lot of codes on that. The programmer is still adding in odd production codes and might benefit if you have new ones to add if the features of that code can be figured out. |
I did do the one decoder but I’m not sur I’m interpreting the information correctly that it’s giving me back. Here are some more photos. I took a few inside the structure of the passenger seat and there is a reinforcement/bolt plate in the back near where my seat belt buckle bolts on on that side. Also just above where they started cutting on the pillars there are spot welds drilled and paint missing from something else that’s gone now. Interior has wood grain side panels not sure if those were something someone added. The headliner is paneling now but I’m not sure what was there originally. Thanks for the input guys.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sat Aug 15, 2020 5:04 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
had a 79 passenger bus, for just a hot min, and it had the sliders. |
Posted: Sat Aug 15, 2020 8:39 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
Those stripes are badass!
I see a short vinyl headliner over the cab, that says Kombi not for Westfalia to me, the interior parts and middle windows were likely added by a PO from a junkyard find.
The RH seat tracks have been added later, you can see the spot where the cleat for the non adjustable seat were attached here:
Looks like a nice bus with good bones, be happy a hacked seat is the worst of your problems, others have to replace the lower 6" of the body all the way around. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Sat Aug 15, 2020 3:00 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
No floor vent/flapper door for rear heat _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Sat Aug 15, 2020 5:34 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
busdaddy wrote: |
Looks like a nice bus with good bones, be happy a hacked seat is the worst of your problems, others have to replace the lower 6" of the body all the way around. |
Thanks we are really happy to have it. Some of the other buses we were considering were the other kind. The ones where you have to replace the whole bottom. _________________ 64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
Posted: Sat Aug 15, 2020 5:35 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
ImAddicted wrote: |
No floor vent/flapper door for rear heat |
where would these parts be located? _________________ 64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
babysnakes Samba Member
Posted: Sun Aug 16, 2020 10:04 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
busdaddy wrote: |
I see a short vinyl headliner over the cab, that says Kombi not for Westfalia to me, the interior parts and middle windows were likely added by a PO from a junkyard find. |
Right? I always thought Kombis had solid middle and rear windows. |
Posted: Sun Aug 16, 2020 10:35 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
babysnakes wrote: |
busdaddy wrote: |
Bone stock yes, but they could be ordered with vents if you wanted. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Aug 16, 2020 11:08 am Post subject: Re: 79 Bus with remnants of both seat bulkheads |
blacka1vw wrote: |
ImAddicted wrote: |
where would these parts be located? |
Upon the floor in the area the middle seat goes, centered, pretty sure where that flat spot is in your pic by the seat mount plate and center seam. Would look like this
[/img] _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Posted: Sun Aug 16, 2020 12:52 pm Post subject: Re: 79 Bus with remnants of both seat bulkheads |
That's usually only found on deluxe buses, commercials don't get the fancy stuff like that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
